Ошибка журнала.
Добрый день. Понятно, что не находит сетевую папку, но я ее и не задал ... Как исправить? Где копать ? WIJ: Netmap Failed Спасибо. ... |
| 21.03.2011, 08:42:50 |
Ошибка журнала.
Ну вы хоть бы побольше обстоятельств написали бы. ... |
| 21.03.2011, 08:56:34 |
Ошибка журнала.
*** Recovery started at Mon Mar 21 07:31:02 2011 Current default directory: /usr/cachesys/mgr Log file directory: /usr/cachesys/mgr/ WIJ file spec: ./CACHE.WIJ Recovering local (./CACHE.WIJ) image journal file... Starting WIJ recovery for './CACHE.WIJ'. 0 blocks pending in this WIJ. Exiting with status 3 (Success) 03/21-07:31:10:712 ( 0) Jrn info from prior WIJ (imflags: 0): fspec: /usr/cachesys/mgr/journal/20110321.001 filecnt: 13 fileoff: 0 min trans cnt: 13 min trans index: 175544 03/21-07:31:10:723 (13218) Write daemon started. 03/21-07:31:10:725 (13191) CSTART of Cache for UNIX (Linux Intel/32-bit) 5.0 (RC 2 Build 434) Fri Oct 4 2002 03:19:17 EDT. in /usr/cachesys/mgr with wij: /usr/cachesys/mgr/CACHE.WIJ from: /usr/cachesys/mgr/ OS=[Linux], version=[#1 SMP Fri Apr 2 15:37:44 EDT 2010], release=[2.6.18-194.el5PAE], machine=[i686] 03/21-07:31:10:726 (13191) nodename=[Database.GTM]. directio: off, synctype: 3 System Initialized. 03/21-07:31:12:647 (13236) Performing Journal Recovery 03/21-07:31:12:648 (13236) Nothing to restore from the journal 03/21-07:31:12:648 (13236) Performing Transaction Rollback 03/21-07:31:12:657 (13236) Processing Net section 03/21-07:31:12:657 (13236) Processing License section 03/21-07:31:12:661 (13236) Processing Datasets section 03/21-07:31:12:666 (13236) .../usr/cachesys/mgr/cachetemp/ initialized as CACHETEMP 03/21-07:31:12:667 (13236) Processing Namespace section 03/21-07:31:12:668 (13237) LMF Info: License manager started on port 4001 03/21-07:31:12:690 (13236) Processing CSP Applications section 03/21-07:31:12:691 (13236) Starting Network 03/21-07:31:12:728 (13236) Activating Namespaces 03/21-07:31:12:786 (13236) Now translating dataset names 03/21-07:31:13:023 (13236) Now activating namespace configuration CACHE 03/21-07:31:13:187 (13236) Namespace configuration CACHE has been activated 03/21-07:31:13:191 (13236) Network Lock Upload Phase Starting 03/21-07:31:13:191 (13236) Lock Upload Phase Complete. 03/21-07:31:13:191 (13236) Processing Language section 03/21-07:31:13:191 (13236) Processing Locale Information 03/21-07:31:13:195 (13236) Processing Startup section 03/21-07:31:13:196 (13236) Max Journal Size: 1073741824 03/21-07:31:13:197 (13236) START: /usr/cachesys/mgr/journal/20110321.002 03/21-07:31:13:208 (13236) Journaling selected globals to /usr/cachesys/mgr/journal/20110321.002 started. 03/21-07:31:13:208 (13236) Processing Devices section 03/21-07:31:13:209 (13218) WIJ: Netmap Failed!! 03/21-07:31:13:212 (13236) Loading custom device mapping tables ... 03/21-07:31:13:212 (13236) Processing DeviceSubTypes section 03/21-07:31:13:213 (13236) Processing MagTape section 03/21-07:31:13:213 (13236) Processing IO section 03/21-07:31:15:349 (13236) Processing SQL section 03/21-07:31:15:350 (13236) Processing CSP section 03/21-07:31:15:352 (13236) Processing SQL Gateway Connections section 03/21-07:31:15:352 (13236) Processing Miscellaneous section 03/21-07:31:15:352 (13236) Processing Library section 03/21-07:31:15:400 (13236) Enabling logons 03/21-07:31:15:401 (13241) Processing Shadowing section 03/21-07:31:15:402 (13241) Processing BMC Patrol section 03/21-07:31:15:408 (13241) Purging old application errors 03/21-07:31:17:733 (13237) LMF Info: Connected to license manager 127.0.0.1,4001 03/21-08:10:35:769 (13218) WIJ: Netmap Failed!! 03/21-08:33:45:397 (13218) WIJ: Netmap Failed!! 03/21-09:03:55:152 (13218) WIJ: Netmap Failed!! ... |
| 21.03.2011, 10:20:09 |
Ошибка журнала.
ECP, Shadow или что-то подобное есть? канал надежный? ... |
| 21.03.2011, 10:34:32 |
Ошибка журнала.
При установке разрешил опцию ЖУРНАЛИРОВАТЬ ВСЕ. Потом опцию снял, перезапустил, но ничего не изменилось. Через определенный интервал выскакивают последние сообщения ... ... |
| 21.03.2011, 11:05:39 |
Ошибка журнала.
ValeriuCache for UNIX (Linux Intel/32-bit) 5.0 ( RC 2 Build 434) Fri Oct 4 2002 03:19:17 EDTВообще-то 5.0 была расчитана на ядро 2.4, насколько она совместима с 2.6 - х/з. Тем более релиз кандидат, от него чего угодно можно ждать. Ошибки WIJ не имеют отношения к журналу - это "журналирование до записи", если проводить аналогию с MSM (BIJ). CACHE.WIJ можно переместить в другую файловую систему и посмотреть на результат. Настраивается в Редакторе конфигурации, за давностью уже не помню где. По типам ф/c: нормально работает в ext2, ext3, ext4. ... |
| 21.03.2011, 11:36:05 |
Ошибка журнала.
авторTo Alexey Maslov А возможно это и за того, что я в конфигурации присвоил для: "Память для кэша базы данных(МБ)"=1024 ? Вернул 512 и это ошибка исчезла ... На моей машине RAM 4 Gb, те вполне есть откуда и 1024 . Спасибо. ... |
| 21.03.2011, 14:29:58 |
Ошибка журнала.
Да, судя по всему, эта версия молчит о том, насколько успешно прошел захват разделяемой памяти. По-видимому, SHMMAX был маловат для 1024Мб... ... |
| 21.03.2011, 14:52:07 |
Ошибка журнала.
Ну, я на всяком еще 256 добавил, те 768. Вроде молчит :) ... |
| 21.03.2011, 14:56:51 |
Ошибка журнала.
Тогда ясно, что был маловат. Должно быть как-то так: GlobCacheSize + RtnCacheSize + (128-256) <= SHMMAX <= SHMALL/2 но в старых версиях Cache for Linux нет гарантии резидентности кэша, а в новых версиях её обеспечение требует дополнительных училий, поэтому увеличивать надо с осторожностью. ... |
| 21.03.2011, 16:29:34 |
start [/forum/topic.php?fid=39&gotonew=1&tid=1557785]: |
25ms |
54ms |
94ms |
| others: | 462ms |
| total: | 705ms |
