10.5 Express-C - новые лимиты
http://www-01.ibm.com/common/ssi/cgi-bin/ssialias?infotype=an&subtype=ca&appname=gpateam&supplier=897&letternum=ENUS213-210#h2-chargex BM DB2 Community Edition IBM DB2 Express-C Edition for Linux and Windows 10.5 DB2 10.5 Express-C is a no-charge, entry-level edition of the DB2 data server for the developer and partner community. It is designed to be up and running in minutes, and easy to use and embed. It includes self-management features, and embodies all of the core capabilities of DB2 for Linux , UNIX , and Windows such as Time Travel Query. One notable difference between DB2 Express-C and the production editions of DB2 for Linux , UNIX , and Windows is that you can't cluster together servers for the purposes of high availability. Solutions developed using DB2 Express-C can be seamlessly deployed using more scalable DB2 editions without modifications to the application code. Program charges: DB2 10.5 Express-C can be used for development and deployment at no charge. It can be installed on x64-based physical or virtual systems and may use up to a maximum of 2 processor cores and 16 GB of memory with no more than 15 terabytes of user data per database. DB2 Express-C comes with online community-based assistance. Users requiring more formal support, access to fix packs, or additional capabilities such as high availability, Homogeneous Federation, and replication can purchase an optional yearly subscription for DB2 Express Server Edition (Fixed Term License) or upgrade to other DB2 editions. In addition, IBM Data Studio is also available to facilitate solutions deployment and management. ... |
| 07.05.2013, 15:54 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. 85. 86. 87. 88. 89. 90. 91. 92. 93. 94. 95. 96. 97. 98. 99. 100. 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. 112. 113. 114. 115. 116. 117. 118. 119. 120. 121. 122. 123. 124. 125. 126. 127. 128. 129. 130. 131. 132. 133. 134. 135. 136. 137. 138. 139. 140. 141. 142. 143. 144. 145. 146. 147. 148. 149. 150. 151. 152. 153. 154. 155. 156. 157. 158. 159. 160. 161. 162. 163. 164. 165. 166. 167. 168. ... |
| 07.05.2013, 15:55 |
хотя на http://www-01.ibm.com/common/ssi/cgi-bin/ssialias?infotype=AN&subtype=CA&htmlfid=897/ENUS213-254&appname=USN#h2-availx написано Software Announcement 213-210, dated April 23, 2013 , contains the incorrect planned availability dates. The correct planned availability dates are: June 14, 2013: Electronic availability July 26, 2013: Media availability , я вижу "10.5" на http://www-01.ibm.com/software/data/db2/express-c/download.html ... |
| 15.05.2013, 12:47 |
Но выдаёт "500 Internal Server Error" пока. ... |
| 15.05.2013, 12:49 |
Короче, по-видимому, поторопились граждане, месяца эдак на два (месяц до платных, плюс обычно Express-C задерживается на месяц после платных). ... |
| 15.05.2013, 14:08 |
Вот и триалки подоспели наконец-то https://www14.software.ibm.com/webapp/iwm/web/reg/download.do?source=swg-dm-db2trial&S_TACT=109HF12W&lang=en_US&S_PKG=ov12916&cp=UTF-8 ... |
| 14.06.2013, 19:45 |
mitekВот и триалки подоспели наконец-то https://www14.software.ibm.com/webapp/iwm/web/reg/download.do?source=swg-dm-db2trial&S_TACT=109HF12W&lang=en_US&S_PKG=ov12916&cp=UTF-8 У меня в "консерватории" чего-то не так или все триалки (AIX, Linux) битые (CRC error при распаковке) ? Cкачивал раз 10 с разных машин разными качалками и через http и через директора. WTF ? ... |
| 15.06.2013, 13:12 |
Вот этот пакет у меня распаковалась нормально: v10.5_nt32_server_t.zip. Распаковывал под Ubuntu /w archive manager. Остальное не пробовал... $ unzip -t v10.5_nt32_server_t.zip No errors detected in compressed data of v10.5_nt32_server_t.zip. ... |
| 15.06.2013, 15:34 |
Hunterik, Да, nt32 распаковывается нормально. С никсовыми косяк. ... |
| 15.06.2013, 16:15 |
Yep... =) $ gunzip -t v10.5_linuxia32_server_t.tar.gz gzip: v10.5_linuxia32_server_t.tar.gz: invalid compressed data--format violated ... |
| 15.06.2013, 17:00 |
Ну, в этом IBM-еры не удивили - далеко не первый раз выкладывают битые инсталляхи. Express-C x96_64 для Линуха рабочая - только что поставил и посмотрел более всего интересующие моменты. Серверы для Линуха и Соляриса x86_64 битые. А вот warehouse component ( https://www14.software.ibm.com/webapp/iwm/web/preLogin.do?source=swg-dm-db2trial ) для Линуха x86_64 живой, а там в комплекте собственно сервер (с непонятной лицензией) и куча всякого другого софта. ... |
| 15.06.2013, 18:24 |
Триальные дистрибутивы починили. По крайней мере, вот эти архивы не битые: Код: plaintext 1. 2. 3. С дистрибутива для linuxx64 я успешно установил DB2 в виртуалку и создал там базу SAMPLE. ... |
| 18.06.2013, 10:35 |
Mark BarinsteinТриальные дистрибутивы починили. AIX - полет нормальный. Поставилось аккурат на OS minimum 6100-06-05 :) ... |
| 18.06.2013, 13:20 |
Смотрю, http://pic.dhe.ibm.com/infocenter/db2luw/v10r1/ работает, а http://pic.dhe.ibm.com/infocenter/db2luw/v10r5/ перестало. Далее выяснилось, что в IE работает, а в FF нет. Потом выяснилось, что старом FF работает, в новом нет. Потом - что работает на другом новом FF (на другой машине). Окончательно: ibm.com насовал FF много кук и сайт http://pic.dhe.ibm.com/infocenter/db2luw/v10r5/ не в силах их переварить. Результат - NetworkError: 413 FULL head. Чистка кук помогла. ... |
| 19.06.2013, 19:45 |
Ошибку увидел через FireBug, а так просто пустая страница выдавалась. ... |
| 19.06.2013, 19:47 |
Victor Metelitsa, Ага, это частая трабла. Если зайти через FF в FixCentral, чего-то скачать, а потом попробовать почитать документацию, то скорее всего получишь именно такую ошибку. Очистка Cookies и помогает. ... |
| 19.06.2013, 21:49 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601412]: |
40ms |
58ms |
| others: | 298ms |
| total: | 437ms |
