insert into
В 9 фоксе такая у меня непонятка: insert into n_960_; SELECT SPACE(5) AS vservtype,; PADR(ALLTRIM("960"),5," ") AS vcode,; MIN(Spisnap.datbeg) AS ddate,; PADR(STR(Spabon.uid,10),10,' ') AS vsacct,; SPACE(30) AS vtechcode, ; SPACE(10) AS vtechtype,; PADR("43",10," ") AS vzone,; PADR("11",5," ") AS vsubstype,; PADR(ALLTRIM(Spabon.namabn),30," ") AS vsurname,; SPACE(100) AS vname,; SPACE(30) AS vpatr,; PADR(ALLTRIM(STR(Sprul.kodadm+430000))+PADL(ALLTRIM(STR(Sprul.kodul)),4,'0'),30,' ') AS vstreet,; PADR(Spabon.domkv,5," ") AS vhouse,; SPACE(5) AS vletter,; SPACE(5) AS vflat,; IIF(EMPTY(Splgot.datend),PADL(Splgot.vprivtype,10," "),SPACE(10)) AS vprivtype,; SPACE(5) AS vwservt,; IIF(EMPTY(Splgot.datend),PADL(Splgot.vprevservt,10," "),SPACE(10)) AS vprevservt,; SPACE(5) AS vwservtcon,; {} AS dpaym,; 0000000000.00 AS nsumone,; SPACE(30) AS vadddata,; IIF(AT("???????",Spabon.namabn)>0,"1","0") AS vsecret,; SPACE(5) AS voper,; {} AS dwrite,; SPACE(10) AS vmfo,; SPACE(20) AS vbankacct,; SPACE(10) AS vokpo,; PADR(Spabon.ind_nom,10," ") AS vtaxcode,; PADR(Spabon.nom_svid,10," ") AS vcoderegnd,; SPACE(10) AS vpostdept,; SPACE(10) AS vatc,; 0000000000.0000 AS ncpct,; 0000000000 AS norder,; SPACE(5) AS vdistr,; {} AS dend,; SPACE(10) as VSTREETK,; SPACE(5) as VHOUSEK,; SPACE(5) as VFLATK; FROM ; spabon ; INNER JOIN spradm ; ON Spabon.kodadm = Spradm.kodadm ; INNER JOIN spisnap ; ON Spabon.schet = Spisnap.schet ; INNER JOIN sprlg ; ON Splgot.kodlg = Sprlg.kodlg ; LEFT OUTER JOIN splgot ; ON Spabon.schet = Splgot.schet ; INNER JOIN sprul ; ON Sprul.kodadm = Spabon.kodadm; AND Sprul.kodul = Spabon.kodul; WHERE Spabon.kodvabn = ( 1 ); AND ( Spabon.schet BETWEEN 200000 AND 700000; OR Spabon.schet > ( 800000 ) ); GROUP BY 1, 2, Spabon.UID, 5, 6, 7, 8, Spabon.namabn, 10,; 11, 12, Spabon.domkv, 14, 15, 16, Splgot.vprevservt, 18, 19, 20, 22,; 23, 24, 25, 26, 27, Spabon.ind_nom, Spabon.nom_svid, Spabon.nom_svid, 31, 32, 33, 34, 35; ORDER BY Spabon.UID В полученой таблице некоторые поля имеют тип Varchar которые после команды copy to .... as 866 type fox2x стают memo-полями. как обойти? ... |
| 17.06.2004, 12:54 |
insert into
В версии VFP9beta стоит обратить особое внимание на настройку SET VarCharMapping ON|OFF В версии Visual FoxPro 9 beta эта настройка по умолчанию установлена в ON. Это означаете, что если в команде Select-SQL размерность какого-либо символьного поля не указана явно, то такое поле будет иметь тип данных VarChar, а не Character, как было раньше. Думаю, в окночательном релизе версии Visual FoxPro 9 эта настройка будет иметь по умолчанию значение OFF. Впрочем, посмотрим. ... |
| 17.06.2004, 13:27 |
insert into
=В полученой таблице некоторые поля имеют тип Varchar которые после =команды =copy to .... as 866 type fox2x =стают memo-полями. =как обойти? у самого такое было... е хе SELECT SUBSTR(Oracle-VarChar-field, 1, 255) AS NotMemoField into table tmp select tmp copy to .... as 866 type fox2x так поборол... но если надо более 255 символов - то извините... не знаю... ... |
| 17.06.2004, 14:24 |
insert into
Я так и знал, что ответ будет от ВладимирМ. БОЛЬШОЕ СПАСИБО! Но не понятно по какому признаку он ставит Varchar или Character. Что занятно таблица, в котрую инсертится не имеет полей типа Varchar. Или Insert into - SQL тоже переписывает табл. как и простой Select into table ? ... |
| 17.06.2004, 14:27 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1596339]: |
171ms |
38ms |
| others: | 229ms |
| total: | 483ms |
