powered by simpleCommunicator - 2.0.60     © 2026 Programmizd 02
Форумы / IBM DB2, WebSphere, IMS, U2 [игнор отключен] [закрыт для гостей] / Помогите нубу!!!
6 сообщений из 6, страница 1 из 1
Помогите нубу!!!
    #37750585
vadipok
Возникает такая ошибка. Все перепробовал ничего не помогает. Что делать?
Output from transformer compilation follows:
##I IIS-DSEE-TFCN-00001 16:28:21(000) <main_program>
IBM WebSphere DataStage Enterprise Edition 8.5.0.5746
Copyright (c) 2001, 2005-2008 IBM Corporation. All rights reserved
##I IIS-DSEE-TFCN-00006 16:28:21(001) <main_program> conductor uname: -s=Windows_NT; -r=2; -v=5; -n=SERVER-VADIM; -m=Pentium
##I IIS-DSEE-TOSH-00002 16:28:21(002) <main_program> orchgeneral: loaded
##I IIS-DSEE-TOSH-00002 16:28:21(003) <main_program> orchsort: loaded
##I IIS-DSEE-TOSH-00002 16:28:21(004) <main_program> orchstats: loaded
##W IIS-DSEE-TOSH-00049 16:28:21(007) <main_program> Parameter specified but not used in flow: DSPXWorkingDir
##E IIS-DSEE-TBLD-00076 16:28:21(009) <main_program> Error when checking composite operator: Subprocess command failed with exit status 256.
##E IIS-DSEE-TFSR-00019 16:28:21(010) <main_program> Could not check all operators because of previous error(s)
##W IIS-DSEE-TFTM-00012 16:28:21(011) <transform> Error when checking composite operator: The number of reject datasets "0" is less than the number of input datasets "1".
##W IIS-DSEE-TFEV-00023 16:28:21(012) <transform> Error when checking composite operator: Implicit conversion from source type "String" to result type "UString".
##W IIS-DSEE-TFEV-00023 16:28:21(013) <transform> Error when checking composite operator: Implicit conversion from source type "String" to result type "UString".
##W IIS-DSEE-TFEV-00023 16:28:21(014) <transform> Error when checking composite operator: Implicit conversion from source type "String" to result type "UString".
##I IIS-DSEE-TBLD-00079 16:28:21(015) <transform> Error when checking composite operator: cxx -O -IC:/IBM/InformationServer/Server/PXEngine/include -W/TP -W/EHa -DAPT_USE_ANSI_IOSTREAMS -c -W/Zc:wchar_t- C:/IBM/InformationServer/Server/Projects/Tutorial/RT_BP7.O/V0S32_db2_load_xml_Transformer_32.C -o C:/IBM/InformationServer/Server/Projects/Tutorial/RT_BP7.O/V0S32_db2_load_xml_Transformer_32.tmp.o.
##I IIS-DSEE-TBLD-00000 16:28:21(016) <main_program> Error when checking composite operator: Output from subprocess: Compiler "cl" not found.
##E IIS-DSEE-TCOS-00029 16:28:21(017) <main_program> Creation of a step finished with status = FAILED. (db2_load_xml.Transformer_32)
*** Internal Generated Transformer Code follows:
0001: //
0002: // Generated file to implement the V0S32_db2_load_xml_Transformer_32 transform operator.
0003: //
0004:
0005: // define our input/output link names
0006: inputname 0 DSLink33;
0007: outputname 0 DSLink36;
0008:
0009: initialize {
0010: // define our control variables
0011: int8 RowRejected0;
0012: int8 NullSetVar0;
0013:
0014: }
0015:
0016: mainloop {
0017:
0018: // initialise the rejected row variable
0019: RowRejected0 = 1;
0020:
0021: // evaluate constraint and columns for link: DSLink36
0022: if ((1 == 1))
0023: {
0024: DSLink36.FIRST_NAME = DSLink33.FIRST_NAME;
0025: DSLink36.LAST_NAME = DSLink33.LAST_NAME;
0026: DSLink36.EMAIL = DSLink33.EMAIL;
0027: writerecord 0;
0028: RowRejected0 = 0;
0029: }
0030: }
0031:
0032: finish {
0033: }
0034:
*** End of Internal Generated Transformer Code
Помогите нубу!!!
    #37751181
Фотография Hunterik
Вечер добрый.
Версия ОС и битность?
Какой компилятор установлен и в каком порядке ставили ( компилятор-> DS / DS -> компилятор )?
Помогите нубу!!!
    #37760365
vadipok
Hunterik,
Спасибо большое! Сами справились. Нужен был Visual Studio. Поставили и заработало.
Помогите нубу!!!
    #38338274
_Marisha_
vadipok, а какую версию студии вы ставили?
Я установила VS 2010, отредактировала переменные в среде окружения
LIB - C:\Program Files\Microsoft SDKs\Windows\v6.0A\Lib
INCLUDE - C:\Program Files\Microsoft SDKs\Windows\v6.0A\Include
PATH - C:\program files (x86)\microsoft visual studio 9.0\vc
У меня все равно та же ошибка, что и у вас. Может быть, вы знаете, в чем еще может быть дело? Помогите пожалуйста!!!
##I IIS-DSEE-TFCN-00001 15:35:10(000) <main_program>
##I IIS-DSEE-TFCN-00006 15:35:10(001) <main_program> conductor uname: -s=Windows_NT; -r=1; -v=6; -n=WIN-6UT996V4RHF; -m=Pentium
##I IIS-DSEE-TOSH-00002 15:35:10(002) <main_program> orchgeneral: loaded
##I IIS-DSEE-TOSH-00002 15:35:11(000) <main_program> orchsort: loaded
##I IIS-DSEE-TOSH-00002 15:35:11(001) <main_program> orchstats: loaded
##W IIS-DSEE-TOSH-00049 15:35:12(000) <main_program> Parameter specified but not used in flow: DSPXWorkingDir
##E IIS-DSEE-TBLD-00076 15:35:16(000) <main_program> Error when checking composite operator: Subprocess command failed with exit status 256.
##E IIS-DSEE-TFSR-00019 15:35:16(001) <main_program> Could not check all operators because of previous error(s)
##W IIS-DSEE-TFTM-00012 15:35:16(002) <transform> Error when checking composite operator: The number of reject datasets "0" is less than the number of input datasets "1".
##I IIS-DSEE-TBLD-00079 15:35:16(003) <transform> Error when checking composite operator: cxx -O -IC:/IBM/InformationServer/Server/PXEngine/include -W/TP -W/EHa -DAPT_USE_ANSI_IOSTREAMS -c -W/Zc:wchar_t- C:/IBM/InformationServer/Server/Projects/MyProject/RT_BP1.O/V0S2_EVA_Result_Transformer_2.C -o C:/IBM/InformationServer/Server/Projects/MyProject/RT_BP1.O/V0S2_EVA_Result_Transformer_2.tmp.o.
##I IIS-DSEE-TBLD-00000 15:35:16(004) <main_program> Error when checking composite operator: Output from subprocess: Compiler "cl" not found.
##E IIS-DSEE-TCOS-00029 15:35:16(005) <main_program> Creation of a step finished with status = FAILED. (EVA_Result.Transformer_2)
0001: //
0002: // Generated file to implement the V0S2_EVA_Result_Transformer_2 transform operator.
0003: //
0004:
0006: inputname 0 DSLink3;
0007: outputname 0 DSLink4;
0008:
0009: initialize {
0013:
0014: }
0015:
0016: mainloop {
0017:
0020:
0021: // evaluate columns (no constraints) for link: DSLink4
0022: DSLink4.RESULT_CLASS_ID = DSLink3.ID;
0023: DSLink4.Ratingclass = DSLink3.TR_TRANSLATION;
0024: writerecord 0;
0025: RowRejected0 = 0;
0026: }
0027:
0028: finish {
0029: }
0030:
Помогите нубу!!!
    #38338418
Фотография Hunterik
Здравствуйте.
Во-первых, 2010 VC, если верить сайту IBM , не поддерживается версией 8.5, хотя в чём могут быть проблемы я лично не знаю.
Во-вторых, после установки компилятора машину/процессы DataStage перезапускали? А то может про ваши переменные DataStage пока ни сном, ни духом...
В-тертьих, можете попробовать вручную скомпилировать трансформер - что будет?
Окошек под рукою нет, к сожалению, из старых записей попробую помочь (под себя пути поменяйте)...
Код: powershell
1.
2.
3.
4.
5.
SET VSTOOLS="C:\Program Files\Microsoft Visual Studio 8\Common7\Tools"
call %VSTOOLS%\vsvars32.bat
SET WIN32VC=1
SET SYSTEMROOT=C:\WINDOWS
"C:\Program Files\MKS Toolkit"\mksnt\cxx ... (см. строку в сообщении об ошибке)
Кроме того, существуют проблемы с переменной Home на Windows, описанные здесь .
Компилятор на Windows - то всегда рулетка, особенно, если ставишь его после DataStage. =)
Я обычно ставил какой-нибудь VC Express подходящей версии, потом ставил SDK в custom режиме, чтобы указать Set Environment Variables, затем DataStage - сбоев не было. =) Но это было давно, когда ещё был 8.1, тогда я понял, что Windows для DataStage - платформа не очень... Особенно при больших нагрузках. Ситуацию исправили начиная с версии 8.7, а в 9.1, насколько мне известно, вообще поменяли модель взаимодействия DataStage и Windows - убрали MKS Toolkit из под движка, оставив только для совместимости и работы UNIX-команд на платформе Windows...
А вот 8.5, если честно - ни туда, ни сюда... =)
Ещё не 8.7, но уже не 8.1...
Помогите нубу!!!
    #38339337
_Marisha_
Hunterik, спасибо за ваш ответ!!!
В моем случае снесла VS2010, поставила 2008. Еще повозилась немного с переменными LIB и INCLUDE.
Jobы начали компилироваться. Идем дальше :)
