Проверяем базы данных на уязвимость - Guardium Vulnerability Assessment Evaluation Edition
FYI ... Проверяем базы данных на уязвимость - Guardium Vulnerability Assessment Evaluation Edition ---- IBM® InfoSphere® Guardium® Vulnerability Assessment Evaluation Edition provides users with an opportunity to preview and evaluate the IBM® InfoSphere® Guardium® Vulnerability Assessment solution using a subset of the full functionality. This free download is enabled for up to 10 data sources and includes a limited version of Guardium Vulnerability Analysis that will enable you to do: 1. Sensitive Data Discovery - Identify sensitive information like credit card numbers and transactions, or personal financial data - Produce a report with sensitive objects for each inspected server 2.= Vulnerability Assessment - - Run predefined tests designed to illustrate common database vulnerability issues. - Produce a Vulnerability Assessment report with a scorecard, and basic results Guardium Vulnerability Assessment Evaluation Edition - https://www14.software.ibm.com/webapp/iwm/web/preLogin.do?source=swg-guardiumva-eval DeveloperWorks - http://www.ibm.com/developerworks/downloads/im/guardiumva/ --- Суважением, Вадим. ... |
| 14.04.2014, 19:49:05 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1601106]: |
| others: | 195ms |
| total: | 268ms |
