export grid to calc libreoffece5
Приветствую! сделал експот грид в exel, но на машине где это должно работать MS Office2010 был удален по лицензионным соображениям и установлен LibreOffece5. Теперь переделываю експорт в calc libreoffece5. Создал файл вспомогательных функций oo_proc.prg: * Open or Create a document from it's URL. * New documents are created by URL's such as: * private:factory/sdraw * private:factory/swriter * private:factory/scalc * private:factory/simpress FUNCTION OOoOpenURL( cURL ) LOCAL ARRAY aNoArgs[1] aNoArgs[1] = OOoMakePropertyValue("Hidden",.F.) LOCAL oDesktop oDesktop = OOoGetDesktop() LOCAL oDoc oDoc = oDesktop.LoadComponentFromUrl(cURL,"_blank",0,@aNoargs) * Make sure that arrays passed to this document are passed zero based. COMARRAY(oDoc,10) RETURN oDoc ENDFUNC * Create a com.sun.star.beans.PropertyValue struct and return it. FUNCTION OOoMakePropertyValue( cName, uValue, nHandle, nState ) LOCAL oPropertyValue oPropertyValue = OOoCreateStruct( "com.sun.star.beans.PropertyValue" ) oPropertyValue.Name = cName oPropertyValue.Value = uValue IF TYPE([nHandle])="N" oPropertyValue.Handle = nHandle ENDIF IF TYPE([nState])="N" oPropertyValue.State = nState ENDIF RETURN oPropertyValue ENDFUNC * Sugar coated routine to create any UNO struct. * Use the Bridge_GetStruct() feature of the OLE-UNO bridge. FUNCTION OOoCreateStruct( cTypeName ) LOCAL oServiceManager oServiceManager = OOoGetServiceManager() LOCAL oStruct oStruct = .NULL. LOCAL cOldErrHandler cOldErrHandler = ON( "ERROR" ) ON ERROR = DoNothing__ErrorHandler( ERROR(), MESSAGE(), LINENO(), SYS(16), PROGRAM(), SYS(2018) ) oStruct = oServiceManager.Bridge_GetStruct( cTypeName ) ON ERROR &cOldErrHandler IF ISNULL( oStruct ) =__OOoReleaseCachedVars() oServiceManager = OOoGetServiceManager() oStruct = oServiceManager.Bridge_GetStruct( cTypeName ) ENDIF RETURN oStruct ENDFUNC * Return the OpenOffice.org desktop object. * Cache it in a global variable. * Create it if not already cached. FUNCTION OOoGetDesktop() IF (TYPE([goOOoDesktop])!="O") OR ISNULL( goOOoDesktop ) PUBLIC goOOoDesktop goOOoDesktop = OOoServiceManager_CreateInstance( "com.sun.star.frame.Desktop" ) COMARRAY( goOOoDesktop, 10 ) ENDIF RETURN goOOoDesktop ENDFUNC * Return the OpenOffice.org dispatcher object. * Cache it in a global variable. * Create it if not already cached. FUNCTION OOoGetDispatcher() IF (TYPE([goOOoDispatcher])!="O") OR ISNULL(goOOoDispatcher) PUBLIC goOOoDispatcher goOOoDispatcher = OOoServiceManager_CreateInstance("com.sun.star.frame.DispatchHelper") COMARRAY(goOOoDispatcher,10) ENDIF RETURN goOOoDispatcher ENDFUNC * Return the OpenOffice.org service manager object. * Cache it in a global variable. * Create it if not already cached. FUNCTION OOoGetServiceManager() IF (TYPE([goOOoServiceManager])!="O") OR ISNULL( goOOoServiceManager ) PUBLIC goOOoServiceManager goOOoServiceManager = CREATEOBJECT( "com.sun.star.ServiceManager" ) ENDIF RETURN goOOoServiceManager ENDFUNC * Sugar coated routine to ask the service manager to * create you an instance of some other OpenOffice.org UNO object. FUNCTION OOoServiceManager_CreateInstance( cServiceName ) LOCAL oServiceManager oServiceManager = OOoGetServiceManager() LOCAL oInstance oInstance = .NULL. LOCAL cOldErrHandler cOldErrHandler = ON( "ERROR" ) ON ERROR = DoNothing__ErrorHandler( ERROR(), MESSAGE(), LINENO(), SYS(16), PROGRAM(), SYS(2018) ) oInstance = oServiceManager.createInstance( cServiceName ) ON ERROR &cOldErrHandler IF ISNULL( oInstance ) =__OOoReleaseCachedVars() oServiceManager = OOoGetServiceManager() oInstance = oServiceManager.createInstance( cServiceName ) ENDIF RETURN oInstance ENDFUNC PROCEDURE DoNothing__ErrorHandler( pnError, pcErrMessage, pnLineNo, pcProgramFileSys16, pcProgram, pcErrorParamSys2018 ) ENDPROC PROCEDURE __OOoReleaseCachedVars() RELEASE goOOoServiceManager, goOOoDesktop, goOOoCoreReflection ENDPROC * Convert a local filename to an OOo URL. FUNCTION OOoConvertToURL( cFilename ) * Ensure leading slash. IF LEFT( cFilename, 1 ) != "/" cFileName = "/" + cFileName ENDIF LOCAL cURL cURL = CHRTRAN( cFilename, "\", "/" ) && change backslashes to forward slashes. cURL = "file://" + cURL RETURN cURL ENDFUNC а на форму с гридом вставил код: If AT("oo_proc", SET("PROCEDURE")) = 0 SET PROCEDURE TO oo_proc ADDITIVE EndIf LOCAL i, lcAlias, lcField LOCAL loDoc, loSheet, loBorderLine LOCAL ARRAY laArgs[1] IF RECCOUNT(ThisForm.pageframe1.page1.grid1.RecordSource)>0 * Откроем OO Calc с "пустым" документом loDoc = OOoOpenURL("private:factory/scalc") * Прячем окно Calc'а чтобы пользователь не видел процесс заполнения loDoc.GetCurrentController.GetFrame.GetContainerWindow.SetVisible(.T.) * Выбираем первый лист loSheet = loDoc.getSheets().getByIndex( 0 ) WITH loSheet * Название отчета * Объединим ячейки под заголовок .getCellRangeByPosition(0, 0, ThisForm.pageframe1.page1.grid1.ColumnCount-1, 0).Merge(.T.) * Размер шрифта 11 .getCellByPosition( 0, 0).charHeight=11 * "Жирный" шрифт (обычный - 100) .getCellByPosition( 0, 0).charWeight=200 * Выравнивание "по горинтали" - по центру .getCellByPosition( 0, 0).HoriJustify=2 && по центру * Выравнивание "по вертикали" - по центру .getCellByPosition( 0, 0).VertJustify=2 && по центру * Пишем текст в ячейку .getCellByPosition( 0, 0).SetString(ThisForm.Caption) * Формируем "шапку" таблицы FOR i=1 TO ThisForm.pageframe1.page1.grid1.ColumnCount .getCellByPosition( i-1, 2).SetString(ThisForm.pageframe1.page1.grid1.Columns(i).Header1.Caption) ENDFOR * Форматируем "шапку" таблицы * Работаем с диапазоном ячеек * Размер шрифта 11 .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, 2).charHeight=11 * "Жирный" шрифт (обычный - 100) .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, 2).charWeight=200 * Выравнивание "по горинтали" - по центру .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, 2).HoriJustify=2 && по центру * Выравнивание "по вертикали" - по центру .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, 2).VertJustify=2 && по центру .getRows.getByIndex(2).OptimalHeight(.T.) && автоподбор высоты lnRowNum=3 WAIT 'Идет формирование отчета...' WINDOW NOWAIT NOCLEAR lcAlias=ThisForm.pageframe1.page1.grid1.RecordSource SELECT (lcAlias) * Перебираем строки грида SCAN * Перебираем столбцы грида FOR i=1 TO ThisForm.pageframe1.page1.grid1.ColumnCount lcField=ThisForm.pageframe1.page1.grid1.Columns(i).ControlSource * Заполняем данные .getCellByPosition( i-1, lnRowNum).SetString(&lcField) ENDFOR lnRowNum=lnRowNum+1 ENDSCAN FOR i=1 TO ThisForm.pageframe1.page1.grid1.ColumnCount * автоподбор ширины столбца .getColumns.getByIndex(i-1).OptimalWidth(.T.) ENDFOR * Рисование таблицы loBorderLine = OOoCreateStruct("com.sun.star.table.BorderLine") loBorderLine.color=RGB(0,0,0) loBorderLine.lineDistance=0 loBorderLine.innerLineWidth=0 loBorderLine.outerLineWidth=1 .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, lnRowNum-1).leftBorder=loBorderLine .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, lnRowNum-1).rightBorder=loBorderLine .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, lnRowNum-1).topBorder=loBorderLine .getCellRangeByPosition( 0, 2, ThisForm.pageframe1.page1.grid1.ColumnCount-1, lnRowNum-1).bottomBorder=loBorderLine WAIT CLEAR * Делаем сформированный отчет видимым loDoc.getCurrentController.getFrame.getContainerWindow.SetVisible(.T.) ENDWITH ELSE =MESSAGEBOX("Нет данных!",0+48+0,"Внимание") ENDIF В результате запускается calc только с шапкой таблицы грид, и выводится сообщение о программной ошибке OLE IDsdpatch exeption code 1001 from[automation bridge]: InterfaceOleWrapper_Impl::Invoke: [automation bridge]UnoConversionUtilites<T>:variantToAny The provided VARIANT of type"7" is unappropriate for.... ошибку указывает на .getCellByPosition( i-1, lnRowNum).SetString(&lcField) подскажите где делаю не так? ... |
| 26.12.2015, 19:17 |
а, уточню, если в окне с сообщением об ошибке понажимать кнопку Ignore, то таблица grid в calc експрортируется.. Что означает програмная ошибка? OLE IDsdpatch exeption code 1001 from[automation bridge]: InterfaceOleWrapper_Impl::Invoke: [automation bridge]UnoConversionUtilites<T>:variantToAny The provided VARIANT of type"7" is unappropriate for.... ... |
| 27.12.2015, 18:24 |
Это ошибка офиса. Если правильно понял, то какое-то значение не может записать. Например пустая дата во многих системах отсутствует. Остановись на ошибке и посмотри отладчиком. ... |
| 27.12.2015, 19:16 |
start [/forum/topic.php?fid=41&gotonew=1&tid=1582195]: |
137ms |
28ms |
| others: | 208ms |
| total: | 407ms |
