Ошибка при получении метаданных
Здравствуйте. Возникает ошибка при получении информации о типах данных. DB2 версии 9.7.4fix com.ibm.db2.jcc.am.mo: [jcc][2085][11336][4.7.112] Взаимоисключающие поля не могут оба содержать непустые значения. ERRORCODE=-4499, SQLSTATE=null at com.ibm.db2.jcc.am.dd.a(dd.java:317) at com.ibm.db2.jcc.am.dd.a(dd.java:382) at com.ibm.db2.jcc.t4.db.Zc(db.java:3225) at com.ibm.db2.jcc.t4.db.b(db.java:2939) at com.ibm.db2.jcc.t4.db.b(db.java:2850) at com.ibm.db2.jcc.t4.db.a(db.java:2709) at com.ibm.db2.jcc.t4.db.f(db.java:2694) at com.ibm.db2.jcc.t4.db.e(db.java:2571) at com.ibm.db2.jcc.t4.db.a(db.java:635) at com.ibm.db2.jcc.t4.db.l(db.java:589) at com.ibm.db2.jcc.t4.db.k(db.java:333) at com.ibm.db2.jcc.t4.db.e(db.java:96) at com.ibm.db2.jcc.t4.t.e(t.java:81) at com.ibm.db2.jcc.t4.sb.k(sb.java:160) at com.ibm.db2.jcc.am.om.jb(om.java:2100) at com.ibm.db2.jcc.am.pm.b(pm.java:3604) at com.ibm.db2.jcc.am.qm.Yb(qm.java:152) at com.ibm.db2.jcc.am.jc.a(jc.java:7747) at com.ibm.db2.jcc.am.jc.ce(jc.java:7501) at com.ibm.db2.jcc.am.jc.getTypeInfo(jc.java:7434) at com.ibm.db.base.DatabaseConnection.getSearchTypeInfo(DatabaseConnection.java:110) at com.ibm.db.base.DatabaseConnection.<init>(DatabaseConnection.java:44) at com.ibm.db.base.JDBCConnectionManager.createDatabaseConnection(JDBCConnectionManager.java:100) at com.ibm.db.DatabaseConnection.connect(DatabaseConnection.java:181) at city.common.Connections$2.createConnection(Connections.java:63) at city.common.NopConnectionManager.createConnection(NopConnectionManager.java:41) at city.common.Connections.initializeConnectionDB2(Connections.java:204) at city.main.MainClass.connect(MainClass.java:479) at city.main.MainClass.launchLogonDialog(MainClass.java:206) at city.main.MainClass.main(MainClass.java:178) ... |
| 23.06.2011, 12:02 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1602211]: |
79ms |
30ms |
| others: | 255ms |
| total: | 418ms |
