IBM Websphere MQ 8.0.Помогите с ошибкой Reason code 2195 (AM4048)
Настроили конфигурацию server-to-server между двумя MQ , прописали каналы и все такое, telnet все Ok, но при попытке Ping в меню sender channel вылетает такая ошибка : The request received an unexpected reason code from an underlying API or command request. The reason code was 2195. (AMQ4048) The request received an unexpected reason code from an underlying API or command request. The reason code was 2195. (AMQ4048) Severity: 20 (Error) Explanation: While executing the requested operation, an unexpected return code was received. This has resulted in the operation not completing as expected. Response: Use the reason code to determine the underlying reason for the failure. В системном журнале сообщение : 22.05.2018 07:32:57 - Process(2908.1) User(MUSR_MQADMIN) Program(amqrcmla.exe) Host(AEROMQ) Installation(Installation1) VRMF(8.0.0.5) QMgr(DP_TEST) Conversion not supported. WebSphere MQ is unable to convert string data tagged in CCSID 866 to data in CCSID 437. Check the WebSphere MQ Application Programming Reference Appendix and the appropriate National Language Support publications to see if the CCSIDs are supported by your system. Причем , в этом же менеджере очередей есть еще один Sender channel , к другому потребителю, там Ping все ок. В чем причина, куда копать? ... |
| 22.05.2018, 07:38:12 |
start [/forum/topic.php?fid=43&gotonew=1&tid=1600326]: |
152ms |
48ms |
| others: | 215ms |
| total: | 461ms |
