xml
Код: plaintext Test The test form is only available for requests from the local machine. SOAP 1.1 The following is a sample SOAP 1.1 request and response. The placeholders shown need to be replaced with actual values. POST /ntosservice/ntosservice.asmx HTTP/1.1 Host: www.primer.ru Content-Type: text/xml; charset=utf-8 Content-Length: length SOAPAction: " http://temp.org/get_ser_users" <?xml version="1.0" encoding="utf-8"?> <soap:Envelope xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:soap=" http://schemas.xmlsoap.org/soap/envelope/"> <soap:Body> <get_ser_users xmlns=" http://temp.org/"> <user_name>string</user_name> <user_password>string</user_password> </get_ser_users> </soap:Body> </soap:Envelope> HTTP/1.1 200 OK Content-Type: text/xml; charset=utf-8 Content-Length: length <?xml version="1.0" encoding="utf-8"?> <soap:Envelope xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:soap=" http://schemas.xmlsoap.org/soap/envelope/"> <soap:Body> <get_ser_usersResponse xmlns=" http://temp.org/"> <get_ser_usersResult>xmlxml</get_ser_usersResult> <user_id>int</user_id> </get_ser_usersResponse> </soap:Body> </soap:Envelope> SOAP 1.2 The following is a sample SOAP 1.2 request and response. The placeholders shown need to be replaced with actual values. POST /ntosservice/ntosservice.asmx HTTP/1.1 Host: www.primer.ru Content-Type: application/soap+xml; charset=utf-8 Content-Length: length <?xml version="1.0" encoding="utf-8"?> <soap12:Envelope xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:soap12=" http://www.w3.org/2003/05/soap-envelope"> <soap12:Body> <get_ser_users xmlns=" http://temp.org/"> <user_name>string</user_name> <user_password>string</user_password> </get_ser_users> </soap12:Body> </soap12:Envelope> HTTP/1.1 200 OK Content-Type: application/soap+xml; charset=utf-8 Content-Length: length <?xml version="1.0" encoding="utf-8"?> <soap12:Envelope xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:soap12=" http://www.w3.org/2003/05/soap-envelope"> <soap12:Body> <get_ser_usersResponse xmlns=" http://temp.org/"> <get_ser_usersResult>xmlxml</get_ser_usersResult> <user_id>int</user_id> </get_ser_usersResponse> </soap12:Body> </soap12:Envelope> ... |
| 03.02.2011, 10:01 |
xml
> Автор: Makrosa > кто нибудь знает как можно связать это с FoxPro У меня такое используется, но вопрос очень общий, что интересует конкретно? У меня на веб-сервере веб-служба, с которой общается программа. Для общения программы и веб-службы использую MS SOAP 3.0. Вот похожие сообщения и гоняются между программой и веб-службой. У тебя веб-служба может быть фокспрошной, а клиент - NET'овский. Posted via ActualForum NNTP Server 1.4 ... |
| 03.02.2011, 10:35 |
xml
Игорь Горбонос, нужно данные из FoxPro оправит (или принять) на сервер. для этого нам дали инструкции похожие на этот. можете посоветовать в каком направление капать. если возможно примерчик (это било просто замечательно). ... |
| 03.02.2011, 13:02 |
xml
> Автор: Makrosa > нужно данные из FoxPro оправит (или принять) на сервер. для этого нам дали инструкции похожие на этот. Вообще-то вам, как клиентскому приложению, нужен так называемый WSDL-файл. Вот его пример. Для SOAP в принципе больше ничего не нужно. > можете посоветовать в каком направление капать. если возможно примерчик (это било просто замечательно). Здесь и теория и примерчик. Пока так, читайте, спрашивайте. Posted via ActualForum NNTP Server 1.4 ... |
| 03.02.2011, 15:08 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1584580]: |
170ms |
51ms |
| others: | 205ms |
| total: | 469ms |
