Инстал Пакет в VFP80
Не знаю как создать инсталяшку своей проги написаной на VFP80. Подскажите чем? ... |
| 19.11.2003, 12:22 |
Application Wizard ? DimonNE ... |
| 19.11.2003, 12:40 |
Какой такой Код: plaintext И где его взять для VFP80 ... |
| 19.11.2003, 12:47 |
CreateInstall ... |
| 19.11.2003, 12:51 |
Building an Application File from the Project See Also Testing a Project | Referencing Modifiable Files | Compiling an Application | Build Options | BUILD APP | BUILD EXE To create a finished file from your application, you build it into an application file. An application file has an extension of .app. To run the application, users first start Visual FoxPro, then load the .app file. You can choose to build either an application (.app) or an executable (.exe) file from your project. Users can run an .app file if they already have a copy of Visual FoxPro. Alternatively, you can create an .exe file. The .exe file works in conjunction with two Visual FoxPro dynamic link libraries (Vfp7r.dll and Vfp7renu.dll) that you ship with your application to provide a complete run-time environment for Visual FoxPro. The second file is specific to the region of the world your application targets. For more information, see Distributing Applications. To build an application In the Project Manager, choose Build. In the Build Options dialog box, choose Build Application to build an .app file, or Build Executable to build an .exe file. Select any other options you need, then choose OK. -or- Use the BUILD APP or BUILD EXE command. For example, to build an application called Myapp.app from a project named Myproj.pjx, you can type: BUILD APP myapp FROM myproj To create an application called Myapp.exe from a project named Myproj.pjx, you can type: BUILD EXE myapp FROM myproj Note You can also use the Build dialog box to create an Automation server from your Visual FoxPro application. For more information, see Creating Automation Servers in "Adding OLE." After you've created a finished application file for your project, you and your users can run it. To run an application as an .app file In Visual FoxPro, choose Do from the Program menu and select the application file. -or- In the Command window, type DO and the name of your application file. For example, to run an application called MYAPP, type: DO myapp.app If you have created an .exe file from your application, users can run it in a variety of ways. To run an application as an .exe file In Visual FoxPro, choose Do from the Program menu and select the application file, or in the Command window, type DO and the name of your application file. For example, to run an .exe file called Myapp.exe, type: DO myapp.exe -or- In Windows, double-click the icon for the .exe file. See Also Testing a Project | Referencing Modifiable Files | Compiling an Application | Build Options | BUILD APP | BUILD EXE Хелп для "семерки" DimonNE ... |
| 19.11.2003, 14:12 |
Брату NE_Dimon Как создавать ехе файлы я давно знаю. Вопрос состоит в другом - КАК СОЗДАТЬ ИНСТАЛ ДЛЯ УСТАНОВКИ НА ДРУГУЮ МАШИНУ ГДЕ НЕТ VFP80!!!!! ... |
| 19.11.2003, 14:20 |
NE_Dimon Application Wizard - если речь о фоксовском, то он создаёт новый Application, а мне надо создать Setup к уже готовому. ozerjan CreateInstall - это что? ... |
| 19.11.2003, 14:24 |
Короче, меню TOOLS-> WIZARD -> ALL WIZARD -> SETUP WIZARD, ДАЛЕЕ ПО СМЫСЛУ. DimonNE ... |
| 19.11.2003, 15:36 |
ЗЫ. Спросил у фокпрошника, у которого 8-ка. DimonNE ... |
| 19.11.2003, 15:38 |
Не знаю, как в 8, но в 6 Application Wizard создаст некое тестовое приложение, но вовсе не дистрибутив. Насколько я в курсе, начиная с 7 версии для создания дистрибутивов поставляется специальная программа Install Shield (точнее, ее усеченная версия). Это внешняя программа. Ее надо устанавливать отдельно. Поставляется вместе с дистрибутивом VFP. ... |
| 19.11.2003, 16:12 |
Возникал такой вопрос. Посмотри |> /topic/54951. ... |
| 20.11.2003, 06:36 |
http://www.createinstall.ru/ ... |
| 20.11.2003, 07:38 |
Какие DLL нужно иметь на компе, чтобы работала прога на VFP80 ... |
| 20.11.2003, 15:06 |
vfp8r.dll,vfp8rrus.dll,gdiplus.dll ... |
| 21.11.2003, 07:54 |
Спасибо !! Я вчера нашёл Foxpro Runtime Support для Setup Factory 6.0, так что проблема создания setup.exe отпала.Но прошла новая, найти кряк к Setup Factory 6.0, а то у меня Демо версия (30 дней). И инсталяшки она делает такие же - 10 дней триал. ... |
| 21.11.2003, 09:43 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1597535]: |
27ms |
40ms |
| others: | 247ms |
| total: | 355ms |
