Значение RECNO() полсле APPEND BLANK
Есть у меня CAD, делаю для него APPEND BLANK: Код: plaintext 1. 2. 3. 4. 5. 6. ... |
| 22.02.2008, 17:39 |
Хелп хотя бы иногда надо читать. You can append and delete records while table buffering is enabled: appended records are added to the end of the buffer. To access all records in the buffer, including appended records, use the RECNO( ) Function. The RECNO( ) function returns sequential negative numbers on records you append to a table buffer. For instance, if you initiate table buffering, edit records 7, 8, and 9, and then append three records, the buffer will contain RECNO( ) values of 7, 8, 9, – 1, – 2, and – 3. То есть -1 и есть номер новой строки. ... |
| 22.02.2008, 17:43 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1588117]: |
55ms |
56ms |
| others: | 234ms |
| total: | 402ms |
