Source not available
[Source not available] при отладке программы, как от этого избавиться ? часть кода, где прописаны пути: *// SET EXCLUSIVE OFF SET DELETED ON SET DATE TO GERMAN SET CENTURY ON SET SAFETY OFF SET TALK OFF SET OPTIMIZE ON SET STATUS BAR ON SET NOTIFY OFF SET EXACT OFF SET NOTIFY CURSOR OFF * SET PROCEDURE TO pmodul ADDITIVE * SET COVERAGE TO 'c:\zzz.txt' ADDITIVE PUBLIC cPath1, cPath2, cPath3, pcCompanyName, pcFileVersion, lactmenyu cPath2 = JUSTPATH(SYS(16)) SET DEFAULT TO (cPath2) SET PATH TO ;db;forms;other;progs;reports;class;picture;shablon *// ... |
| 13.03.2008, 17:29 |
Код: plaintext 1. 2. ... |
| 13.03.2008, 18:04 |
Vitalьпомогите плз про пути и SET PATH тут было ... |
| 13.03.2008, 18:09 |
В проекте поставь галку Debug Info и перекомпели весь проект ... |
| 13.03.2008, 19:55 |
Visual FoxPro 9.0 Project Tab, Project Information Dialog Box ... Debug Info Specifies whether debugging information is included with the compiled file. If this is not checked, you cannot view program execution in the Trace window. Corresponds to the NODEBUG argument in the COMPILE command. ... ... |
| 13.03.2008, 19:58 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1588041]: |
47ms |
63ms |
| others: | 224ms |
| total: | 388ms |
