firebird-linux-i386 2.0.0.6404.Alpha1
Ну что, буду первым психопатом, который это установит :) Notes: ************** * v2.0 Alpha 1 ************** * C/C++ client interface version added FB_API_VER defined to 20 for Firebird 2.0 in ibase.h Contributor(s): Nickolay Samofatov * Implemented EXECUTE BLOCK statement It is now possible to use dynamic PSQL with this statement Contributor(s): Vlad Horsun * Implemented support for default parameters for stored procedures Contributor(s): Vlad Horsun * DSQL parser changed It now always detects table aliases ambiguity and abandoned support for implicit double table aliases Contributor(s): Arno Brinkman * Fixed unregistered bug Problems with interdependent views during restore process Contributor(s): Arno Brinkman * Fixed SF #750664 Issues with read-only databases and transactions Contributor(s): Nickolay Samofatov * Fixed unregistered bug Fixed memory leak from connection pool in isc_database_info Contributor(s): Nickolay Samofatov * Per-segment index selectivity maintenance Per-segment selectivity information is now available to the optimizer opening possibilities for more clever access path decisions Contributor(s): Dmitry Yemanov Arno Brinkman * Fixed/re-worked invariant tracking in PSQL and request cloning logic This fixes numerous issues with recursive procedures, for example SF #627057 Contributor(s): Nickolay Samofatov * Re-worked logic of updatable views This solves problems with views that are implicitly updatable, but still have update triggers Contributor(s): Dmitry Yemanov * Added SQL200X ROWS clause New syntax to limit amount of records you want to get Contributor(s): Dmitry Yemanov * Fixed SF #781610 Problems with -- comments in ISQL Contributor(s): John Bellardo Blas Rodriguez Somoza * Support for explicit cursor syntax in PSQL It is now possible to declare and use multiple cursors in PSQL Contributor(s): Dmitry Yemanov * LIKE/CONTAINING/STARTING WITH functions re-worked 1) functions now work with BLOBs correctly 2) use single-pass Knuth-Morris-Pratt algorithm for pattern matching 3) fix crash when NULL is used as ESCAPE character for LIKE Contributor(s): Nickolay Samofatov * Fixed unregistered bug Fixed server crash with explicit plans used in subqueries, when outer aggregation is performed. Contributor(s): Dmitry Yemanov * Nulls ordering is changed to be SQL200X-compliant (SF #225218) Implemented nulls placement behavior is MSSQL-like, works on ODS11 databases only since it requires new indices for operation. Contributor(s): Nickolay Samofatov * Enable support for databases on raw devices You can now use raw devices to store database. Exceptionally usable with database aliases Contributor(s): Erik Kunze Nickolay Samofatov * New indices code Very fast, nicely tolerates large amount of duplicates, limit of 256 bytes key length removed Contributor(s): Arno Brinkman * Internal logging enhanced 1) Implemented thread- and signal- safe debug logging facilities 2) Updated routines that print out various internal structures (DSQL node tree, BLR, DYN, etc) Contributor(s): Nickolay Samofatov * Improved PLAN clause Allowed to specify more possible paths for the engine Contributor(s): Dmitry Yemanov * Further optimizer improvements 1) MERGE PLAN is may now be generated for joins using equality comparsion on expressions 2) Better logic regarding unique indices handling 3) Improved logic for OR expressions Contributor(s): Arno Brinkman * New local protocol XNET is now used as default local protocol for Windows and is supported in CS builds Contributor(s): Dmitry Yemanov * Services API are fully ported to Classic architecture All Services API are supported on Linux and Windows CS Contributor(s): Nickolay Samofatov * SUBSTRING enhanced SUBSTRING built-in function now supports arbitrary expressions in parameters Contributor(s): Dmitry Yemanov * Added LEAVE syntax support PSQL loops now may be marked with labels and terminated in Java style Contributor(s): Dmitry Yemanov * Fix SF #750659 Generators values were resisting metadata-only backup Contributor(s): Claudio Varderrama * Fix SF #544132, #728839 Problems with nulls handling in UDFs Contributor(s): Claudio Varderrama * Fix SF #784121 Problems with some expressions in outer join conditions Contributor(s): Claudio Varderrama * Slightly reworked synchronization logic 1) Significantly reduce thread lock contention in lock manager and in SuperServer thread pool manager 2) Fix rare race condition that could cause SS engine to hang during request processing until next request arrival 3) Make lock manager memory dumps more informative (OWN_hung is detected correctly) 4) Decouple lock manager synchronization objects for different engine instances Contributor(s): Nickolay Samofatov * Derived tables support Implemented support for derived tables in DSQL (subqueries in FROM clause) as defined by SQL200X Contributor(s): Arno Brinkman * Enhanced GROUP BY clause Implemented support for arbitrary expressions in GROUP BY clause Contributor(s): Arno Brinkman * New backup technology Implemented fast on-line physical incremental backup facilities Contributor(s): Nickolay Samofatov * Generic cleanup. Various cleaning and tidying up of code, warnings removal, 64-bitness cleanup, numerious minor bugfixes Contributor(s): Blas Rodriguez Somoza Dmitry Yemanov Nickolay Samofatov * Generic cleanup Large amount of ongoing code cleanup and style standartization. In particular, broken WAL and journalling code is fully cleaned out Contributor(s): Claudio Varderrama ... |
| 29.01.2004, 19:51 |
x.diabloНу что, буду первым психопатом, который это установит :) Пробуй, если интересно :) Только учти, от первой альфы до релиза, как минимум года полтора... ... |
| 29.01.2004, 20:13 |
видимо не первым :-) или ты думаешь создатели пишут код и не пробуют? я как понял у Самофатова один сервак работает основанный на коде второй версии. подтора года может и не полтора, но в общем еще не скоро, и многое еще возможно изменится. ... |
| 30.01.2004, 08:17 |
Хочется заметить, что это альфа-версия заявлена не была и не будет в течении еще нескольких месяцев. Я бы не рекомендовал автору исходного сообщения брать на себя такую смелость. ... |
| 30.01.2004, 10:42 |
* Derived tables support Implemented support for derived tables in DSQL (subqueries in FROM clause) as defined by SQL200X - интересно, на каком уровне? а виртуальные триггеры можно будет определять? Вообще, оч. мало информации - какое там будут общее направление? где узнать можно? ... |
| 30.01.2004, 14:01 |
А какая связь между подзапросом и триггерами? Быстро читаем стандарт на тему derived tables. ... |
| 30.01.2004, 16:22 |
start [/forum/topic.php?fid=40&gotonew=1&tid=1579253]: |
175ms |
62ms |
| others: | 244ms |
| total: | 534ms |
