Опять же Install VFP
Жаль что так мало было хороших мыслей по поводу установки VFP 7 с диска Alex soft , но на всякий спрошу : - На WinXP eng +MUI ставлю VFP 8 (навигатор). Все идет прекрасно до начала копирования (стр. install). Воремя копирования вылазит failed.htm c installlog.txt следующего содержания: перед тем как прочтете, на HD копировал и тд и тп тоже делал но в чем фича - не знаю !!!!!!!!!!!!!!!!!! [03/25/03,15:31:24] setup.exe: ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() [03/25/03,15:31:25] setup.exe: Component error string not specified in ISetupManager::AddToActionResultCollection() ***EndOfSession*** а также [03/25/03,15:31:09] Setup.exe: GetGlobalCustomProperty(B51015E7-26A5-4c8f-B871-26ABA9BEFB65) [03/25/03,15:31:09] Setup.exe: LoadSetupDatabase() [03/25/03,15:31:09] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:09] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:09] Setup.exe: IsRunningUnattended [03/25/03,15:31:09] Setup.exe: AddGlobalCustomProperty [03/25/03,15:31:09] Setup.exe: IsRunningUnattended [03/25/03,15:31:09] Setup.exe: inside ISetupManager::LoadHelpManager() [03/25/03,15:31:09] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:09] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:09] Setup.exe: ISetupManager::LoadCommandLineMgr() completed [03/25/03,15:31:09] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:09] Setup.exe: ISetupManager::LoadSetupLog() completed [03/25/03,15:31:10] Setup.exe: ISetupManager::RunIntro() starting [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadDependencyMgr() [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadCDInfoMgr() [03/25/03,15:31:10] Setup.exe: GetCustomProperties() [03/25/03,15:31:10] Setup.exe: get_CustomProperties() [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadTemplMgr() [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadDiskInfoMgr() [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadUIManager() [03/25/03,15:31:10] vs70uimgr: Entering InitializeModule() method. [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadAccountManager() [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadValidationManager() [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:10] Setup.exe: inside ISetupManager::LoadDependencyManagerUI() [03/25/03,15:31:10] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:11] Setup.exe: inside ISetupManager::LoadServerGroupManager() [03/25/03,15:31:11] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:11] Setup.exe: inside ISetupManager::LoadChangeFolder() [03/25/03,15:31:11] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:11] Setup.exe: GetCustomProperties() [03/25/03,15:31:11] Setup.exe: get_CustomProperties() [03/25/03,15:31:11] Setup.exe: GetGlobalCustomProperty({9AB7F66B-DBC6-4D44-8C09-E16F0EB162E7}) [03/25/03,15:31:11] : ISetupManager::GetGlobalCustomProperty(CustomCoreProp_Launcher) failed to find global prop in CRootcomponent::BuildRegKey() [03/25/03,15:31:11] Setup.exe: GetGlobalCustomProperty({9AB7F66B-DBC6-4D44-8C09-E16F0EB162E7}) [03/25/03,15:31:11] Visual FoxPro 8.0 Professional - English: ISetupManager::GetGlobalCustomProperty(CustomCoreProp_Launcher) failed to find global prop in CRootcomponent::BuildRegKey() [03/25/03,15:31:11] Setup.exe: GetGlobalCustomProperty({CF5ED780-9627-4D59-8530-1BCDE23E7E32}) [03/25/03,15:31:12] Setup.exe: inside ISetupManager::LoadActionOverrides() [03/25/03,15:31:12] Setup.exe: inside ISetupManager::LoadScenarioFactory() [03/25/03,15:31:12] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:12] Default Scenario Factory: Default scenario not specified or not found in [Scenario Factory Information] section of DefFactory.dat, defaulting to the first specified [03/25/03,15:31:12] Setup.exe: inside ISetupManager::InitializeUIManager() [03/25/03,15:31:12] vs70uimgr: Entering Start() method. [03/25/03,15:31:12] Setup.exe: GetGlobalCustomProperty({340F7930-0E41-11D3-ACE2-00C04F8EEBA1}) [03/25/03,15:31:12] Setup.exe: GetGlobalCustomProperty({AA62DF98-3F2C-11D3-887B-00C04F8ECDD6}) [03/25/03,15:31:12] Setup.exe: GetGlobalCustomProperty({BCC78D7A-89AE-11D2-AF03-00C04F797FB8}) [03/25/03,15:31:13] vs70uimgr: Entering GetAdminMode. [03/25/03,15:31:13] Setup.exe: GetGlobalCustomProperty({27B34574-6B5B-409F-9F93-D1E927B39E9C}) [03/25/03,15:31:13] vs70uimgr: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CUIMgr::GetGlobalProperty() [03/25/03,15:31:13] Setup.exe: AddGlobalCustomProperty [03/25/03,15:31:13] vs70uimgr: CUIMgr::GetAdminMode m_AdminMode = AM_NOMODE [03/25/03,15:31:13] vs70uimgr: Entering LoagPages() method. [03/25/03,15:31:13] vs70uimgr: Entering AddPageToList() method. Loading: vs70pgui.dll : {bb81d810-3f9b-11d3-a50c-00c04f5e0ba5} [03/25/03,15:31:13] VS70pgui: Entered InitializeModule Method of Start Page [03/25/03,15:31:13] vs70uimgr: Returning from CUIMgr::AddPageToList() [03/25/03,15:31:13] vs70uimgr: Entering AddPageToList() method. Loading: vs70pgui.dll : {9fe307c0-3646-11d3-a508-00c04f5e0ba5} [03/25/03,15:31:13] vs70uimgr: Returning from CUIMgr::AddPageToList() [03/25/03,15:31:13] vs70uimgr: Entering AddPageToList() method. Loading: vs70pgui.dll : {bb81d811-3f9b-11d3-a50c-00c04f5e0ba5} [03/25/03,15:31:13] vs70uimgr: Returning from CUIMgr::AddPageToList() [03/25/03,15:31:13] vs70uimgr: Entering AddPageToList() method. Loading: vs70pgui.dll : {1920cc5d-5be5-45d4-9c1c-3513d334c71c} [03/25/03,15:31:13] vs70uimgr: Returning from CUIMgr::AddPageToList() [03/25/03,15:31:13] Setup.exe: IsRunningUnattended [03/25/03,15:31:13] vs70uimgr: Entering ThreadUI() method. [03/25/03,15:31:13] vs70uimgr: Entering DisplayStartup() method. - not custom implemented [03/25/03,15:31:13] Setup.exe: ISetupManager::ResetBaselineActions() : SMP_SUITEBASELINE [03/25/03,15:31:13] Setup.exe: ISetupManager::GetBaslineComponents() [03/25/03,15:31:13] Setup.exe: ISetupManager::ResetBaselineActions() : SMP_SUITEBASELINE [03/25/03,15:31:13] Setup.exe: ISetupManager::GetBaslineComponents() [03/25/03,15:31:13] Setup.exe: ISetupManager::ResetBaselineActions() : SMP_SCENARIOBASELINE [03/25/03,15:31:13] Setup.exe: GetCustomProperties() [03/25/03,15:31:14] Setup.exe: get_CustomProperties() [03/25/03,15:31:14] Client Scenario: ISetupScenarioImpl::GetBaslineComponents() [03/25/03,15:31:14] vs70uimgr: Entering SelectScenario() method. - not custom implemented [03/25/03,15:31:14] Setup.exe: GetCustomProperties() [03/25/03,15:31:14] Setup.exe: get_CustomProperties() [03/25/03,15:31:14] Setup.exe: StartUIManager() [03/25/03,15:31:14] vs70uimgr: Entering RunScenario() method. [03/25/03,15:31:14] Setup.exe: GetGlobalCustomProperty({AA62DF98-3F2C-11D3-887B-00C04F8ECDD6}) [03/25/03,15:31:14] VS70pgui: Creating Start Page [03/25/03,15:31:14] VS70pgui: Initializing the Start Page dialog [03/25/03,15:31:14] VS70pgui: Entered InitGDIResources method [03/25/03,15:31:14] VS70pgui: Entered InitStaticControls method [03/25/03,15:31:14] VS70pgui: Entered InitStateBar method [03/25/03,15:31:14] VS70pgui: Entered InitNavLinks method [03/25/03,15:31:14] VS70pgui: Entered InitStaticToolTips method [03/25/03,15:31:14] VS70pgui: Created the Start Page [03/25/03,15:31:14] VS70pgui: Entered OnShowWindow method [03/25/03,15:31:14] VS70pgui: Entered COptionsPage::OnInitDialog method [03/25/03,15:31:14] VS70pgui: Entered COptionsPage::InitStaticControls method [03/25/03,15:31:14] VS70pgui: Entered COptionsPage::InitGDIResources method [03/25/03,15:31:14] VS70pgui: Entered COptionsPage::InitPropertyList method [03/25/03,15:31:15] VS70pgui: Entered COptionsPage::InitStateBar method [03/25/03,15:31:15] VS70pgui: Entered COptionsPage::InitNavLinks method [03/25/03,15:31:15] VS70pgui: Entered COptionsPage::InitStaticToolTips method [03/25/03,15:31:15] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [03/25/03,15:31:15] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [03/25/03,15:31:15] VS70pgui: Entered COptionsPage::InitFeatureTips method [03/25/03,15:31:15] VS70pgui: Entered COptionsPage::OnShowWindow method [03/25/03,15:31:15] Setup.exe: in RegisterSetupService() [03/25/03,15:31:15] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:15] Setup.exe: in RegisterSetupService() [03/25/03,15:31:15] Setup.exe: in InternalRegisterSetupService() [03/25/03,15:31:15] VS70pgui: Entered CPageHeaderDynamic::SetCallingPageBrowser method [03/25/03,15:31:15] VS70pgui: Entered CPageHeaderDynamic::OnInitDialog method [03/25/03,15:31:15] VS70pgui: Entered OnShowWindow method [03/25/03,15:31:15] Setup.exe: GetGlobalCustomProperty(DF8FF64A-1967-4871-9E32-CA2F819BAB81) [03/25/03,15:31:17] VS70pgui: Entered OnClickedAccept method [03/25/03,15:31:18] VS70pgui: Clicked Next on the Start Page [03/25/03,15:31:18] VS70pgui: Entered PidIsValid method [03/25/03,15:31:19] Setup.exe: GetGlobalCustomProperty({A5F918AF-5E66-11D2-ACCA-00C04F8EEBA1}) [03/25/03,15:31:19] Setup.exe: GetGlobalCustomProperty({A5F918AC-5E66-11D2-ACCA-00C04F8EEBA1}) [03/25/03,15:31:19] vs70uimgr: Entering Next() method. [03/25/03,15:31:19] VS70pgui: Entered COptionsPage::OnShowWindow method [03/25/03,15:31:19] VS70pgui: Entered OnShowWindow method [03/25/03,15:31:20] Setup.exe: ISetupManager::GetFullComponents() [03/25/03,15:31:20] Setup.exe: GetGlobalCustomProperty({0969412C-7281-11D2-AF01-00C04F797FB8}) [03/25/03,15:31:20] VS70pgui: Entered COptionsPage::Next method [03/25/03,15:31:20] vs70uimgr: Entering Next() method. [03/25/03,15:31:20] VS70pgui: Entered CPageHeaderDynamic::OnShowWindow method [03/25/03,15:31:20] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [03/25/03,15:31:20] VS70pgui: Entered COptionsPage::OnShowWindow method [03/25/03,15:31:20] Setup.exe: ISetupManager::RunIntro() complete [03/25/03,15:31:20] Setup.exe: ValidateAndCorrectTheInstallOrder() [03/25/03,15:31:20] Setup.exe: Attempted Order [03/25/03,15:31:20] Setup.exe: Visual FoxPro 8.0 Professional - English [{235D8A94-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:20] Setup.exe: Visual FoxPro 8.0 Professional [{235D8AA3-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:20] Setup.exe: Visual FoxPro Samples [{235D8AA7-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:20] Setup.exe: Visual FoxPro Tools [{235D8AA4-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:20] Setup.exe: Visual FoxPro Shared Features [{235D8AA5-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:20] Setup.exe: HTML Help 1.3 SDK [{024A175C-C539-11D3-A52B-00A0C9231BA1}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro Graphics Library [{235D8AA9-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: ValidateAndCorrectTheInstallOrder() [03/25/03,15:31:21] Setup.exe: Attempted Order [03/25/03,15:31:21] Setup.exe: Visual FoxPro 8.0 Professional - English [{235D8A94-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro 8.0 Professional [{235D8AA3-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro Samples [{235D8AA7-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro Tools [{235D8AA4-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro Shared Features [{235D8AA5-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: HTML Help 1.3 SDK [{024A175C-C539-11D3-A52B-00A0C9231BA1}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro Graphics Library [{235D8AA9-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: ValidateAndCorrectTheInstallOrder() [03/25/03,15:31:21] Setup.exe: Attempted Order [03/25/03,15:31:21] Setup.exe: Visual FoxPro 8.0 Professional - English [{235D8A94-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro 8.0 Professional [{235D8AA3-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro Samples [{235D8AA7-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:21] Setup.exe: Visual FoxPro Tools [{235D8AA4-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:22] Setup.exe: Visual FoxPro Shared Features [{235D8AA5-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:22] Setup.exe: HTML Help 1.3 SDK [{024A175C-C539-11D3-A52B-00A0C9231BA1}] [03/25/03,15:31:22] Setup.exe: Visual FoxPro Graphics Library [{235D8AA9-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:22] Setup.exe: ISetupManager::RunLoadSetup() complete [03/25/03,15:31:22] Setup.exe: RunInstall() [03/25/03,15:31:22] Setup.exe: ISetupManager::RunInstallLists() starting [03/25/03,15:31:22] Setup.exe: CSetupManager::InstallSetupFiles() starting [03/25/03,15:31:22] Setup.exe: CreateDirectoryLayout() [03/25/03,15:31:22] vs70uimgr: Entering ShowSmallProgress() method. [03/25/03,15:31:22] Setup.exe: IsRunningUnattended [03/25/03,15:31:22] vs70uimgr: Entering DisplayProgressScreen() method. [03/25/03,15:31:22] Setup.exe: ISetupManager::RunInstallFromList(IP_PREINSTALL) starting [03/25/03,15:31:22] Setup.exe: ValidateAndCorrectTheInstallOrder() [03/25/03,15:31:22] Setup.exe: Attempted Order [03/25/03,15:31:23] Setup.exe: Visual FoxPro 8.0 Professional - English [{235D8A94-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:23] Setup.exe: Visual FoxPro 8.0 Professional [{235D8AA3-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:23] Setup.exe: Visual FoxPro Samples [{235D8AA7-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:23] Setup.exe: Visual FoxPro Tools [{235D8AA4-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:23] Setup.exe: Visual FoxPro Shared Features [{235D8AA5-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:23] Setup.exe: HTML Help 1.3 SDK [{024A175C-C539-11D3-A52B-00A0C9231BA1}] [03/25/03,15:31:23] Setup.exe: Visual FoxPro Graphics Library [{235D8AA9-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] Setup.exe: GetGlobalCustomProperty({CDD00162-2E69-11D3-A829-00C04FB1799F}) [03/25/03,15:31:23] Setup.exe: GetGlobalCustomProperty({6B9948CF-0275-4B0A-BD4C-BD51A98D9D1C}) [03/25/03,15:31:23] Setup.exe: GetGlobalCustomProperty({A5F918AC-5E66-11D2-ACCA-00C04F8EEBA1}) [03/25/03,15:31:23] Setup.exe: GetGlobalCustomProperty({A5F918AD-5E66-11D2-ACCA-00C04F8EEBA1}) [03/25/03,15:31:23] Setup.exe: GetGlobalCustomProperty({A5F918AF-5E66-11D2-ACCA-00C04F8EEBA1}) [03/25/03,15:31:23] Setup.exe: IsRunningUnattended [03/25/03,15:31:23] vs70uimgr: Entering GetActiveHWND() method. [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:23] Setup.exe: ISetupManager::RunInstallFromList(IP_PREINSTALL) completed [03/25/03,15:31:23] Setup.exe: ISetupManager::RunInstallFromList(IP_INSTALL) starting [03/25/03,15:31:23] Setup.exe: ValidateAndCorrectTheInstallOrder() [03/25/03,15:31:23] Setup.exe: Attempted Order [03/25/03,15:31:24] Setup.exe: Visual FoxPro 8.0 Professional - English [{235D8A94-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:24] Setup.exe: Visual FoxPro 8.0 Professional [{235D8AA3-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:24] Setup.exe: Visual FoxPro Samples [{235D8AA7-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:24] Setup.exe: Visual FoxPro Tools [{235D8AA4-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:24] Setup.exe: Visual FoxPro Shared Features [{235D8AA5-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:24] Setup.exe: HTML Help 1.3 SDK [{024A175C-C539-11D3-A52B-00A0C9231BA1}] [03/25/03,15:31:24] Setup.exe: Visual FoxPro Graphics Library [{235D8AA9-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:24] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:24] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:24] Setup.exe: GetGlobalCustomProperty({A4421CB8-2DFF-4FB4-B59E-5E79F9DC09A0}) [03/25/03,15:31:24] Visual FoxPro 8.0 Professional - English: MsiInstallProduct initiated with command line: SUITEINTEGRATIONKEY="{3F83A255-3399-4eb8-B2F6-38C2DF5A111D}" VSEXTUI="1" SETUPWINDOW="263038" REINSTALLMODE="omus" INSTALLLEVEL="2" USERNAME="Alexandrov Sergey" REBOOT="Suppress" PIDKEY="TCJC7H2QDH3T7G7R6RTMYRK3Y" COMPANYNAME="GUMP "SANGVIS"" ALLUSERS="1" ADDLOCAL="VFP8_Professional,VFP_Samples,VFP_Tools,VFP_Shared_Features,HTML_Help_1.3_SDK,VFP_Graphics_Library" ARPINSTALLLOCATION="C:\Program Files\Microsoft Visual FoxPro 8\" [03/25/03,15:31:24] setup.exe: ***ERRORLOG EVENT*** : ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() [03/25/03,15:31:25] setup.exe: ***ERRORLOG EVENT*** : Component error string not specified in ISetupManager::AddToActionResultCollection() [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] Setup.exe: ISetupManager::RunInstallFromList(IP_INSTALL) completed [03/25/03,15:31:25] Setup.exe: ISetupManager::RunSharedInstall starting [03/25/03,15:31:25] Setup.exe: ISetupManager::RunSharedInstall completed [03/25/03,15:31:25] Setup.exe: ISetupManager::RunInstallFromList(IP_POSTINSTALL) starting [03/25/03,15:31:25] Setup.exe: ValidateAndCorrectTheInstallOrder() [03/25/03,15:31:25] Setup.exe: Attempted Order [03/25/03,15:31:25] Setup.exe: Visual FoxPro 8.0 Professional - English [{235D8A94-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:25] Setup.exe: Visual FoxPro 8.0 Professional [{235D8AA3-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:25] Setup.exe: Visual FoxPro Samples [{235D8AA7-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:25] Setup.exe: Visual FoxPro Tools [{235D8AA4-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:25] Setup.exe: Visual FoxPro Shared Features [{235D8AA5-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:25] Setup.exe: HTML Help 1.3 SDK [{024A175C-C539-11D3-A52B-00A0C9231BA1}] [03/25/03,15:31:25] Setup.exe: Visual FoxPro Graphics Library [{235D8AA9-2F97-11D6-A551-0090278A1BB8}] [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:25] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:26] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:26] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:26] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:26] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:26] Setup.exe: ISetupManager::RunInstallFromList(IP_POSTINSTALL) completed [03/25/03,15:31:26] Setup.exe: ISetupManager::RunInstallLists() completing [03/25/03,15:31:26] vs70uimgr: Entering RunningComponent() method. [03/25/03,15:31:26] VS70pgui: Failed to increment max steps for small progress. Logging as event not error ... noncritical. [03/25/03,15:31:27] Setup.exe: IsRunningUnattended [03/25/03,15:31:27] vs70uimgr: Entering DisplayFinal() method. [03/25/03,15:31:27] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [03/25/03,15:31:27] vs70uimgr: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CUIMgr::GetGlobalProperty() [03/25/03,15:31:27] Setup.exe: GetGlobalCustomProperty({47EAF7DE-458C-4C05-B3E1-82B9C563679B}) [03/25/03,15:31:27] vs70uimgr: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CUIMgr::GetGlobalProperty() [03/25/03,15:31:27] vs70uimgr: Entering Next() method. [03/25/03,15:31:27] VS70pgui: Entered CPageHeaderDynamic::OnShowWindow method [03/25/03,15:31:27] Setup.exe: GetGlobalCustomProperty({710A502B-4669-405C-A985-BA21545509BA}) [03/25/03,15:31:27] VS70pgui: ISetupManager::GetGlobalCustomProperty() failed to find global prop in CFinishPage::GetGlobalProperty() [03/25/03,15:31:27] Setup.exe: AddGlobalCustomProper ... |
| 25.03.2003, 15:39:19 |
В реестре наименование организации напиши по ангельски и без кавычек и других прибамбасов. ... |
| 26.03.2003, 19:58:07 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1598372]: |
193ms |
37ms |
| others: | 192ms |
| total: | 466ms |
