сертификация при помощи uCertify
Нашел программку на http://www.ucertify.com/download/000-731.html. Демо версия показалась толковой. Не посмотрел, что индусы ваяли (а надо было). Решил купить. Дальше смешной обмен письмами авторThank you for shopping at uCertify. Please follow these steps to register and unlock your uCertify product: * If you have not already downloaded and installed the PrepKit(s), please do so now. Download links are at the end of this email. * Run PrepKit from Start >> Programs >> uCertify menu. PrepKit will open in a Demo mode with limited access. * Go to Help >> License Key menu from within the PrepKit. It will open up a “License and Unlock” dialog box. * Fill out your email: mymail@mail.com and order no: WF-XXXXXXXXX * Click on the Update License button. It will download the License information form the uCertify.com website and will register the PrepKit. * You now have access to the full suite Once successfully registered, the dialog box will be automatically close and you will have access to all questions and study notes. If you are having problems, details instructions can be found at http://www.ucertify.com/about/registration.html. Please contact us at support@ucertify.com and reference order number WF-XXXXXXXXX if you need assistance. Good luck with your certification exam! Sincerely, Team uCertify http://www.ucertify.com Learn, Get Certified, Earn More, The uCertify Way. Ключ как вы понимаете не сработал авторHi I've got problem with registration. Screen shoots in attachments. Need fast help because exam on next week авторHello Andrei, Thanks for contacting uCertify. We would like to inform you that the PrepKit for the exam 000-731 is Pre Released as of now and that is the reason why it is not allowing you to register the product for the full version. Our technical team is working on that PrepKit and hope it will be released by tommorow. After that It will allow you to register the product with the help of the License Key provided. We will inform you with the top priority when it will be released. Regards, uCertify Team, www.ucertify.com вобщем накрылись мои 40 американских рублей поскольку "tommorow" явно затянулось. Что тут скажешь - будьте бдительны, не покупайте китайскую лапшу и индийские программы ... |
| 21.10.2009, 16:52 |
oldkeyboНашел программку на http://www.ucertify.com/download/000-731.html. ИБМовского теста должно было хватить на ура http://www-03.ibm.com/certify/tests/sam731.shtml да и стоит только $10 ;) offtop: oldkeybo вобщем накрылись мои 40 американских рублей поскольку "tommorow" явно затянулось. Что тут скажешь - будьте бдительны, не покупайте китайскую лапшу и индийские программы если платили кредиткой или типа через пейпал (и т.д.) вопрос легко решается, просто надо позвонить в свой банк... ... |
| 21.10.2009, 19:14 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601868]: |
71ms |
47ms |
| others: | 246ms |
| total: | 422ms |
