как добавить BPM к WAS
CWMCF8504E: Creating a IBM BPM stand-alone server profile is not supported in a BPM Advanced installation. не могу создать бизнес процес сервер под linux ./manageprofiles.sh -create -profileName AppSrv008 -profilePath /tmp/SS -templatePath /opt/IBM/WebSphere/AppServer/profileTemplates/default -nodeName server2 -hostName szci -startingPort 6048 -augment -templatePath /opt/IBM/WebSphere/AppServer/profileTemplates/BPM/BpmServer The following validation errors were present with the command line arguments: adminPassword: adminPassword cannot be empty. profileName: CWMCF8504E: Creating a IBM BPM stand-alone server profile is not supported in a BPM Advanced installation. profileName: CWMCF8501E: Parameter enableAdminSecurity must be set to 'true' but was found to be 'AppSrv008'. enableAdminSecurity: CWMCB0051E: An error occurred while reading the profile registry for AppSrv008. adminUserName: adminUserName cannot be empty. profilePath: More than one mode cannot be specified. ... |
| 23.10.2013, 12:42 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601294]: |
81ms |
47ms |
| others: | 255ms |
| total: | 446ms |
