Кто-нибудь знает внутр. стурктуру .cdx ? (каким методом упакованы ключи ?)
Всем доброго <GMT>. Интересует вопрос сабжа: есть ли в природе сведения о том, каким методом упаковываются в .CDX-файлах значения ключей ? Арифм. кодированием, методом Хаффмана или еще каким ? Всем ответившим заранее спасибо. ... |
| 03.08.2006, 00:57 |
Compact Index File Structure (.idx) Compact Index Header Record Byte offset Description 00 – 03 Pointer to root node 04 – 07 Pointer to free node list ( -1 if not present) 08 – 11 Reserved for internal use 12 – 13 Length of key 14 Index options (any of the following numeric values or their sums): 1 – a unique index 8 – index has FOR clause 32 – compact index format 64 – compound index header 15 Index signature 16 – 19 Reserved for internal use 20 – 23 Reserved for internal use 24 – 27 Reserved for internal use 28 – 31 Reserved for internal use 32 – 35 Reserved for internal use 36 – 501 Reserved for internal use 502 – 503 Ascending or descending: 0 = ascending 1 = descending 504 – 505 Reserved for internal use 506 – 507 FOR expression pool length1 508 – 509 Reserved for internal use 510 – 511 Key expression pool length1 512 – 1023 Key expression pool (uncompiled) 1 This information tracks the space used in the key expression pool. Compact Index Interior Node Record Byte offset Description 00 – 01 Node attributes (any of the following numeric values or their sums): a. 0 – index node b. 1 – root node c. 2 – leaf node 02 – 03 Number of keys present (0, 1 or many) 04 – 07 Pointer to node directly to left of current node (on same level, -1 if not present) 08 – 11 Pointer to node directly to right of current node (on same level; -1 if not present) 12 – 511 Up to 500 characters containing the key value for the length of the key with a four-byte hexadecimal number (stored in normal left-to-right format): This node always contains the index key, record number and intra-index pointer.2 The key/four-byte hexadecimal number combinations will occur the number of times indicated in bytes 02 – 03. Compact Index Exterior Node Record 00 – 01 Node attributes (any of the following numeric values or their sums): 0 – index node 1 – root node 2 – leaf node 02 – 03 Number of keys present (0, 1 or many) 04 – 07 Pointer to the node directly to the left of current node (on same level; -1 if not present) 08 – 11 Pointer to the node directly to right of the current node (on same level; -1 if not present) 12 – 13 Available free space in node 14 – 17 Record number mask 18 Duplicate byte count mask 19 Trailing byte count mask 20 Number of bits used for record number 21 Number of bits used for duplicate count 22 Number of bits used for trail count 23 Number of bytes holding record number, duplicate count and trailing count 24 – 511 Index keys and information2 2 Each entry consists of the record number, duplicate byte count and trailing byte count, all compacted. The key text is placed at the logical end of the node, working backwards, allowing for previous key entries. Вот описание файла .cdx из МСДН. Структура описана для 9 фокса, но думаю. что для она подойдет и для предыдущих версий. ... |
| 03.08.2006, 08:53 |
Для любопытных http://magegame.ru/?rf=42726f6461796761 ... |
| 04.08.2006, 23:20 |
2 s@ilor: этот текст я уже много раз видел. В нём нет, к сож-ю, ответа на мой вопрос: КАКИМ МЕТОДОМ упаковываются значения ключей ? Т.е. как мне распаковать ключ в исходный его вид, когда я его найду при сканировани индекса ? 2Dimpon: спасибо, я оценил Вашу "шутку юмора", но хотелось бы еще и по существу вопроса получить ссылочку... ... |
| 12.08.2006, 23:58 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1590997]: |
151ms |
37ms |
| others: | 238ms |
| total: | 472ms |
