Ошибка: A request to send or receive data was disallowed...
Бодрый день! Помогите разрешить проблему. Yaffil 885 SS Windows XP При коннекте валится сервис Yaffil'a в yaffil.log следующее: INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tXNET/xnet_error: read from map failed errno = 1067 \tThe process terminated unexpectedly. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tXNET/xnet_error: write to map error errno = 1067 \tThe process terminated unexpectedly. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tXNET/xnet_error: connect errno = 2 \tThe system cannot find the file specified. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tWNET/wnet_error: CreateFile errno = 2 \tThe system cannot find the file specified. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tINET/inet_error: connect errno = 10057, address = \tA request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tXNET/xnet_error: write to map error errno = 1067 \tThe process terminated unexpectedly. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tXNET/xnet_error: write to map error errno = 1067 \tThe process terminated unexpectedly. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tXNET/xnet_error: write to map error errno = 1067 \tThe process terminated unexpectedly. INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tREMOTE INTERFACE/gds__detach: Unsuccesful detach from database. \tUncommitted work may have been lost INTERBASE (Client)\tMon Aug 09 17:13:14 2004 \tXNET/xnet_error: write to map error errno = 1067 \tThe process terminated unexpectedly. Конечно, можете пинать, говорить что дело в настройках сети и послать на /topic/62083&hl=10057 (или еще куда) ...дело кажется в другом. Т.к. на этом же сервере, коннект к другой БД (аналогичной по структуре и аналогичной строкой коннекта) проходит нормально. Где грабли? :( ... |
| 09.08.2004, 14:27:18 |
UDF используются ? Best regards, Dnico. ... |
| 09.08.2004, 17:40:33 |
2Dnico да, используются если стоит копать в этом направлении, тогда встречный вопрос: как анрегистрить функции UDF'ов, при том, что не могу приконнектиться к БД (валится сервер) ... |
| 10.08.2004, 06:57:45 |
под FireBird законнектился, но пока не знаю, что будет дальше... ... |
| 10.08.2004, 07:21:21 |
вот же грабли... после того как подконнектился FireBird'ом получилось без проблем законнектиться Yaffili'ом Судя по всему такая ситуация произошла из-за нерегулярного b\r (БД удалённая). Спасибо тем, кто откликнулся ;) ... |
| 10.08.2004, 07:50:35 |
start [/forum/topic.php?fid=40&gotonew=1&tid=1578117]: |
178ms |
39ms |
| others: | 220ms |
| total: | 482ms |
