Ошибки в firebird.log
Добрый день firebird 2.5.7 Linux kurseddb 4.4.49-92.11-default #1 SMP Fri Feb 17 08:29:30 UTC 2017 (8f9478a) x86_64 x86_64 x86_64 GNU/Linux Возникают ошибки kurseddb Mon Apr 17 12:16:03 2017 Operating system call pthread_create failed. Error code 11 kurseddb Mon Apr 17 12:16:03 2017 operating system directive pthread_create failed Resource temporarily unavailable kurseddb Mon Apr 17 12:16:10 2017 Operating system call pthread_create failed. Error code 11 kurseddb Mon Apr 17 12:16:10 2017 Trace facility: can't start touch thread kurseddb Mon Apr 17 12:16:10 2017 Operating system call pthread_create failed. Error code 11 kurseddb Mon Apr 17 12:16:10 2017 Database: /opt/firebird/security2.fdb lock manager error operating system directive pthread_create failed Resource temporarily unavailable kurseddb Mon Apr 17 12:16:20 2017 Error in isc_attach_database() API call when working with security database lock manager error operating system directive pthread_create failed Resource temporarily unavailable kurseddb Mon Apr 17 12:16:47 2017 Operating system call pthread_create failed. Error code 11 kurseddb Mon Apr 17 12:16:47 2017 SRVR_multi_thread: shutting down due to unhandled exception kurseddb Mon Apr 17 12:16:47 2017 Could not start first worker thread - shutdown server kurseddb Mon Apr 17 12:16:47 2017 SRVR_multi_thread: forcefully disconnecting a port kurseddb Mon Apr 17 12:16:47 2017 Operating system call pthread_create failed. Error code 11 kurseddb Mon Apr 17 12:16:47 2017 operating system directive pthread_create failed Resource temporarily unavailable что такое и как бороться? ... |
| 17.04.2017, 12:47 |
http://man7.org/linux/man-pages/man3/pthread_create.3.html EAGAIN A system-imposed limit on the number of threads was encountered. There are a number of limits that may trigger this error: the RLIMIT_NPROC soft resource limit (set via setrlimit(2)), which limits the number of processes and threads for a real user ID, was reached; the kernel's system- wide limit on the number of processes and threads, /proc/sys/kernel/threads-max, was reached (see proc(5)); or the maximum number of PIDs, /proc/sys/kernel/pid_max, was reached (see proc(5)). Posted via ActualForum NNTP Server 1.5 ... |
| 17.04.2017, 12:58 |
не катит. kurseddb:/proc/sys/kernel # cat threads-max 385003 kurseddb:/proc/sys/kernel # cat pid_max 32768 на похожем сервере, с большей нагрузкой параметры те же проблем нет. ... |
| 17.04.2017, 13:08 |
kirill_sgне катит. Тогда у тебя проблема: сисадмин нужен. Posted via ActualForum NNTP Server 1.5 ... |
| 17.04.2017, 13:22 |
Dimitry Sibiryakov, Вы можете сказать, почему такую ошибку выдает firebird? ему не хватает 300000 потоков? ... |
| 17.04.2017, 13:23 |
kirill_sgВы можете сказать, почему такую ошибку выдает firebird? Какое слово в цитате выше (которую, судя по всему, ты прочитал только наполовину) тебе непонятно? Posted via ActualForum NNTP Server 1.5 ... |
| 17.04.2017, 13:41 |
Dimitry Sibiryakov, никакое не понятно. я не могу представить себе систему, которой не хватало бы 300000 потоков на процесс. Процессов я увеличил-не помогло. ... |
| 17.04.2017, 13:47 |
kirill_sgя не могу представить себе систему, которой не хватало бы 300000 потоков на процесс. А я не могу представить себе сисадмина, который не различает лимит "на систему" и "на процесс". Поэтому и сказал, что он (сисадмин) тебе нужен. Posted via ActualForum NNTP Server 1.5 ... |
| 17.04.2017, 13:53 |
Dimitry Sibiryakov, лимитов не стоит разумеется на firebird kurseddb:/etc/security # cat /proc/32649/limits Limit Soft Limit Hard Limit Units Max cpu time unlimited unlimited seconds Max file size unlimited unlimited bytes Max data size unlimited unlimited bytes Max stack size 8388608 unlimited bytes Max core file size 0 unlimited bytes Max resident set unlimited unlimited bytes Max processes 192426 192426 processes Max open files 1024 4096 files Max locked memory 65536 65536 bytes Max address space unlimited unlimited bytes Max file locks unlimited unlimited locks Max pending signals 192426 192426 signals Max msgqueue size 819200 819200 bytes Max nice priority 0 0 Max realtime priority 0 0 Max realtime timeout unlimited unlimited us ... |
| 17.04.2017, 14:00 |
[quot kirill_sg]kurseddb:/proc/sys/kernel # cat pid_max 32768[quot kirill_sg] kirill_sgkurseddb:/etc/security # cat /proc/ 32649 /limits Ы?.. Posted via ActualForum NNTP Server 1.5 ... |
| 17.04.2017, 16:35 |
start [/forum/topic.php?fid=40&gotonew=1&tid=1561630]: |
160ms |
32ms |
| others: | 234ms |
| total: | 470ms |
