DB2 9.5 и блокировки
Добрый день! Имеется SLES11 (x64), DB 9.5 Раньше базы работали под управлением DB2 8.2. Экскалаций блокировок не было. Переехали на 9.5. Стали появляться эскалации. Конфигурация нашей БД Database Configuration for Database Self tuning memory (SELF_TUNING_MEM) = OFF Size of database shared memory (4KB) (DATABASE_MEMORY) = AUTOMATIC(192928) Database memory threshold (DB_MEM_THRESH) = 10 Max storage for lock list (4KB) (LOCKLIST) = AUTOMATIC(10240) Percent. of lock lists per application (MAXLOCKS) = AUTOMATIC(20) Package cache size (4KB) (PCKCACHESZ) = AUTOMATIC(6144) Sort heap thres for shared sorts (4KB) (SHEAPTHRES_SHR) = AUTOMATIC(5000) Sort list heap (4KB) (SORTHEAP) = AUTOMATIC(1024) Database heap (4KB) (DBHEAP) = AUTOMATIC(1200) Catalog cache size (4KB) (CATALOGCACHE_SZ) = 260 Log buffer size (4KB) (LOGBUFSZ) = 98 Utilities heap size (4KB) (UTIL_HEAP_SZ) = 47272 Buffer pool size (pages) (BUFFPAGE) = 1000 SQL statement heap (4KB) (STMTHEAP) = AUTOMATIC(6144) Default application heap (4KB) (APPLHEAPSZ) = AUTOMATIC(512) Application Memory Size (4KB) (APPL_MEMORY) = AUTOMATIC(40016) Statistics heap size (4KB) (STAT_HEAP_SZ) = AUTOMATIC(4384) Interval for checking deadlock (ms) (DLCHKTIME) = 10000 Lock timeout (sec) (LOCKTIMEOUT) = -1 Changed pages threshold (CHNGPGS_THRESH) = 60 Number of asynchronous page cleaners (NUM_IOCLEANERS) = AUTOMATIC(3) Number of I/O servers (NUM_IOSERVERS) = AUTOMATIC(3) Index sort flag (INDEXSORT) = YES Sequential detect flag (SEQDETECT) = YES Default prefetch size (pages) (DFT_PREFETCH_SZ) = 32 Track modified pages (TRACKMOD) = OFF Default number of containers = 1 Default tablespace extentsize (pages) (DFT_EXTENT_SZ) = 32 Max number of active applications (MAXAPPLS) = AUTOMATIC(60) Average number of active applications (AVG_APPLS) = AUTOMATIC(1) Max DB files open per application (MAXFILOP) = 61440 Automatic maintenance (AUTO_MAINT) = ON Automatic database backup (AUTO_DB_BACKUP) = OFF Automatic table maintenance (AUTO_TBL_MAINT) = ON Automatic runstats (AUTO_RUNSTATS) = ON Automatic statement statistics (AUTO_STMT_STATS) = ON Automatic statistics profiling (AUTO_STATS_PROF) = OFF Automatic profile updates (AUTO_PROF_UPD) = OFF Automatic reorganization (AUTO_REORG) = OFF Enable XML Character operations (ENABLE_XMLCHAR) = YES WLM Collection Interval (minutes) (WLM_COLLECT_INT) = 0 Вроде все параметры отвечающие за распределение памяти установили в AUTOMATIC:) Может быть что-нибудь упустили? ... |
| 02.12.2010, 10:18 |
Max storage for lock list (4KB) (LOCKLIST) = AUTOMATIC(10240) Percent. of lock lists per application (MAXLOCKS) = AUTOMATIC(20) 1) Измените эти параметры в сторону увеличения. 2) Сделайте транзакции как можно короче (кол-во изменяемых/добавляемых/удаляемых записей должно быть как можно меньше) 3) используйте LOCK TABLE где это возможно по бизнес-логике. ... |
| 02.12.2010, 10:38 |
chuk_and_gek, Здравствуйте. Self tuning memory (SELF_TUNING_MEM) = OFF Вы специально так сделали? Оно же автоматически рулить AUTOMATIC значениями не будет... ... |
| 02.12.2010, 11:07 |
А разве эти параметры не расчитывает сама DB2? Мы просто пишим using LOCKLISTAUTOMATIC? Т.е надо написать using LOCKLISTAUTOMATIC(20480)? И это будет значит, что больше этого DB2 не даст, а уменьшить может? ... |
| 02.12.2010, 11:07 |
chuk_and_gekА разве эти параметры не расчитывает сама DB2? Мы просто пишим using LOCKLISTAUTOMATIC? Т.е надо написать using LOCKLISTAUTOMATIC(20480)? И это будет значит, что больше этого DB2 не даст, а уменьшить может?Если SELF_TUNING_MEM = OFF , то всё, что в AUTOMATIC, выставляется при активации базы либо как-то само (если указано просто AUTOMATIC), либо в стартовое значение (если указано 20480 AUTOMATIC, например). И в обоих случаях не меняется в процессе работы. ... |
| 02.12.2010, 11:20 |
Т.е. правильно будет SELF_TUNNING_MEM=2? ... |
| 02.12.2010, 11:33 |
chuk_and_gekТ.е. правильно будет SELF_TUNNING_MEM=2?Правильнее будет db2 update db cfg for yourdb using SELF_TUNING_MEM ON И по-хорошему надо разбираться, почему они возникают, эти эскалации. Может быть из-за того, что план запроса изменился, и теперь оно много сканит. А может из-за того, что приложений много и ей действительно не хватает LOCKLIST... ... |
| 02.12.2010, 11:47 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1602471]: |
38ms |
43ms |
| others: | 249ms |
| total: | 364ms |
