не стартует apply
ситуация: на сервере под управлением AIX (5.3 tl8) неожиданно перестала корректно работать репликация в БД IBM DB2 8.2 FP12, на сервере определен один Capture и пять Apply. у всех Apply параметры запуска одинаковые, но три из пяти не запускаются с одной и той же ошибкой. вот лог запуска Apply: автор# cat db2inst2.ABONCRK.ORDWIRE.APP.log 2008-09-23-08.36.02.245678 <setEnvDprRIB> ASN8003D "Apply" : "" : "Initial" : Program "apply 8.2.5" is starting. 2008-09-23-08.36.04.369739 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "CONTROL_SERVER" was set to "ABONCRK" at startup by the following method: "COMMANDLINE". 2008-09-23-08.36.04.370333 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "APPLY_QUAL" was set to "ORDWIRE" at startup by the following method: "COMMANDLINE". 2008-09-23-08.36.04.370367 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "LOGREUSE" was set to "Y" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370404 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "LOGSTDOUT" was set to "N" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370435 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "TERM" was set to "N" at startup by the following method: "COMMANDLINE". 2008-09-23-08.36.04.370466 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "PWDFILE" was set to "asnpwd.aut" at startup by the following method: "DEFAULT". 2008-09-23-08.36.04.370499 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "APPLY_PATH" was set to "/aboncrk/asn/" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370530 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "DIAGLOG" was set to "Y" at startup by the following method: "DEFAULT". 2008-09-23-08.36.04.370561 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "NOTIFY" was set to "N" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370591 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "SLEEP" was set to "N" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370622 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "ERRWAIT" was set to "300" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370653 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "COPYONCE" was set to "N" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370683 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "TRLREUSE" was set to "Y" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370720 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "SPILLFILE" was set to "DISK" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370750 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "LOADXIT" was set to "N" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370781 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "SQLERRCONTINUE" was set to "Y" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370811 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "OPT4ONE" was set to "N" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370842 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "DELAY" was set to "6" at startup by the following method: "IBMSNAP_APPPARMS". 2008-09-23-08.36.04.370873 <asnParmClass::printParms> ASN0529I "Apply" : "ORDWIRE" : "Initial" : The value of "INAMSG" was set to "N" at startup by the following method: "COMMANDLINE". 2008-09-23-08.36.04.396347 <Asnenv:setEnvIpcQRcvHdl> ASN0592I "Apply" : "ORDWIRE" : "Initial" The program attached to the IPC queue with keys "(0x30000065)". 2008-09-23-08.36.04.396421 <Asnenv:setEnvIpcQRcvHdl> ASN0596I "Apply" : "ORDWIRE" : "Initial" The program could not create an IPC queue with keys "(0x30000065)" for path "/tmp/db2inst2.ABONCRK.ORDWIRE.APP.IPC". OSSE reason is "Access denied". 2008-09-23-08.36.04.396446 <Asnenv:setEnvIpcQRcvHdl> ASN0589I "Apply" : "ORDWIRE" : "Initial" The program received an unexpected return code "-1879048191" from routine "OSSHIPCQueue:create". 2008-09-23-08.36.04.396468 <Asnenv:setEnvIpcQRcvHdl> ASN0507E "Apply" : "ORDWIRE" : "Initial" : The program could not create the replication communications message queue. 2008-09-23-08.36.04.396571 <asnThread::stop> ASN0590I "Apply" : "ORDWIRE" : "Initial" The thread "Initial" received return code "0" from the exiting thread "HoldLThread". 2008-09-23-08.36.04.396656 <erWhatSignal> ASN0591I "Apply" : "ORDWIRE" : "HoldLThread" The thread "HoldLThread" received "Handled" signal "SIGUSR2". 2008-09-23-08.36.05.397632 <_asnApply> ASN1097I APPLY "ORDWIRE" : "Initial". The Apply program stopped. Пробовали: 1. удалять временные файлы из каталога tmp (db2inst2.ABONCRK.ORDWIRE.APP.IPC) 2. пробовали удалять файл с идентификатором процесса Apply в каталоге /sqllib/dpropr 3. пробовали менять параметры запуска Apply в центре репликации 4. пытались запускать Apply из TaskCenter и центра репликации ничего из вышеперечисленного не помогло решить нашу проблему. люди добрые подскажите что еще можно попробовать сделать, чтобы запустить Apply ... |
| 23.09.2008, 08:55 |
не стартует apply
Все, спасибо. Разобрались. Дело в том, что админ, который делал Apply, уволился и они от него запускались. Переделали,чтобы запускались от другого админа db2, все ок. ... |
| 23.09.2008, 09:42 |
не стартует apply
Привет Марк. Уже сделали. Я это читал. Сделали с помощью этого http://publib.boulder.ibm.com/infocenter/db2luw/v9r5/index.jsp?topic=/com.ibm.db2.luw.messages.asn.doc/doc/masn00596i.html. Тем более наша система умирает. Недолго мучится ей осталось. ... |
| 23.09.2008, 11:06 |
не стартует apply
Не стартует asncap на одной из баз. ASN0543E Похоже на: PK70664: MSGASN0543E REPORTS A NEGATIVE STORAGE AMOUNT http://www-01.ibm.com/support/docview.wss?uid=swg1PK70664 Есть ли более развернутое описание вот этой рекомендации: автор**************************************************************** * RECOMMENDATION: * **************************************************************** 1- Decoder must not decode no-data DROP TABLE log records causing ASN0543E negative storage amount message to occur ... |
| 11.01.2013, 17:01 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601568]: |
83ms |
66ms |
| others: | 253ms |
| total: | 492ms |
