Непонятное предупреждение от STMM
Здравствуйте! Подскажите, пожалуйста, почему может возникать предупреждение: "The DATABASE_MEMORY parameter could not be decreased" Контекст: 2011-01-31-17.57.43.007339+180 I69235593E512 LEVEL: Info PID : 3698 TID : 140423972514128PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : IGPG APPHDL : 0-228 APPID: *LOCAL.DB2.110128074903 AUTHID : IGPG EDUID : 168 EDUNAME: db2stmm (IGPG) 0 FUNCTION: DB2 UDB, buffer pool services, sqlbAlterBufferPoolAct, probe:90 MESSAGE : Altering bufferpool "IBMDEFAULTBP" From: "1551" <automatic> To: "2326" <automatic> 2011-01-31-17.57.53.037639+180 I69236106E513 LEVEL: Info PID : 3698 TID : 140435825617232PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DNC APPHDL : 0-92 APPID: *LOCAL.DB2.110128074648 AUTHID : DNC EDUID : 134 EDUNAME: db2stmm (DNC) 0 FUNCTION: DB2 UDB, buffer pool services, sqlbAlterBufferPoolAct, probe:90 MESSAGE : Altering bufferpool "DNC_ARCH_BP" From: "126739" <automatic> To: "190108" <automatic> 2011-01-31-17.57.55.829212+180 I69236620E554 LEVEL: Event PID : 3698 TID : 140435825617232PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DNC APPHDL : 0-92 APPID: *LOCAL.DB2.110128074648 AUTHID : DNC EDUID : 134 EDUNAME: db2stmm (DNC) 0 FUNCTION: DB2 UDB, access plan manager, sqlra_resize_pckcache, probe:150 CHANGE : APM : Package Cache : FROM "576364625" : TO "864546938" : success IMPACT : None DATA #1 : String, 29 bytes Package Cache Resized (bytes) 2011-01-31-17.57.55.829371+180 I69237175E494 LEVEL: Event PID : 3698 TID : 140435825617232PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DNC APPHDL : 0-92 APPID: *LOCAL.DB2.110128074648 AUTHID : DNC EDUID : 134 EDUNAME: db2stmm (DNC) 0 FUNCTION: DB2 UDB, config/install, sqlfLogUpdateCfgParam, probe:20 CHANGE : STMM CFG DB DNC: "Pckcachesz" From: "145066" <automatic> To: "217599" <automatic> 2011-01-31-17.57.55.840309+180 E69237670E731 LEVEL: Warning PID : 3698 TID : 140435825617232PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DNC APPHDL : 0-92 APPID: *LOCAL.DB2.110128074648 AUTHID : DNC EDUID : 134 EDUNAME: db2stmm (DNC) 0 FUNCTION: DB2 UDB, Self tuning memory manager, stmmDecreaseDBMemOriginatedBySTMM, probe:1606 MESSAGE : ZRC=0x02AE00A5=44957861=STMM_DBMEM_COULD_NOT_BE_DECREASED "The DATABASE_MEMORY parameter could not be decreased" DATA #1 : String, 141 bytes Overflow memory decrease amount exceeds overflow size. DATABASE_MEMORY decrease failed. Decrease amount: 643547136, overflow size: 607584256 2011-01-31-17.57.55.859597+180 I69238402E499 LEVEL: Event PID : 3698 TID : 140435825617232PROC : db2sysc 0 INSTANCE: db2inst1 NODE : 000 DB : DNC APPHDL : 0-92 APPID: *LOCAL.DB2.110128074648 AUTHID : DNC EDUID : 134 EDUNAME: db2stmm (DNC) 0 FUNCTION: DB2 UDB, config/install, sqlfLogUpdateCfgParam, probe:20 CHANGE : STMM CFG DB DNC: "Database_memory" From: "742320" <automatic> To: "647940" <automatic> ... |
| 03.02.2011, 09:32 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1602396]: |
71ms |
33ms |
| others: | 255ms |
| total: | 420ms |
