Помогите с фильтром по датам
Через ODBС с Informatica хочу выбрать данные по фильтру даты и не получается. как верное его задать? По всем этим условиям ошибка всегда: timestamp> cast('2012-11-10' as date) timestamp> '2012-11-10' timestamp> to_date('2012-11-10','YYYY-MM-DD') Thread: READER_1_1_1 Process ID: 12737 Message Code: RR_4035 Message: SQL Error [ FnName: Prepare -- [Cache ODBC][State : 37000][Native Code 4] [libcacheodbc.so] [SQLCODE: <-4>:<A term expected, beginning with one of the following: identifier, constant, aggregate, %ALPHAUP, %EXACT, %MVR, %SQLSTRING, %SQLUPPER, %STRING, %UPPER, $$, :, +, -, (, NOT, EXISTS, or FOR>] [Location: <Prepare>] [%msg: < A term expected, beginning with either of: (, NOT, EXISTS, or FOR^SELECT DBO . IAPPLICATIONSTAT . TIMESTAMP , DBO . IAPPLICATIONSTAT . APPLICATIONID , DBO . IAPPLICATIONSTAT . APPLICATION , DBO . IAPPLICATIONST]. как же верно его задать? ... |
| 12.11.2012, 19:17:52 |
Так как правильно задать фильтр в PC Informatica ? Как не задаю ошибка: SQ instance [SQ_IAPPLICATIONSTAT] SQL Query [SELECT DBO.IAPPLICATIONSTAT.TIMESTAMP, DBO.IAPPLICATIONSTAT.APPLICATIONID, DBO.IAPPLICATIONSTAT.APPLICATION, DBO.IAPPLICATIONSTAT.CALLSABANDONED, DBO.IAPPLICATIONSTAT.CALLSABANDONEDAFTTHRESHOLD, DBO.IAPPLICATIONSTAT.CALLSABANDONEDDELAY, DBO.IAPPLICATIONSTAT.CALLSANSWERED, DBO.IAPPLICATIONSTAT.CALLSANSWEREDAFTTHRESHOLD, DBO.IAPPLICATIONSTAT.CALLSANSWEREDDELAY, DBO.IAPPLICATIONSTAT.CALLSANSWEREDDELAYATSKILLSET, DBO.IAPPLICATIONSTAT.CALLSCONFERENCEDIN, DBO.IAPPLICATIONSTAT.CALLSCONFERENCEDOUT, DBO.IAPPLICATIONSTAT.CALLSGIVENBROADCAST, DBO.IAPPLICATIONSTAT.CALLSGIVENDEFAULT, DBO.IAPPLICATIONSTAT.CALLSGIVENFORCEBUSY, DBO.IAPPLICATIONSTAT.CALLSGIVENFORCEDISCONNECT, DBO.IAPPLICATIONSTAT.CALLSGIVENFORCEOVERFLOW, DBO.IAPPLICATIONSTAT.CALLSGIVENHOSTLOOKUP, DBO.IAPPLICATIONSTAT.CALLSGIVENIVR, DBO.IAPPLICATIONSTAT.CALLSGIVENMUSIC, DBO.IAPPLICATIONSTAT.CALLSGIVENNACD, DBO.IAPPLICATIONSTAT.CALLSGIVENRAN, DBO.IAPPLICATIONSTAT.CALLSGIVENROUTETO, DBO.IAPPLICATIONSTAT.CALLSNACDOUT, DBO.IAPPLICATIONSTAT.CALLSOFFERED, DBO.IAPPLICATIONSTAT.CALLSTRANSFERREDIN, DBO.IAPPLICATIONSTAT.CALLSTRANSFERREDOUT, DBO.IAPPLICATIONSTAT.IVRABANDONED, DBO.IAPPLICATIONSTAT.IVRTERMINATED, DBO.IAPPLICATIONSTAT.IVRTRANSFERRED, DBO.IAPPLICATIONSTAT.MAXCALLSABANDONEDDELAY, DBO.IAPPLICATIONSTAT.MAXCALLSANSDELAY, DBO.IAPPLICATIONSTAT.MAXCALLSANSDELAYATSKILLSET, DBO.IAPPLICATIONSTAT.MAXNETOUTCALLSABANDONEDDELAY, DBO.IAPPLICATIONSTAT.MAXNETOUTCALLSANSWEREDDELAY, DBO.IAPPLICATIONSTAT.NETOUTCALLS, DBO.IAPPLICATIONSTAT.NETOUTCALLSABANDONED, DBO.IAPPLICATIONSTAT.NETOUTCALLSABANDONEDDELAY, DBO.IAPPLICATIONSTAT.NETOUTCALLSANSWERED, DBO.IAPPLICATIONSTAT.NETOUTCALLSANSWEREDDELAY, DBO.IAPPLICATIONSTAT.NETOUTCALLSREACHNONISDN, DBO.IAPPLICATIONSTAT.TIMEBEFOREDEFAULT, DBO.IAPPLICATIONSTAT.TIMEBEFOREFORCEBUSY, DBO.IAPPLICATIONSTAT.TIMEBEFOREFORCEDISCONNECT, DBO.IAPPLICATIONSTAT.TIMEBEFOREFORCEOVERFLOW, DBO.IAPPLICATIONSTAT.TIMEBEFOREINTERFLOW, DBO.IAPPLICATIONSTAT.TIMEBEFOREIVRTRANSFERRED, DBO.IAPPLICATIONSTAT.TIMEBEFORENACDOUT, DBO.IAPPLICATIONSTAT.TIMEBEFORENETOUT, DBO.IAPPLICATIONSTAT.TIMEBEFOREREACHNONISDN, DBO.IAPPLICATIONSTAT.TIMEBEFOREROUTETO, DBO.IAPPLICATIONSTAT.POSTCALLPROCESSINGTIME, DBO.IAPPLICATIONSTAT.TALKTIME, DBO.IAPPLICATIONSTAT.WAITTIME, DBO.IAPPLICATIONSTAT.DNOUTEXTCALLSTALKTIME, DBO.IAPPLICATIONSTAT.DNOUTINTCALLSTALKTIME, DBO.IAPPLICATIONSTAT.ABDDELAY2, DBO.IAPPLICATIONSTAT.ABDDELAY4, DBO.IAPPLICATIONSTAT.ABDDELAY6, DBO.IAPPLICATIONSTAT.ABDDELAY8, DBO.IAPPLICATIONSTAT.ABDDELAY10, DBO.IAPPLICATIONSTAT.ABDDELAY12, DBO.IAPPLICATIONSTAT.ABDDELAY14, DBO.IAPPLICATIONSTAT.ABDDELAY16, DBO.IAPPLICATIONSTAT.ABDDELAY18, DBO.IAPPLICATIONSTAT.ABDDELAY20, DBO.IAPPLICATIONSTAT.ABDDELAY22, DBO.IAPPLICATIONSTAT.ABDDELAY24, DBO.IAPPLICATIONSTAT.ABDDELAY26, DBO.IAPPLICATIONSTAT.ABDDELAY28, DBO.IAPPLICATIONSTAT.ABDDELAY30, DBO.IAPPLICATIONSTAT.ABDDELAY32, DBO.IAPPLICATIONSTAT.ABDDELAY34, DBO.IAPPLICATIONSTAT.ABDDELAY36, DBO.IAPPLICATIONSTAT.ABDDELAY38, DBO.IAPPLICATIONSTAT.ABDDELAY40, DBO.IAPPLICATIONSTAT.ABDDELAY42, DBO.IAPPLICATIONSTAT.ABDDELAY44, DBO.IAPPLICATIONSTAT.ABDDELAY46, DBO.IAPPLICATIONSTAT.ABDDELAY48, DBO.IAPPLICATIONSTAT.ABDDELAY50, DBO.IAPPLICATIONSTAT.ABDDELAY52, DBO.IAPPLICATIONSTAT.ABDDELAY54, DBO.IAPPLICATIONSTAT.ABDDELAY56, DBO.IAPPLICATIONSTAT.ABDDELAY58, DBO.IAPPLICATIONSTAT.ABDDELAY60, DBO.IAPPLICATIONSTAT.ABDDELAY70, DBO.IAPPLICATIONSTAT.ABDDELAY80, DBO.IAPPLICATIONSTAT.ABDDELAY90, DBO.IAPPLICATIONSTAT.ABDDELAY100, DBO.IAPPLICATIONSTAT.ABDDELAY110, DBO.IAPPLICATIONSTAT.ABDDELAY120, DBO.IAPPLICATIONSTAT.ABDDELAY130, DBO.IAPPLICATIONSTAT.ABDDELAY140, DBO.IAPPLICATIONSTAT.ABDDELAY150, DBO.IAPPLICATIONSTAT.ABDDELAY160, DBO.IAPPLICATIONSTAT.ABDDELAY170, DBO.IAPPLICATIONSTAT.ABDDELAY180, DBO.IAPPLICATIONSTAT.ABDDELAY190, DBO.IAPPLICATIONSTAT.ABDDELAY200, DBO.IAPPLICATIONSTAT.ABDDELAY210, DBO.IAPPLICATIONSTAT.ABDDELAY220, DBO.IAPPLICATIONSTAT.ABDDELAY230, DBO.IAPPLICATIONSTAT.ABDDELAY240, DBO.IAPPLICATIONSTAT.ABDDELAY250, DBO.IAPPLICATIONSTAT.ABDDELAY260, DBO.IAPPLICATIONSTAT.ABDDELAY270, DBO.IAPPLICATIONSTAT.ABDDELAY280, DBO.IAPPLICATIONSTAT.ABDDELAY290, DBO.IAPPLICATIONSTAT.ABDDELAY300, DBO.IAPPLICATIONSTAT.ABDDELAY360, DBO.IAPPLICATIONSTAT.ABDDELAY420, DBO.IAPPLICATIONSTAT.ABDDELAY480, DBO.IAPPLICATIONSTAT.ABDDELAY540, DBO.IAPPLICATIONSTAT.ABDDELAY600, DBO.IAPPLICATIONSTAT.ABDDELAYBEYOND, DBO.IAPPLICATIONSTAT.ANSDELAY2, DBO.IAPPLICATIONSTAT.ANSDELAY4, DBO.IAPPLICATIONSTAT.ANSDELAY6, DBO.IAPPLICATIONSTAT.ANSDELAY8, DBO.IAPPLICATIONSTAT.ANSDELAY10, DBO.IAPPLICATIONSTAT.ANSDELAY12, DBO.IAPPLICATIONSTAT.ANSDELAY14, DBO.IAPPLICATIONSTAT.ANSDELAY16, DBO.IAPPLICATIONSTAT.ANSDELAY18, DBO.IAPPLICATIONSTAT.ANSDELAY20, DBO.IAPPLICATIONSTAT.ANSDELAY22, DBO.IAPPLICATIONSTAT.ANSDELAY24, DBO.IAPPLICATIONSTAT.ANSDELAY26, DBO.IAPPLICATIONSTAT.ANSDELAY28, DBO.IAPPLICATIONSTAT.ANSDELAY30, DBO.IAPPLICATIONSTAT.ANSDELAY32, DBO.IAPPLICATIONSTAT.ANSDELAY34, DBO.IAPPLICATIONSTAT.ANSDELAY36, DBO.IAPPLICATIONSTAT.ANSDELAY38, DBO.IAPPLICATIONSTAT.ANSDELAY40, DBO.IAPPLICATIONSTAT.ANSDELAY42, DBO.IAPPLICATIONSTAT.ANSDELAY44, DBO.IAPPLICATIONSTAT.ANSDELAY46, DBO.IAPPLICATIONSTAT.ANSDELAY48, DBO.IAPPLICATIONSTAT.ANSDELAY50, DBO.IAPPLICATIONSTAT.ANSDELAY52, DBO.IAPPLICATIONSTAT.ANSDELAY54, DBO.IAPPLICATIONSTAT.ANSDELAY56, DBO.IAPPLICATIONSTAT.ANSDELAY58, DBO.IAPPLICATIONSTAT.ANSDELAY60, DBO.IAPPLICATIONSTAT.ANSDELAY70, DBO.IAPPLICATIONSTAT.ANSDELAY80, DBO.IAPPLICATIONSTAT.ANSDELAY90, DBO.IAPPLICATIONSTAT.ANSDELAY100, DBO.IAPPLICATIONSTAT.ANSDELAY110, DBO.IAPPLICATIONSTAT.ANSDELAY120, DBO.IAPPLICATIONSTAT.ANSDELAY130, DBO.IAPPLICATIONSTAT.ANSDELAY140, DBO.IAPPLICATIONSTAT.ANSDELAY150, DBO.IAPPLICATIONSTAT.ANSDELAY160, DBO.IAPPLICATIONSTAT.ANSDELAY170, DBO.IAPPLICATIONSTAT.ANSDELAY180, DBO.IAPPLICATIONSTAT.ANSDELAY190, DBO.IAPPLICATIONSTAT.ANSDELAY200, DBO.IAPPLICATIONSTAT.ANSDELAY210, DBO.IAPPLICATIONSTAT.ANSDELAY220, DBO.IAPPLICATIONSTAT.ANSDELAY230, DBO.IAPPLICATIONSTAT.ANSDELAY240, DBO.IAPPLICATIONSTAT.ANSDELAY250, DBO.IAPPLICATIONSTAT.ANSDELAY260, DBO.IAPPLICATIONSTAT.ANSDELAY270, DBO.IAPPLICATIONSTAT.ANSDELAY280, DBO.IAPPLICATIONSTAT.ANSDELAY290, DBO.IAPPLICATIONSTAT.ANSDELAY300, DBO.IAPPLICATIONSTAT.ANSDELAY360, DBO.IAPPLICATIONSTAT.ANSDELAY420, DBO.IAPPLICATIONSTAT.ANSDELAY480, DBO.IAPPLICATIONSTAT.ANSDELAY540, DBO.IAPPLICATIONSTAT.ANSDELAY600, DBO.IAPPLICATIONSTAT.ANSDELAYBEYOND, DBO.IAPPLICATIONSTAT.TIME, DBO.IAPPLICATIONSTAT.SITEID, DBO.IAPPLICATIONSTAT.SITE, DBO.IAPPLICATIONSTAT.CONTACTTYPE FROM DBO.IAPPLICATIONSTAT WHERE timestamp> cast( {d '2012-11-10'} as date)] Thread: READER_1_1_1 Process ID: 1824 Message Code: RR_4049 Message: RR_4049 SQL Query issued to database : (Tue Nov 13 11:06:30 2012) Thread: READER_1_1_1 Process ID: 1824 Message Code: RR_4035 Message: SQL Error [ FnName: Prepare -- [Cache ODBC][State : 37000][Native Code 4] [libcacheodbc.so] [SQLCODE: <-4>:<A term expected, beginning with one of the following: identifier, constant, aggregate, %ALPHAUP, %EXACT, %MVR, %SQLSTRING, %SQLUPPER, %STRING, %UPPER, $$, :, +, -, (, NOT, EXISTS, or FOR>] [Location: <Prepare>] [%msg: < A term expected, beginning with either of: (, NOT, EXISTS, or FOR^SELECT DBO . IAPPLICATIONSTAT . TIMESTAMP , DBO . IAPPLICATIONSTAT . APPLICATIONID , DBO . IAPPLICATIONSTAT . APPLICATION , DBO . IAPPLICATIONST]. Как же задать? ... |
| 13.11.2012, 14:14:12 |
Малеваный , Достаточно WHERE timestamp> {d '2012-11-10'} Хотя у меня и Ваш вариант работает без проблем. Вы уверены, что ошибка именно из-за даты? Попробуйте вовсе удалить WHERE timestamp> cast( {d '2012-11-10'} as date) или заменить чем-нибудь простым, типа ID=1 : исчезнет ли ошибка? ... |
| 13.11.2012, 14:39:48 |
Полная выборка работает. Фильтр по полю where applicationid=10006 тоже отработало без ошибок. ... |
| 13.11.2012, 15:06:43 |
В Oracle, поле которое я фильтрую выглядит так: 13.11.12 02:00:00,000000 ... |
| 13.11.2012, 15:07:19 |
WHERE TIMESTAMP> {d '2012-13-10'}] При таком фильтре ошибка: SQL Error [ FnName: Prepare -- [Cache ODBC][State : 37000][Native Code 4] [libcacheodbc.so] [SQLCODE: <-4>:<A term expected, beginning with one of the following: identifier, constant, aggregate, %ALPHAUP, %EXACT, %MVR, %SQLSTRING, %SQLUPPER, %STRING, %UPPER, $$, :, +, -, (, NOT, EXISTS, or FOR>] [Location: <Prepare>] [%msg: < A term expected, beginning with either of: (, NOT, EXISTS, or FOR^SELECT DBO . IAPPLICATIONSTAT . TIMESTAMP , DBO . IAPPLICATIONSTAT . APPLICATIONID , DBO . IAPPLICATIONSTAT . APPLICATION , DBO . IAPPLICATIONST]. Может там нужно задавать с определенными настройками сессии? ... |
| 13.11.2012, 15:10:01 |
МалеваныйВ Oracle, поле которое я фильтрую выглядит так: 13.11.12 02:00:00,000000Попробуйте так: WHERE timestamp > {ts '2012-11-10 00:00:00'} PS: запрос вида WHERE timestamp IS NULL работает нормально? Если нет, я бы рекомендовал заключить зарезервированное слово "timestamp" в двойные кавычки. ... |
| 13.11.2012, 17:53:06 |
start [/forum/topic.php?fid=39&gotonew=1&tid=1557315]: |
55ms |
68ms |
| others: | 394ms |
| total: | 595ms |
