Вопрос о причине возникновения ошибки
Удалось поковыряться с битой базой (все ковыряния производились из IBE). Запустил свип. Результат IBE: Код: powershell 1. 2. 3. Лог FB: SERVER Wed Aug 09 10:51:10 2017 Sweep is started by SYSDBA Database "database" OIT 763579, OAT 1098629, OST 1098629, Next 1098629 SERVER Wed Aug 09 11:21:13 2017 Database: D:\DB\DATABASE.FDB internal Firebird consistency check (cannot find record back version (291), file: vio.cpp line: 4016) SERVER Wed Aug 09 11:21:13 2017 Database: D:\DB\DATABASE.FDB internal Firebird consistency check (cannot find record back version (291), file: vio.cpp line: 4016) SERVER Wed Aug 09 11:21:13 2017 Error during sweep: internal Firebird consistency check (cannot find record back version (291), file: vio.cpp line: 4016) SERVER Wed Aug 09 11:21:13 2017 I/O error during "ReadFile" operation for file "D:\DB\DATABASE.FDB" Error while trying to read from file Неверный дескриптор. SERVER Wed Aug 09 11:21:13 2017 Database: D:\DB\DATABASE.FDB I/O error during "ReadFile" operation for file "D:\DB\DATABASE.FDB" Error while trying to read from file Неверный дескриптор. Запустил валидэйшн в режиме фулл: Результат IBE: Код: powershell 1. 2. 3. 4. 5. Лог FB: SERVER Wed Aug 09 11:28:57 2017 Database: database Chain for record 5349730 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:57 2017 Database: database Chain for record 5376665 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:57 2017 Database: database Chain for record 5385341 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:57 2017 Database: database Chain for record 9450692 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:57 2017 Database: database Chain for record 9455564 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:58 2017 Database: database Chain for record 9457453 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:58 2017 Database: database Chain for record 9457474 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:58 2017 Database: database Chain for record 9457500 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:58 2017 Database: database Chain for record 9457501 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:58 2017 Database: database Chain for record 9691256 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:59 2017 Database: database Chain for record 13440167 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:59 2017 Database: database Chain for record 13440168 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:28:59 2017 Database: database Chain for record 13440169 is broken in table MAPOBJECTS (334) SERVER Wed Aug 09 11:36:51 2017 INET/inet_error: read errno = 10054 SERVER Wed Aug 09 11:36:51 2017 INET/inet_error: read errno = 10054 SERVER Wed Aug 09 11:36:51 2017 Unable to complete network request to host "SERVER". Error reading data from the connection. SERVER Wed Aug 09 11:36:51 2017 Unable to complete network request to host "SERVER". Error reading data from the connection. Запустил бэкап с включенным грабадже коллекшн: Результат IBE: Код: powershell 1. 2. 3. 4. Лог FB: SERVER Wed Aug 09 12:53:42 2017 Database: D:\DB\DATABASE.FDB I/O error during "GetFileInformationByHandle" operation for file "D:\DB\DATABASE.FDB" Error while trying to access file Неверный дескриптор. SERVER Wed Aug 09 12:53:42 2017 Cannot dump the monitoring data I/O error during "GetFileInformationByHandle" operation for file "D:\DB\DATABASE.FDB" Error while trying to access file Неверный дескриптор. SERVER Wed Aug 09 13:05:33 2017 Database: D:\DB\DATABASE.FDB internal Firebird consistency check (cannot find record back version (291), file: vio.cpp line: 4016) SERVER Wed Aug 09 13:05:33 2017 I/O error during "ReadFile" operation for file "D:\DB\DATABASE.FDB" Error while trying to read from file Неверный дескриптор. SERVER Wed Aug 09 13:05:33 2017 Database: D:\DB\DATABASE.FDB I/O error during "ReadFile" operation for file "D:\DB\DATABASE.FDB" Error while trying to read from file Неверный дескриптор. Файла бэкапа не осталось. Запустил бэкап с отключенным грабадже коллекшн - ошибок нет, база нормально отресторилась. Спасибо за помощь в данном вопросе. С уважением, Polesov. ... |
| 09.08.2017, 13:41 |
PolesovЗапустил бэкап с включенным грабадже коллекшн: Может быть выключенным. -g отключает сборку мусора gbak'ом, а не включает её ... |
| 09.08.2017, 13:48 |
Симонов ДенисPolesovЗапустил бэкап с включенным грабадже коллекшн: Может быть выключенным. -g отключает сборку мусора gbak'ом, а не включает её Ну, я запускал бэкап из IBE - там в опциях на группировке "General" четвертый сверху чекбокс "Garbage collection". Он, я так понимаю, соответствует опции -g gbak. При включенном чекбоксе бэкап вываливался по ошибке, при выключенном - прошел нормально. ... |
| 09.08.2017, 13:54 |
Polesov, опция в gbak Код: plaintext Т.е. если её указать , то коннект gbak'а не будет собирать мусор. В IBE галка имеет противоположный смысл, поэтому, если её выключить, то это будет эквивалентно присутствующей опции gbak. ... |
| 09.08.2017, 14:13 |
PolesovУдалось поковыряться с битой базойПроверь ещё раз FW у этой БД ... |
| 09.08.2017, 14:14 |
hvladPolesov, опция в gbak Код: plaintext Т.е. если её указать , то коннект gbak'а не будет собирать мусор. В IBE галка имеет противоположный смысл, поэтому, если её выключить, то это будет эквивалентно присутствующей опции gbak. Именно так и получилось - бэкап битой базы без сборки мусора завершился без ошибок. hvladПроверь ещё раз FW у этой БД Включен Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. ... |
| 10.08.2017, 10:02 |
start [/forum/topic.php?fid=40&gotonew=1&tid=1561464]: |
25ms |
39ms |
| others: | 235ms |
| total: | 356ms |
