создать триггер.
create trigger trigger_name after update on table_name referencing new as n old as o for each row mode db2sql when (o.column1 <> n.column1 or o.column2 <> n.column2 ) begin atomic if o.column1 + o.column1 > n.column2 + n.column2 then set n.column1=o.column1; set n.column2=o.column2; end if; end @ Здесь что неправильно? Помогите решить этот вопрос. ... |
| 11.09.2012, 13:34 |
создать триггер.
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. The following rules apply to the REFERENCING clause: A NEW transition variable can only be the target of an assignment in a BEFORE trigger. Otherwise, transition variables cannot be the target of an assignment (SQLSTATE 42703 or 42987). ... |
| 11.09.2012, 14:04 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601721]: |
38ms |
37ms |
| others: | 206ms |
| total: | 323ms |
