Начался Cache' 5.2 Field Test
Cache' 5.2 Field Test software is now available for download for the following platforms: Microsoft Windows XP Professional (SP1, SP2)(32 bit) Microsoft Windows Server 2003 (SP1)(32 bit) Apple Mac OS X 10.4 HP OpenVMS OpenVMS 8.2 (Alpha) RedHat Linux (32-bit) - Advanced Server 4.0 Please see http://www.intersystems.com/cache/fieldtest to download the Field Test kits, key, and release notes. You will need to use your WRC Online login to access this page. Вадим ... |
| 04.04.2006, 09:46:08 |
Вадим ... |
| 05.04.2006, 11:52:20 |
Скачивать кота в мешке на 300 мег когда еще от 5.1 шок не прошел? Ради чего? Можно посмотреть список фич? ... |
| 05.04.2006, 12:02:25 |
The following features have been added to Caché for the 5.2 release: • Jalapeno • Caché Managed Provider for .net • IEEE 8-byte Floating Point Support • Direct FileMan Dictionary Converter • Code Completion in Caché Studio • Process-Private Globals • Caché Journal File Encryption • Optimistic Concurrency • Dynamic Dispatch • Free Text Search • ODBC Multiple Result Sets • WMI Support • Enhanced Debugging Capabilities • T-SQL Support • Device Level SSL and TLS support Caché 5.2 Release Notes 1 • Enhanced ECP Performance • Enhanced Windows Cluster Resource Management • Improved RPM Linux Installation Документ, подробно описывающий новые возможности Caché 5.2 находится в портале beta-тестирования. Вместе с дистрибутивом. Вадим ... |
| 05.04.2006, 13:46:07 |
start [/forum/topic.php?fid=39&gotonew=1&tid=1559598]: |
25ms |
52ms |
80ms |
| others: | 388ms |
| total: | 625ms |
