.NULL
Privet ! Mne nado v zaprose v mesto '.NULL' prosto 0 (nol (tsifra)) polucat. Kak ne skajite? ... |
| 14.01.2005, 09:30 |
.NULL
Код: plaintext ... |
| 14.01.2005, 09:32 |
.NULL
select nvl(MyField,0) from ... ... |
| 14.01.2005, 09:36 |
.NULL
Net, oba fuuksiya vse zapisi delayut =0, a mne nado chto tolko te zaposi katoriy = .null Ili ya chto-to ne tak delayu? *************** SELECT Kurslar.*, IIF(ISNULL(Mez_f.sum_debet),0000.00, Mez_f.sum_debet), IIF(ISNULL(Mez_f.sum_KREDIT),0000.00, Mez_f.sum_KREDIT) , Mez_f.sum_m_debe,; Mez_f.sum_m_kred; FROM kurslar FULL JOIN mez_f ; ON Kurslar.tarix = Mez_f.tarix; ORDER BY Kurslar.tarix; INTO TABLE MEZ_F1 ... |
| 14.01.2005, 10:00 |
.NULL
Izvenite ,eto moya oshibka bilo ... |
| 14.01.2005, 10:06 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1595086]: |
178ms |
46ms |
| others: | 223ms |
| total: | 483ms |
