Как переименовать каталог
Необходимо переименовать каталог. Команды в VFP такой нет. Подскажите, как это сделать с помощью API ... |
| 05.09.2007, 22:33 |
БЮИ.Необходимо переименовать каталог. Команды в VFP такой нет. Подскажите, как это сделать с помощью API MSDN Help MoveFile The MoveFile function moves an existing file or a directory, including its children. To specify how to move the file, use the MoveFileEx function. BOOL MoveFile( LPCTSTR lpExistingFileName, // file name LPCTSTR lpNewFileName // new file name ); Parameters lpExistingFileName [in] Pointer to a null-terminated string that names an existing file or directory. Windows NT/2000: In the ANSI version of this function, the name is limited to MAX_PATH characters. To extend this limit to nearly 32,000 wide characters, call the Unicode version of the function and prepend "\\?\" to the path. For more information, see File Name Conventions. Windows 95/98: This string must not exceed MAX_PATH characters. lpNewFileName [in] Pointer to a null-terminated string that specifies the new name of a file or directory. The new name must not already exist. A new file may be on a different file system or drive. A new directory must be on the same drive. Windows NT/2000: In the ANSI version of this function, the name is limited to MAX_PATH characters. To extend this limit to nearly 32,000 wide characters, call the Unicode version of the function and prepend "\\?\" to the path. For more information, see File Name Conventions. Windows 95/98: This string must not exceed MAX_PATH characters. Return Values If the function succeeds, the return value is nonzero. If the function fails, the return value is zero. To get extended error information, call GetLastError. Remarks The MoveFile function will move (rename) either a file or a directory (including its children) either in the same directory or across directories. The one caveat is that the MoveFile function will fail on directory moves when the destination is on a different volume. Windows 2000: The MoveFile function coordinates its operation with the link tracking service, so link sources can be tracked as they are moved. MAPI: For more information, see Syntax and Limitations for Win32 Functions Useful in MAPI Development. Requirements Windows NT/2000: Requires Windows NT 3.1 or later. Windows 95/98: Requires Windows 95 or later. Header: Declared in Winbase.h; include Windows.h. Library: Use Kernel32.lib. Unicode: Implemented as Unicode and ANSI versions on Windows NT/2000. А еще можно сделать так: -создать директорию с нужным именем (CreateDirectory) - скопировать все содержимое из исходной директории (можно средствами Фокса) - удалиь исходную директорию (RemoveDirectory) ... |
| 06.09.2007, 07:15 |
Код: plaintext 1. ... |
| 06.09.2007, 07:28 |
piva Код: plaintext 1. Очень класный способ. Попробовал в VFP 9.0 - работает и на длиных именах. Но есть проблема в RUNTIME - дает ошибку "Неизвестный код состояния com". ... |
| 06.09.2007, 21:03 |
БЮИ piva Код: plaintext 1. Очень класный способ. Попробовал в VFP 9.0 - работает и на длиных именах. Но есть проблема в RUNTIME - дает ошибку "Неизвестный код состояния com". На какой команде-то? В принципе, сообщение об ошибке говорит о проблемах на конкретной машине. К RunTime никакого отношения не имеет. Перемещать каталоги с одного диска на другой можно только в случае, если это поддерживается операционной системой. Например: Windows 98 SE с установленным DirectCD не позволяет перемещать каталоги с жесткого диска на CD-RW и обратно. Подробности и другие команды по работе с файловой системой смотри здесь http://kodu.neti.ee/~juri4/vfpplus/vbs_fso_01_ru.htm ... |
| 06.09.2007, 21:31 |
Разобрался. Такая ошибка появляется в случае попытки переименовать несуществующий каталог. Спасибо всем за помощь. ... |
| 08.09.2007, 23:38 |
piva Код: plaintext 1. А для копирования папки - так? o=CreateObject("Scripting.FileSystemObject") o. Copy Folder("C:\000","C:\111") ... |
| 09.09.2007, 10:37 |
Точно ;-)) - САМ проверил... ... |
| 09.09.2007, 10:55 |
Ссылку бы посмотрел. Там много чего еще написано. Все по русски, с примерами и комментариями. ... |
| 09.09.2007, 13:07 |
ВладимирМСсылку бы посмотрел. Там много чего еще написано. Все по русски, с примерами и комментариями. Обязательно. Но пока интересно было только это. На самом деле весь форум - одна большая ссылка, всегда можно вернуться, посмотреть (поискать) и - дальше в бой. Кстати. Было обсуждение по книге по Фоксу. Купил. На самом деле книга не в пример бывшим - хорошая. По крайней мере есть информация для реального использования. Но пока не воспользовался - форума достаточно. И всем за это агромадное спасибо! Фокс жил, Фокс жив. Фокс будет жить! ... |
| 09.09.2007, 21:51 |
start [/forum/search_topic.php?author=antonyjee&author_mode=last_topics&do_search=1]: |
79ms |
58ms |
| others: | 634ms |
| total: | 854ms |
