DB2 Version 10.5 Fix Pack 5 for Linux, UNIX, and Windows
FYI ... DB2 Version 10.5 Fix Pack 5 for Linux, UNIX, and Windows - http://www-01.ibm.com/support/docview.wss?uid=swg24038828 Kind regards, Vadim. ... |
| 22.12.2014, 17:13:40 |
GVF112GVFFYI ... DB2 Version 10.5 Fix Pack 5 for Linux, UNIX, and Windows - http://www-01.ibm.com/support/docview.wss?uid=swg24038828 Kind regards, Vadim. In DB2 10.5 FP5, DB2 adds support for encrypting data in storage. This is the built-in DB2 native encryption capability. DB2 native encryption uses a symmetric encryption scheme for both the database and the backup images. A DB2 Native Encryption Primer - http://www.ibmbluhub.com/walid-encryption-primer/ Kind regards, Vadim. ... |
| 22.01.2015, 00:07:57 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1600906]: |
44ms |
28ms |
| others: | 185ms |
| total: | 297ms |
