как в db2 транспонировать таблицу?
#37093471
Ссылка:
тынц
1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80.
create procedure cols2rows(
in p_sel_stmt clob(2m)
, in p_collen int
, in p_vallen int
--, out p_rc int
--, out p_msg varchar(128)
--, out p_stmt clob(2m)
LANGUAGE SQL
DYNAMIC RESULT SETS 1
BEGIN
declare p_rc int;
declare p_msg varchar( 128 );
declare p_stmt clob(2m);
declare SQLCODE int;
declare l_SQLTYPE_ID int;
declare l_SQLTYPE varchar( 128 );
declare l_SQLLENGTH int;
declare l_SQLSCALE int;
declare l_SQLNAME_DATA varchar( 128 );
declare l_SQLTYPEF varchar( 128 );
declare l_colexpr clob(2m) default '';
declare l_valexpr clob(2m) default '';
declare l_colid int default 0 ;
declare l_collen varchar( 10 );
declare l_vallen varchar( 10 );
declare l_colname varchar( 128 );
declare l1 RESULT_set_LOCATOR VARYING;
declare c_out cursor with return for s_out;
declare EXIT HANDLER FOR SQLEXCEPTION
BEGIN
GET DIAGNOSTICS EXCEPTION 1 p_msg = MESSAGE_TEXT;
set p_rc = SQLCODE;
END;
set l_collen=trim(char(coalesce(p_collen, 10 ))), l_vallen=trim(char(coalesce(p_vallen, 80 )));
-- construct case clauses
set p_stmt = 'describe '||p_sel_stmt;
set l_colexpr = 'when 0 then cast(repeat(''-'', '||l_collen||') as char('||l_collen||'))';
set l_valexpr = 'when 0 then cast(repeat(''-'', '||l_vallen||') as char('||l_vallen||'))';
call SYSPROC.ADMIN_CMD(p_stmt);
associate result set locator (l1)
with procedure SYSPROC.ADMIN_CMD;
allocate c1 cursor for result set l1;
open c1;
fetch c1 into l_SQLTYPE_ID, l_SQLTYPE, l_SQLLENGTH, l_SQLSCALE, l_SQLNAME_DATA;
while (SQLCODE!= 100 ) do
set l_colid = l_colid+ 1 ;
set l_colname =
case l_SQLTYPE_ID
when 404 -- BLOB
then '''x''''''||hex(a.'||l_SQLNAME_DATA||')||'''''''''
when 988 -- XML
then 'xmlserialize(a.'||l_SQLNAME_DATA||' as clob(4000))'
else 'a.'||l_SQLNAME_DATA
end;
set l_colexpr=l_colexpr||' '||'when '||rtrim(char(l_colid))||' then cast('''||l_SQLNAME_DATA||''' as char('||l_collen||'))';
set l_valexpr=l_valexpr||' '||'when '||rtrim(char(l_colid))||' then cast('||l_colname||' as char('||l_vallen||'))';
end while;
close c1;
-- construct select statement
set p_stmt=
'with '
||' a as (select s.*, rownumber() over() rn_ from ('||p_sel_stmt||') s) '
||', t (i) as (values 0 union all select i+1 from t where i<'||trim(char(l_colid))||') '
||'select '
||' case t.i '||l_colexpr||' end as col '
||', case t.i '||l_valexpr||' end as val '
||'from a, t '
||'order by a.rn_, t.i';
-- execute this statement
prepare s_out from p_stmt;
open c_out;
set p_rc= 0 ;
END;
вызов:
1. 2. 3. 4.
call cols2rows('select * from table(values
(current date, current time, current timestamp, double(1), real(1), 1, dec(1), clob(''123''), blob(''123''), decfloat(1), xmlparse (document ''<d><n>1</n></d>''))
, (current date, current time, current timestamp, double(2), real(2), 2, dec(2), clob(''456''), blob(''456''), decfloat(2), xmlparse (document ''<d><n>2</n></d>''))
) t(dt, tm, ts, dbl, rl, i, dec, cl, bl, df, xl)', 10 , 80 );
