Установка DB 9.5 на CentOs 7.3
Здравствуйте! Имеем CentOs 7.3 Хотим установить DB 9.5 После успешного выполнения ./db2_install Выполняем: в файл /etc/services db2c_db2inst1 50000/tcp потом groupadd db2iadm1 groupadd db2fadm1 groupadd dasadm1 useradd -g db2iadm1 -m -d /home/db2inst1 db2inst1 useradd -g db2fadm1 -m -d /home/db2fenc1 db2fenc1 useradd -g dasadm1 -m -d /home/dasusr1 dasusr1 passwd db2inst1 passwd db2fenc1 passwd dasusr1 cd /opt/ibm/db2/V9.5/instance ./db2icrt -u db2fenc1 db2inst1 Получаем ошибку: 017-09-26-15.26.10.253257+180 I2605E387 LEVEL: Error PID : 3196 TID : 139765804808000PROC : db2 INSTANCE: db2inst1 NODE : 000 FUNCTION: DB2 UDB, command line process, clp_start_bp, probe:3 MESSAGE : CLP frontend unable to get REQUEST queue handle DATA #1 : Hexdump, 4 bytes 0x00007FFCB730B4E8 : 4200 0F87 B... DBI1703E No valid service name or port number found. Explanation: No valid service name or port number for this instance can be found in the TCP/IP services file. This information is either missing or is invalid. If you installed "DB2 Extended Server Edition" product, a service name must be specified for the instance before using this command. User response: Specify valid service name and port number for this instance and enter this command again. Подскажите, пожалуйста, что неправильно. ... |
| 26.09.2017, 16:17:52 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1600399]: |
213ms |
46ms |
| others: | 246ms |
| total: | 567ms |
