SQL2563W
Выручите советом? не могу восстановить базу. db2 =>RESTORE DATABASE BASE FROM '/mnt/backup/' TAKEN AT 20140310100010 INTO BASE REPLACE EXISTING SQL2539W Warning! Restoring to an existing database that is the same as the backup image database. The database files will be deleted. SQL2563W The restore process has completed successfully, but one or more table spaces from the backup were not restored. db2 => У бекапа : storage path: /opt/IBM/base/sys4 Name: /opt/IBM/base/sys4/db2inst3/ в реальности пути другие на сервере где восстанавливаю. storage path: /opt/IBM/base/sys2 Name: /opt/IBM/base/sys2/db2inst1/ как указать иной путь для восстановления? Спасибо. ... |
| 26.01.2015, 18:03:05 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1600902]: |
179ms |
30ms |
| others: | 187ms |
| total: | 428ms |
