БД DUMP
Здравствуйте. Database dump. Невозможно подключиться к БД log DB: ................................................. 2011-02-21-11.34.36.916247+000 I4338382A530 LEVEL: Warning PID : 31987 TID : 2199112769232PROC : db2agent (ITSBOB) 0 INSTANCE: bobeu1 NODE : 000 DB : ITSBOB APPHDL : 0-7 APPID: *LOCAL.bobeu1.110221113435 AUTHID : BOBEU1 FUNCTION: DB2 UDB, Self tuning memory manager, stmmStartSortDbMonitorIfNecessary, probe:1559 MESSAGE : STMM Sort Memory Tuning cannot be activated because the Database Manager Configuration Parameter SHEAPTHRES is not set to 0. 2011-02-21-11.35.22.534446+000 I4338913A1641 LEVEL: Event PID : 32012 TID : 2199112770240PROC : db2stop INSTANCE: bobeu1 NODE : 000 FUNCTION: DB2 UDB, base sys utilities, sqleStartStopSingleNode, probe:1130 DATA #1 : String, 42 bytes /spimdb/db2home/bobeu1/sqllib/adm/db2stop2 DATA #2 : Hexdump, 256 bytes 0x000003FFFFD17E88 : 2F73 7069 6D64 622F 6462 3268 6F6D 652F /spimdb/db2home/ 0x000003FFFFD17E98 : 626F 6265 7531 2F73 716C 6C69 622F 6164 bobeu1/sqllib/ad 0x000003FFFFD17EA8 : 6D2F 6462 3273 746F 7032 004E 4F4D 5347 m/db2stop2.NOMSG 0x000003FFFFD17EB8 : 0046 4F52 4345 0053 4E00 0000 0000 0000 .FORCE.SN....... 0x000003FFFFD17EC8 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17ED8 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17EE8 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17EF8 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F08 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F18 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F28 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F38 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F48 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F58 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F68 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x000003FFFFD17F78 : 0000 0000 0000 0000 0000 0000 0000 0000 ................ 2011-02-21-11.35.22.660460+000 I4340555A384 LEVEL: Event PID : 32014 TID : 2199112770240PROC : db2stop2 INSTANCE: bobeu1 NODE : 000 FUNCTION: DB2 UDB, base sys utilities, DB2StopMain, probe:104 DATA #1 : String, 26 bytes Force phase is in progress DATA #2 : Hexdump, 4 bytes 0x000003FFFFC2CEF8 : 0000 0000 .... 2011-02-21-11.35.22.661292+000 I4340940A428 LEVEL: Event PID : 31968 TID : 2199112769232PROC : db2sysc 0 INSTANCE: bobeu1 NODE : 000 FUNCTION: DB2 UDB, base sys utilities, sqeAppServices::ExecuteStopForce, probe:1000 DATA #1 : String, 47 bytes [Force]->Number of applications to be forced : DATA #2 : Hexdump, 4 bytes 0x000003FFFFF30B48 : 0000 0002 .... ................................................................................................... ? ... |
| 22.02.2011, 19:52 |
БД DUMP
Не совсем понятно, вы пытаетесь подключиться к бд до того, как остановили бд (db2stop force) или после? в логе есть только одно предупреждение (warning), оно рекомендует Вам сделать update dbm cfg using SHEAPTHRES 0 (Database Manager Configuration Parameter SHEAPTHRES is not set to 0) остальные - говорят об остановке сервера ... |
| 24.02.2011, 05:25 |
БД DUMP
2011-02-23-08.03.24.987611 Instance:bobeu1 Node:000 файл bobeu1.nfy .................................................. PID:17864(db2acd 0) TID:178288976 Appid:none Health Monitor HealthIndicator::update Probe:500 ADM10501W Health indicator "Table Space Container Utilization" ("tsc.tscont_util") breached the "upper" warning threshold of "80 %" with value "82 %" on "table space container" "bobeu1.ITSBOB .ITSPSPACE8K./spimdb/db2home/bobeu1/bobeu1/NODE0000/SQL00001/ITSPSPACE8K". Calculation: "((os.fs_used/os.fs_total)*100);" = "((32544837632 / 39629324288) * 100)" = "82 %". History (Timestamp, Value, Formula): "()" 2011-02-23-08.03.24.989373 Instance:bobeu1 Node:000 PID:17864(db2acd 0) TID:178288976 Appid:none Health Monitor HealthIndicator::update Probe:500 ADM10501W Health indicator "Table Space Container Utilization" ("tsc.tscont_util") breached the "upper" warning threshold of "80 %" with value "82 %" on "table space container" "bobeu1.ITSBOB .SYSTOOLSTMPSPACE./spimdb/db2home/bobeu1/bobeu1/NODE0000/SQL00001/SYSTOOLSTMPSP ACE". Calculation: "((os.fs_used/os.fs_total)*100);" = "((32544849920 / 39629324288) * 100)" = "82 %". History (Timestamp, Value, Formula): "()" файл db2diag.log MESSAGE : ADM4000W A catalog cache overflow condition has occurred. There is no error but this indicates that the catalog cache has exceeded the configured maximum size. If this condition persists, you may want to adjust the CATALOGCACHE_SZ DB configuration parameter. Что можно предпринять? ... |
| 24.02.2011, 18:29 |
БД DUMP
Здравствуйте. Aquest2011-02-23-08.03.24.987611 Instance:bobeu1 Node:000 файл bobeu1.nfy .................................................. PID:17864(db2acd 0) TID:178288976 Appid:none Health Monitor HealthIndicator::update Probe:500 ADM10501W Health indicator "Table Space Container Utilization" ("tsc.tscont_util") breached the "upper" warning threshold of "80 %" with value "82 %" on "table space container" "bobeu1.ITSBOB .ITSPSPACE8K./spimdb/db2home/bobeu1/bobeu1/NODE0000/SQL00001/ITSPSPACE8K". Calculation: "((os.fs_used/os.fs_total)*100);" = "((32544837632 / 39629324288 ) * 100)" = "82 %". History (Timestamp, Value, Formula): "()" 2011-02-23-08.03.24.989373 Instance:bobeu1 Node:000 PID:17864(db2acd 0) TID:178288976 Appid:none Health Monitor HealthIndicator::update Probe:500 ADM10501W Health indicator "Table Space Container Utilization" ("tsc.tscont_util") breached the "upper" warning threshold of "80 %" with value "82 %" on "table space container" "bobeu1.ITSBOB .SYSTOOLSTMPSPACE./spimdb/db2home/bobeu1/bobeu1/NODE0000/SQL00001/SYSTOOLSTMPSP ACE". Calculation: "((os.fs_used/os.fs_total)*100);" = "((32544849920 / 39629324288) * 100)" = "82 %". History (Timestamp, Value, Formula): "()" Место в файловой системе, где лежат эти табличные пространства, занято более чем на 80%. Осталось ~ 7GB. Что делать - рашайте сами. Aquest файл db2diag.log MESSAGE : ADM4000W A catalog cache overflow condition has occurred. There is no error but this indicates that the catalog cache has exceeded the configured maximum size. If this condition persists, you may want to adjust the CATALOGCACHE_SZ DB configuration parameter. Что можно предпринять? Увеличить параметр базы CATALOGCACHE_SZ. ... |
| 25.02.2011, 13:10 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1602360]: |
37ms |
26ms |
| others: | 222ms |
| total: | 321ms |
