Деплой план
создал для вебложика деплой план имею web.xml <?xml version="1.0" encoding="UTF-8" ?> <!DOCTYPE web-app (View Source for full doctype...)> - <web-app> ... - <env-entry> <env-entry-name>server/databaseURL</env-entry-name> <env-entry-value>D:\\dev\\trac-projects\\it-jenty\\db\\trac.db</env-entry-value> <env-entry-type>java.lang.String</env-entry-type> </env-entry> </web-app> Создал plan.xml <?xml version='1.0' encoding='UTF-8'?> <deployment-plan xmlns=" http://xmlns.oracle.com/weblogic/deployment-plan" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" http://xmlns.oracle.com/weblogic/deployment-plan http://xmlns.oracle.com/weblogic/deployment-plan/1.0/deployment-plan.xsd" global-variables="false"> <application-name>itclaims</application-name> <variable-definition> <variable> <name>Env_databaseURL</name> <value>C:\\dev\\trac-projects\\it-jenty\\db\\trac.db</value> </variable> </variable-definition> <module-override> <module-name>itclaims-trac-0.12.war</module-name> <module-type>war</module-type> <module-descriptor external="false"> <root-element>weblogic-web-app</root-element> <uri>WEB-INF/weblogic.xml</uri> </module-descriptor> <module-descriptor external="false"> <root-element>web-app</root-element> <uri>WEB-INF/web.xml</uri> <variable-assignment> <name>Env_databaseURL</name> <xpath>/web-app/env-entry/[env-entry-name="server/databaseURL"]/env-entry-value</xpath> <operation>replace</operation> </variable-assignment> </module-descriptor> <module-descriptor external="true"> <root-element>wldf-resource</root-element> <uri>META-INF/weblogic-diagnostics.xml</uri> </module-descriptor> </module-override> <config-root>c:\dev\itclaims\plan</config-root> </deployment-plan> Собственно проблема в том что replace на C:\\dev\\trac-projects\\it-jenty\\db\\trac.db не выполняется. Помогите пожалуйста, в чем проблема. ... |
| 27.06.2011, 19:05 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1602208]: |
64ms |
| others: | 239ms |
| total: | 371ms |
