RESTORE DATABASE ... или невероятные приключения DB2
при попытке сделать restore под конец процедуры падает со следующим. посоветуйте что можно сделать? AIX Product name: "DB2 Enterprise Server Edition" Product identifier: "db2ese" Version information: "9.7" $ db2 get db cfg SQL1024N A database connection does not exist. SQLSTATE=08003 $ db2 connect to DATA SQL1117N A connection to or activation of database "DATA" cannot be made because of ROLL-FORWARD PENDING. SQLSTATE=57019 MESSAGE : ZRC=0x8B0F0000=-1961951232=SQLO_NOMEM "No Memory Available" DIA8300C A memory heap error has occurred. DATA #1 : String, 60 bytes Insufficient instance_memory to allocate new memory consumer DATA #2 : String, 11 bytes DB-CMD DATA #3 : Requested size, PD_TYPE_MEM_REQUESTED_SIZE, 8 bytes 63997083648 DATA #4 : Current instance_memory consumption in bytes, PD_TYPE_MEM_INSTANCE_CUR, 8 bytes 312410112 DATA #5 : Maximum allowed instance_memory in bytes, PD_TYPE_MEM_INSTANCE_MAX, 8 bytes 17179869184 FUNCTION: DB2 UDB, SQO Memory Management, sqlogmshr, probe:149 MESSAGE : ZRC=0x850F0005=-2062614523=SQLO_NOSEG "No Storage Available for allocation" DIA8305C Memory allocation failure occurred. DATA #1 : String, 8 bytes CMD DATA #2 : String, 56 bytes Insufficient INSTANCE_MEMORY to allocate new memory set. DATA #3 : numChunks, PD_TYPE_NUM_CHUNKS, 4 bytes 976518 FUNCTION: DB2 UDB, base sys utilities, sqeLocalDatabase::FirstConnect, probe:100 MESSAGE : ZRC=0x850F0005=-2062614523=SQLO_NOSEG "No Storage Available for allocation" DIA8305C Memory allocation failure occurred. DATA #1 : String, 299 bytes Failed to allocate the desired database shared memory set. The configured DATABASE_MEMORY plus desired overflow may have exceeded INSTANCE_MEMORY or the maximum shared memory on the system. Attempting to start up with a smaller overflow allowance. Desired database shared memory set size is (bytes): DATA #2 : unsigned integer, 8 bytes 63997083648 FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::requestMemory, probe:50 MESSAGE : ZRC=0x8B0F0000=-1961951232=SQLO_NOMEM "No Memory Available" DIA8300C A memory heap error has occurred. DATA #1 : String, 28 bytes Attempt to get memory failed DATA #2 : unsigned integer, 8 bytes 55997497344 DATA #3 : unsigned integer, 8 bytes 0 DATA #4 : String, 11 bytes DB-CMD DATA #5 : unsigned integer, 8 bytes 0 DATA #6 : unsigned integer, 8 bytes 0 DATA #7 : unsigned integer, 8 bytes 312410112 DATA #8 : unsigned integer, 8 bytes 17179869184 DATA #9 : unsigned integer, 8 bytes 208601088 FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::getPartitionStats, probe:10 DATA #1 : <preformatted> Instance Memory Controller statistics. Instance Memory Automatic: No. Maximum size = 16777216 KB Current size = 305088 KB Usage HWM = 14919104 KB Cached memory = 203712 KB Cached DB memory = 0 KB FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::getPartitionStats, probe:11 DATA #1 : <preformatted> APPL-CMD - Current size : 160000 KB, HWM : 160000 KB, Reserved : 159872 KB FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::getPartitionStats, probe:12 DATA #1 : <preformatted> DBMS-db2inst2 - Current size : 102784 KB, HWM : 102784 KB, Reserved : 34944 KB FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::getPartitionStats, probe:13 DATA #1 : <preformatted> FMP_RESOURCES - Current size : 22528 KB, HWM : 22528 KB, Reserved : 0 KB FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::getPartitionStats, probe:14 DATA #1 : <preformatted> PRIVATE - Current size : 19648 KB, HWM : 47232 KB, Reserved : 8896 KB FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::getPartitionStats, probe:16 DATA #1 : <preformatted> DB-CMD - Current size : 0 KB, HWM : 0 KB, Reserved : 0 KB FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::getPartitionStats, probe:17 DATA #1 : <preformatted> Aggregated stats for 1 Local Applications Sets Current size : 128 KB HWM : 128 KB Reserved : 0 KB FUNCTION: DB2 UDB, SQO Memory Management, SqloMemController::registerConsumer, probe:1000 MESSAGE : ZRC=0x8B0F0000=-1961951232=SQLO_NOMEM "No Memory Available" DIA8300C A memory heap error has occurred. DATA #1 : String, 60 bytes Insufficient instance_memory to allocate new memory consumer DATA #2 : String, 11 bytes DB-CMD DATA #3 : Requested size, PD_TYPE_MEM_REQUESTED_SIZE, 8 bytes 55997497344 DATA #4 : Current instance_memory consumption in bytes, PD_TYPE_MEM_INSTANCE_CUR, 8 bytes 312410112 DATA #5 : Maximum allowed instance_memory in bytes, PD_TYPE_MEM_INSTANCE_MAX, 8 bytes 17179869184 FUNCTION: DB2 UDB, SQO Memory Management, sqlogmshr, probe:149 MESSAGE : ZRC=0x850F0005=-2062614523=SQLO_NOSEG "No Storage Available for allocation" DIA8305C Memory allocation failure occurred. DATA #1 : String, 8 bytes CMD DATA #2 : String, 56 bytes Insufficient INSTANCE_MEMORY to allocate new memory set. DATA #3 : numChunks, PD_TYPE_NUM_CHUNKS, 4 bytes 854454 FUNCTION: DB2 UDB, base sys utilities, sqeLocalDatabase::FirstConnect, probe:110 MESSAGE : ZRC=0x850F0005=-2062614523=SQLO_NOSEG "No Storage Available for allocation" DIA8305C Memory allocation failure occurred. DATA #1 : String, 283 bytes Failed to allocate the database shared memory set. The configured DATABASE_MEMORY plus smaller overflow may have exceeded INSTANCE_MEMORY or the maximum shared memory on the system. Attempting to start up with only the system buffer pools. Database shared memory set size is (bytes): DATA #2 : unsigned integer, 8 bytes 55997448192 FUNCTION: DB2 UDB, base sys utilities, sqeLocalDatabase::FirstConnect, probe:125 DATA #1 : Hexdump, 4 bytes 0x0780000002A858DC : FFFF FBA3 .... FUNCTION: DB2 UDB, base sys utilities, sqeLocalDatabase::TermDbConnect, probe:2000 STOP : DATABASE: CMD : DEACTIVATED: NO Спасибо. ... |
| 27.01.2015, 17:10:33 |
Amiri, Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. Попробуйте урезать буферы, как наиболее возможные самые большие потребители памяти: Код: plaintext 1. 2. 3. ... |
| 27.01.2015, 18:40:33 |
Mark Barinstein, А откуда ему желание такое?) Спасибо. ... |
| 27.01.2015, 18:57:15 |
AmiriА откуда ему желание такое?)Наверное от того, что они такой слишком большой размер имеют для этой вашей новой системы. На той, где архив был взят, скорее всего, памяти гораздо больше, чем на той, где вы хотите восстановиться. ... |
| 27.01.2015, 22:59:14 |
Mark Barinstein, ясно. спасибо за ответ. ... |
| 28.01.2015, 09:51:22 |
Не выходит каменный цветок. ( получаю ошибку! db2 => RESTORE DATABASE SQL2539W Warning! Restoring to an existing database that is the same as the backup image database. The database files will be deleted. Do you want to continue ? (y/n) y SQL2563W The restore process has completed successfully, but one or more table spaces from the backup were not restored. db2 => connect to DATA SQL1117N A connection to or activation of database "DATA" cannot be made because of ROLL-FORWARD PENDING. SQLSTATE=57019 db2 => в логе всего одна ошибка. FUNCTION: DB2 UDB, High Availability Disaster Recovery, hdrSetDbRole, probe:10010 CHANGE : HADR role set to Standard (was Standard) FUNCTION: DB2 UDB, database utilities, sqludBMResponse, probe:678 DATA #1 : Sqlcode, PD_TYPE_SQLCODE, 4 bytes 2563 DATA #2 : Hexdump, 4 bytes 0x07000000436C4868 : 0000 0A03 .... FUNCTION: DB2 UDB, database utilities, sqludBMResponse, probe:678 MESSAGE : SQL2563W The restore process has completed successfully, but one or more table spaces from the backup were not restored. DATA #1 : SQLCA, PD_DB2_TYPE_SQLCA, 136 bytes sqlcaid : SQLCA sqlcabc: 136 sqlcode: 2563 sqlerrml: 0 sqlerrmc: sqlerrp : sqludBMR sqlerrd : (1) 0x00000000 (2) 0x00000000 (3) 0x00000000 (4) 0x00000000 (5) 0x00000000 (6) 0x00000000 sqlwarn : (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) sqlstate: FUNCTION: DB2 UDB, database utilities, sqludrsa, probe:779 MESSAGE : Restore Complete. Подскажите какой таблспейс он не смог восстановить. Спасибо. ... |
| 29.01.2015, 09:14:56 |
Amiri, Скорее всего оно не смогло записать контейнеры табличных по оригинальным путям. На новой системе их нет, либо они недоступны для записи владельцу инстанса, либо в них недостаточно места. Путь, который ей не нравится, должен быть в db2diag.log недалеко после сообщения о начале восстановления. Узнать то, какие пути должны быть доступны можно, сгенерировав скрипт redirected restore. Если сделать такие же пути доступными не получится, можно отредактировать этот скрипт и запустить его на выполнение. Performing a redirected restore using an automatically generated script Кроме того, при восстаноавлении из онлайн-архива, чтобы сделать базу доступной, надо накатиться по журналам по крайней мере до момента окончания архивирования. Необходимые журналы вы можете взять с оригинальной системы или из самого архива. ... |
| 29.01.2015, 10:20:15 |
Mark Barinstein, Да вы правы скорее всего не хватило места для контейнера нашел в логе такое MESSAGE : ADM10502W Health indicator "Table Space Container Operational State" ("tsc.tscont_op_status") is in state "Abnormal" on "table space container" "db2inst1.DB Спасибо. ... |
| 29.01.2015, 10:53:46 |
все прошло удачно, но вот( DB20000I The RESTORE DATABASE command completed successfully. db2 => connect to DATA SQL1084C Shared memory segments cannot be allocated. SQLSTATE=57019 ... |
| 29.01.2015, 15:15:32 |
Свободно всего 500m не получается подключиться к базе( $ db2pd -osinfo Operating System Information: OSName: AIX NodeName: hostname Version: 6 Release: 1 Machine: CPU Information: TotalCPU OnlineCPU ConfigCPU Speed(MHz) HMTDegree Cores/Socket 32 16 32 3300 2 n/a Physical Memory and Swap (Megabytes): TotalMem FreeMem AvailMem TotalSwap FreeSwap 16384 527 n/a 512 459 Virtual Memory (Megabytes): Total Reserved Available Free 16896 n/a n/a 986 Message Queue Information: MsgSeg MsgMax MsgMap MsgMni MsgTql MsgMnb MsgSsz n/a 4194304 n/a n/a n/a 4194304 n/a Shared Memory Information: ShmMax ShmMin ShmIds ShmSeg 68719476736 1 131072 0 Semaphore Information: SemMap SemMni SemMns SemMnu SemMsl SemOpm SemUme SemUsz SemVmx SemAem n/a 131072 n/a n/a 65535 1024 n/a n/a 32767 16384 CPU Load Information: Short Medium Long 1.386337 1.206024 1.345779 CPU Usage Information (percent): Total Usr Sys Wait Idle 4.166667 0.277778 3.750000 0.138889 95.833333 $ db2 get db cfg for CMD Database Configuration for Database DATA Database configuration release level = 0x0d00 Database release level = 0x0d00 Database territory = RU Database code page = 915 Database code set = ISO8859-5 Database country/region code = 7 Database collating sequence = UNIQUE Alternate collating sequence (ALT_COLLATE) = Number compatibility = OFF Varchar2 compatibility = OFF Date compatibility = OFF Database page size = 32768 Dynamic SQL Query management (DYN_QUERY_MGMT) = DISABLE Statement concentrator (STMT_CONC) = OFF Discovery support for this database (DISCOVER_DB) = ENABLE Restrict access = NO Default query optimization class (DFT_QUERYOPT) = 5 Degree of parallelism (DFT_DEGREE) = 1 Continue upon arithmetic exceptions (DFT_SQLMATHWARN) = NO Default refresh age (DFT_REFRESH_AGE) = 0 Default maintained table types for opt (DFT_MTTB_TYPES) = SYSTEM Number of frequent values retained (NUM_FREQVALUES) = 10 Number of quantiles retained (NUM_QUANTILES) = 20 Decimal floating point rounding mode (DECFLT_ROUNDING) = ROUND_HALF_EVEN Backup pending = NO All committed transactions have been written to disk = NO Rollforward pending = DATABASE Restore pending = NO Multi-page file allocation enabled = YES Log retain for recovery status = NO User exit for logging status = YES Self tuning memory (SELF_TUNING_MEM) = ON Size of database shared memory (4KB) (DATABASE_MEMORY) = 10000 Database memory threshold (DB_MEM_THRESH) = 10 Max storage for lock list (4KB) (LOCKLIST) = 458572 Percent. of lock lists per application (MAXLOCKS) = 97 Package cache size (4KB) (PCKCACHESZ) = AUTOMATIC(5216) Sort heap thres for shared sorts (4KB) (SHEAPTHRES_SHR) = 3938372 Sort list heap (4KB) (SORTHEAP) = AUTOMATIC(256) Database heap (4KB) (DBHEAP) = AUTOMATIC(262140) Catalog cache size (4KB) (CATALOGCACHE_SZ) = 10600 Log buffer size (4KB) (LOGBUFSZ) = 256 Utilities heap size (4KB) (UTIL_HEAP_SZ) = 5000 Buffer pool size (pages) (BUFFPAGE) = 1000 SQL statement heap (4KB) (STMTHEAP) = AUTOMATIC(4096) Default application heap (4KB) (APPLHEAPSZ) = AUTOMATIC(256) Application Memory Size (4KB) (APPL_MEMORY) = AUTOMATIC(40000) Statistics heap size (4KB) (STAT_HEAP_SZ) = AUTOMATIC(4384) Interval for checking deadlock (ms) (DLCHKTIME) = 10000 Lock timeout (sec) (LOCKTIMEOUT) = 10800 Changed pages threshold (CHNGPGS_THRESH) = 80 Number of asynchronous page cleaners (NUM_IOCLEANERS) = AUTOMATIC(47) Number of I/O servers (NUM_IOSERVERS) = 8 Index sort flag (INDEXSORT) = YES Sequential detect flag (SEQDETECT) = YES Default prefetch size (pages) (DFT_PREFETCH_SZ) = AUTOMATIC Track modified pages (TRACKMOD) = ON Default number of containers = 1 Default tablespace extentsize (pages) (DFT_EXTENT_SZ) = 32 Max number of active applications (MAXAPPLS) = AUTOMATIC(652) Average number of active applications (AVG_APPLS) = AUTOMATIC(1) Max DB files open per application (MAXFILOP) = 61440 Log file size (4KB) (LOGFILSIZ) = 65535 Number of primary log files (LOGPRIMARY) = 12 Number of secondary log files (LOGSECOND) = -1 Changed path to log files (NEWLOGPATH) = Path to log files = /NODE0000/ Overflow log path (OVERFLOWLOGPATH) = Mirror log path (MIRRORLOGPATH) = First active log file = S0354097.LOG Block log on disk full (BLK_LOG_DSK_FUL) = NO Block non logged operations (BLOCKNONLOGGED) = NO Percent max primary log space by transaction (MAX_LOG) = 0 Num. of active log files for 1 active UOW(NUM_LOG_SPAN) = 200 Group commit count (MINCOMMIT) = 1 Percent log file reclaimed before soft chckpt (SOFTMAX) = 520 Log retain for recovery enabled (LOGRETAIN) = OFF User exit for logging enabled (USEREXIT) = OFF HADR database role = STANDARD HADR local host name (HADR_LOCAL_HOST) = HADR local service name (HADR_LOCAL_SVC) = HADR remote host name (HADR_REMOTE_HOST) = HADR remote service name (HADR_REMOTE_SVC) = HADR instance name of remote server (HADR_REMOTE_INST) = HADR timeout value (HADR_TIMEOUT) = 120 HADR log write synchronization mode (HADR_SYNCMODE) = NEARSYNC HADR peer window duration (seconds) (HADR_PEER_WINDOW) = 0 First log archive method (LOGARCHMETH1) = DISK:/archlog/ Options for logarchmeth1 (LOGARCHOPT1) = Second log archive method (LOGARCHMETH2) = OFF Options for logarchmeth2 (LOGARCHOPT2) = Failover log archive path (FAILARCHPATH) = /fail/ Number of log archive retries on error (NUMARCHRETRY) = 5 Log archive retry Delay (secs) (ARCHRETRYDELAY) = 20 Vendor options (VENDOROPT) = Auto restart enabled (AUTORESTART) = ON Index re-creation time and redo index build (INDEXREC) = SYSTEM (RESTART) Log pages during index build (LOGINDEXBUILD) = OFF Default number of loadrec sessions (DFT_LOADREC_SES) = 1 Number of database backups to retain (NUM_DB_BACKUPS) = 12 Recovery history retention (days) (REC_HIS_RETENTN) = 366 Auto deletion of recovery objects (AUTO_DEL_REC_OBJ) = OFF TSM management class (TSM_MGMTCLASS) = TSM node name (TSM_NODENAME) = TSM owner (TSM_OWNER) = TSM password (TSM_PASSWORD) = Automatic maintenance (AUTO_MAINT) = ON Automatic database backup (AUTO_DB_BACKUP) = OFF Automatic table maintenance (AUTO_TBL_MAINT) = ON Automatic runstats (AUTO_RUNSTATS) = OFF Automatic statement statistics (AUTO_STMT_STATS) = OFF Automatic statistics profiling (AUTO_STATS_PROF) = OFF Automatic profile updates (AUTO_PROF_UPD) = OFF Automatic reorganization (AUTO_REORG) = ON Auto-Revalidation (AUTO_REVAL) = DEFERRED Currently Committed (CUR_COMMIT) = ON CHAR output with DECIMAL input (DEC_TO_CHAR_FMT) = NEW Enable XML Character operations (ENABLE_XMLCHAR) = YES WLM Collection Interval (minutes) (WLM_COLLECT_INT) = 0 Monitor Collect Settings Request metrics (MON_REQ_METRICS) = EXTENDED Activity metrics (MON_ACT_METRICS) = EXTENDED Object metrics (MON_OBJ_METRICS) = BASE Unit of work events (MON_UOW_DATA) = NONE Lock timeout events (MON_LOCKTIMEOUT) = NONE Deadlock events (MON_DEADLOCK) = WITHOUT_HIST Lock wait events (MON_LOCKWAIT) = NONE Lock wait event threshold (MON_LW_THRESH) = 5000000 Number of package list entries (MON_PKGLIST_SZ) = 32 Lock event notification level (MON_LCK_MSG_LVL) = 1 SMTP Server (SMTP_SERVER) = SQL conditional compilation flags (SQL_CCFLAGS) = Section actuals setting (SECTION_ACTUALS) = NONE Что можно сделать? Спасибо. ... |
| 29.01.2015, 15:34:13 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1600899]: |
191ms |
44ms |
| others: | 225ms |
| total: | 497ms |
