Ошибки при сборе статистики в DB2.
db2 9.7.4 Провожу ежевечернее обслуживание по реорганизации и сбору статистике и на некоторых таблицах получаю сообщение об ошибке. RUNSTATS ON TABLE CS.KORRLOG ON ALL COLUMNS ALLOW READ ACCESS SQL2314W Некоторые из статистик находятся в несовместимом состоянии. Вновь собранные статистики для "TABLE" несовместимы с существующими статистиками для "INDEX". SQLSTATE=01650 Что с этим делать? ... |
| 09.07.2013, 17:08 |
GuzyaRUNSTATS ON TABLE CS.KORRLOG ON ALL COLUMNS ALLOW READ ACCESS SQL2314W Некоторые из статистик находятся в несовместимом состоянии. Вновь собранные статистики для "TABLE" несовместимы с существующими статистиками для "INDEX". SQLSTATE=01650 Что с этим делать? db2 ? SQL2314D:\>db2 ? SQL2314W SQL2314W Some statistics are in an inconsistent state. The newly collected "<object1>" statistics are inconsistent with the existing "<object2>" statistics. Explanation: The query optimizer uses statistics to determine the best access plan for a query. When inconsistent statistics are present, the optimizer performs access plan evaluation with information that is less accurate then if a consistent set of statistics was available. This might result in an access plan that is not optimal. Possible causes of this warning include the following. 1. Issuing RUNSTATS on the table only may result in a situation where the table level statistics are inconsistent with the already existing index level statistics. Likewise, issuing RUNSTATS for indexes only or during index creation may leave table level statistics in an inconsistent state. For example, if index level statistics are collected on a particular table and later a significant number of rows is deleted from this table, issuing RUNSTATS on the table only may end up with the table cardinality less than FIRSTKEYCARD which is an inconsistent state. 2. If a RUNSTATS is issued with the ALLOW WRITE ACCESS option when many inserts, updates, or deletes are occurring concurrently, then inconsistencies may occur because of table changes between the time that table and index statistics are collected. 3. If a RUNSTATS is issued with the TABLESAMPLE option, then an excessively low sample size may cause statistics to be inaccurately extrapolated, resulting in inconsistencies. The chance of inaccurate extrapolation is higher for SYSTEM sampling than for BERNOULLI sampling. User response: Address the cause of the inconsistency and then collect statistics again to resolve the inconsistency. 1. Issue a RUNSTATS to collect both table level and index level statistics. 2. Collect statistics when inserts, updates, and deletes are minimal or not occurring at all. Or, if concurrent inserts, updates, and deletes are not essential, issue a RUNSTATS with the ALLOW READ ACCESS option. 3. Increase the sample size, or, if RUNSTATS was issued with TABLESAMPLE SYSTEM, use the TABLESAMPLE BERNOULLI option instead. sqlcode: 2314 sqlstate: 01650 ... |
| 09.07.2013, 17:14 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601396]: |
40ms |
| others: | 223ms |
| total: | 319ms |
