Flock()
Какие команды (кроме Raplace All) неявно выполняют FLock() ?!? ... |
| 03.10.2005, 15:07:16 |
Flock()
[quot [хельп (c)]Commands that Automatically Lock Records and Tables Command Scope of lock ALTER TABLE Entire table APPEND Table header APPEND BLANK Table header APPEND FROM Table header APPEND FROM ARRAY Table header APPEND MEMO Current record BLANK Current record BROWSE, CHANGE and EDIT Current record and all records from aliased fields in related tables once editing of a field begins CURSORSETPROP( ) Depends on parameters DELETE Current record DELETE NEXT 1 Current record DELETE RECORD n Record n DELETE of more than one record Entire table DELETE – SQL Current record GATHER Current record INSERT Entire table INSERT - SQL Table header MODIFY MEMO Current record when editing begins READ Current record and all records from aliased fields RECALL Current record RECALL NEXT 1 Current record RECALL RECORD n Record n RECALL of more than one record Entire table REPLACE Current record and all records from aliased fields REPLACE NEXT 1 Current record and all records from aliased fields REPLACE RECORD n Record n and all records from aliased fields REPLACE of more than one record Entire table and all files from aliased fields SHOW GETS Current record and all records referenced by aliased fields TABLEUPDATE( ) Depends on buffering UPDATE Entire table UPDATE – SQL Entire table [/quot] ... |
| 03.10.2005, 15:14:49 |
start [/forum/search_topic.php?author=IT+exam+Sertification&author_mode=last_posts&do_search=1]: |
187ms |
35ms |
| others: | 405ms |
| total: | 694ms |
