Register now for the Tech Talk on November 20, 2014: at's New in DB2 10.5 'Cancun Release'
FYI ... Learn about DB2's new capabilities for transaction and analytic processing from the product architects DB2's most recent release added significant new capabilities for both transaction and analytic processing. This presentation will take you through the new features and what you need to know. Attend this DB2 Tech Talk to learn about: - BLU Shadow Tables - Run reports directly in your transactional processing environment; optimize and improve both transactional and - analytic query performance without indexes or aggregates. - Expanded Oracle SQL compatibility for data marts - Easily migrate Oracle data marts to DB2 and continue to leverage Oracle skills without retraining. - Enhanced SAP Business Warehouse support - Extended and simplified data integration with greater compression, high availability and - disaster recovery without hardware or application upgrades. - Standard TCP/IP sockets for pureScale - Use standard TCP/IP sockets for smaller pureScale clusters or lower volume transaction applications. - Additional capabilities for high availability, disaster recovery, minimizing backup windows, and more. Register now for the Tech Talk on November 20, 2014: at's New in DB2 10.5 'Cancun Release' http://bit.ly/tt2014nov Kind regards, Vadim. ... |
| 10.11.2014, 11:13:55 |
[quot GVF112GVF] - Expanded Oracle SQL compatibility for data marts - Easily migrate Oracle data marts to DB2 and continue to leverage Oracle skills without retraining./quot] Что они имеют в виду (именно в 10.5 fp4, а не что было раньше)? Я немного погуглил, но ничего внятного не нашёл. ... |
| 10.11.2014, 15:57:35 |
Victor Metelitsa, До 10.5 fp 4 вы не могли выставить одновременно DB2_WORKLOAD=ANALYTICS и DB2_COMPATIBILITY_VECTOR=ORA, то есть были ограничения на использование функций совместимости с Oracle и BLU. ... |
| 10.11.2014, 21:10:00 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1600951]: |
183ms |
36ms |
| others: | 192ms |
| total: | 456ms |
