DB2 Advanced Copy Services & DB2 Linux, Unix and Windows HADR Simulator use case
FYI ... DB2 Linux, Unix and Windows HADR Simulator use case and troubleshooting guide: Although DB2 high availability disaster recovery (HADR) is billed as a feature that's easy to set up, customers often have problems picking the right settings for their environment. This Developer works article is a use case, and it shows how you can use the HADR simulator tool to configure and troubleshoot your HADR configuration in a real-world scenario. http://www.ibm.com/developerworks/data/library/techarticle/dm-1310db2luwhadr/ DB2 Advanced Copy Services: DB2 Advanced Copy Services (DB2 ACS) , available in DB2 10.5 makes it possible for customers to implement shell scripts instead of C-libraries. The feature supports all three architectures of DB2: enterprise server, multipartitioned databases using the database partitioning feature (DPF), and databases using pureScale. This Developerworks article is the first part of a series which provides an introduction to this feature and presents some real-life examples. http://www.ibm.com/developerworks/data/library/techarticle/dm-1308scriptdb2copy/ Kind regards, Vadim. ... |
| 11.03.2014, 12:16 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601145]: |
38ms |
31ms |
| others: | 265ms |
| total: | 386ms |
