V5.5-000 brings major new enhancements to GT.M
Новый релиз классического М http://www.fisglobal.com/products-technologyplatforms-gtm-infobulletins-c012279 http://groups.google.com/group/comp.lang.mumps/browse_thread/thread/da3d5b07e52300fe# ... |
| 23.02.2012, 21:53:21 |
V5.5-000 brings two major new enhancements to GT.M. A new type of replication, Supplementary Instance (SI) replication, allows replication to a supplementary instance which can execute its own business logic and commit database updates, to provide reporting, decision support, data warehousing, auditing, and more - all in real time. A technical bulletin is at http://tinco.pair.com/bhaskar/gtm/doc/articles/GTM_Supplementary_Inst... MUPIP REORG now has a TRUNCATE option, to return unused space at the end of a database file to the host file system, after operations such as data archival - even while the database continues in active use. There are other noteworthy enhancements as well, for example: A framework to allow GT.M to be extended with plugins, whether from FIS or others. In parallel with this release, FIS is providing a sample plugin which wraps zlib ( http://zlib.net) to compress strings in M code. Routine invocations using DO no longer require empty parentheses for calls with no actuallist. This change also improves the performance of routine invocation. The encryption reference plug-in supports a method to employ if key management requires the ability to pass an obfuscated password between unrelated processes, or even from one system to another. As usual, the release includes many smaller improvements and corrections. A more detailed announcement is at http://fisglobal.com/products-technologyplatforms-gtm-infobulletins-c... and the Release Notes are at http://tinco.pair.com/bhaskar/gtm/doc/articles/GTM_V5.5-000_Release_N... There is a fix to a bug exposed by VistA. While the application code from the VistA Surgery package that exposed the bug was unnecessarily convoluted and easily replaced with more readable code, it was legal code and reliably produced a segmentation violation in V5.4-002B. From the release notes, the relevant entry is: GT.M now handles nesting of XECUTE strings that contain subscripted FOR control variables. In V5.4-002x such constructs could result in a memory segmentation violation (UNIX SIG-11 or OpenVMS ACCVIO). (GTM-7007) Please do try V5.5-000 and let us know what you think. Regards -- Bhaskar ks dot bhaskar at fisglobal dot com <-- send e-mail here -- GT.M - Rock solid. Lightning fast. Secure. No compromises. ... |
| 23.02.2012, 21:57:52 |
start [/forum/topic.php?fid=39&gotonew=1&tid=1557528]: |
30ms |
74ms |
76ms |
| others: | 378ms |
| total: | 635ms |
