fatal error:exception code=c0000005
Privet! Pomoqite pojaluysta! Poluchayu exe fayl iz pjx. Vsyo normalno exe fayl poluchaetsa, No pri zapuska etot je exe fayl na etom je komputera dayut oshibka: "fatal error:exception code=c0000005 " V chem delo ne ponimayu (Vfp 6) ... |
| 22.09.2005, 10:13 |
n12m34Privet! Pomoqite pojaluysta! Poluchayu exe fayl iz pjx. Vsyo normalno exe fayl poluchaetsa, No pri zapuska etot je exe fayl na etom je komputera dayut oshibka: "fatal error:exception code=c0000005 " V chem delo ne ponimayu (Vfp 6) MORE INFORMATION With earlier versions of FoxPro, there are some conditions in which a developer may have found it desirable to include @ ... GET statements in the ERROR, MESSAGE, VALID, or WHEN clause of certain controls. When screens created with FoxPro 2.x are functionally converted to Visual FoxPro forms, @ ... GET statements, used to generate a FoxPro 2.x screen, are converted to a corresponding Visual FoxPro control. Likewise, any code contained in any of the clauses of the control is copied to a corresponding Visual FoxPro form method. If the ERROR, MESSAGE, VALID, or WHEN clause of a FoxPro 2.x screen contains an @ ... GET statement, then the @ ... GET statement is copied into the Visual FoxPro as code and is not treated as a form control. Случайно не исполюзуете команды FoxPro 2.x ??? ... |
| 22.09.2005, 10:56 |
[quot Владимир СА Случайно не исполюзуете команды FoxPro 2.x ???[/quot] Pomoemu net, ne isplzuval. ... |
| 22.09.2005, 11:04 |
n12m34Pomoemu net, ne isplzuval. Фраза: "помоему НЕТ", звучит как-то неубедительно. Как формируете формочки??? Перекодировали программы (экраны) из FPD2X ??? ... |
| 22.09.2005, 11:08 |
Net, tochno net. ... |
| 22.09.2005, 11:16 |
Извиняюсь, еще нашел: SYMPTOMS Under a specific set of circumstances involving Access methods in custom classes and the use of the debugger, Visual FoxPro displays the following error message: Fatal error: Exception code=C0000005 This behavior may not happen if you run the form using the Run button (!) in the system toolbar although this sometimes can occur. STATUS Microsoft has confirmed that this is a bug in the Microsoft products that are listed at the beginning of this article. The Visual Studio 6.0 Service Pack 3 readme lists this bug as being fixed. Service Pack 3 did not fix this bug. У тебя VFP6 с каким SP ??? У меня лично уже SP5. ... |
| 22.09.2005, 11:22 |
Владимир САУ тебя VFP6 с каким SP ??? У меня лично уже SP5. Daje neznayu. Akak eto mojno proverit? ... |
| 22.09.2005, 11:57 |
System Menu: Help - About Microsoft Visual FoxPro... First line as this "Microsoft Visual FoxPro 8.0 SP..." ... |
| 22.09.2005, 12:19 |
Здравствуйте. У меня програма на VFP6. Все шло хорошо на wxp. На компьютере с W7 работает странно, выдает ошибку Fatal Error Exception code=c0000005. Помогите, пожалуйста. ... |
| 20.10.2011, 16:54 |
Строку кода вычислил на которой вылетает? Такая ошибка в 6-ке часто бывает в трех случаях: 1. Функция FILE("С:\...") где буква диска С русская. 2. Из-за кривого драйвера принтера вылетает на формировании отчета, лечить заменой драйвера или играть настройками. 3. Из-за битых индексов (редко, но бывает). Надо пересоздать индексы Из-за 7-ки проблем не было, но если в проге есть какие-то самописные DLL-ки, то может в них что-то криво написано. В висте бывали проблемы если в "Program files" прогу селить. Если у тебя там, то попробуй в корень диска С перенести. ... |
| 21.10.2011, 08:18 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1584058]: |
179ms |
33ms |
| others: | 243ms |
| total: | 497ms |
