Caché CSP/ZEN & WebDAV
Has anyone already used Caché as a WebDAV-server. If yes, what's the best way to implement. ... |
| 04.05.2015, 16:01:12 |
Deja vu (06/23/2009) ... |
| 04.05.2015, 16:31:50 |
Kurt HofmanHas anyone already used Caché as a WebDAV-server. If yes, what's the best way to implement.Yes, we are using WebDAV in our project. It doesn't matter which WebServer to use. And is not so difficult to implement it in CachéObjectScript. ... |
| 04.05.2015, 17:14:36 |
DAiMor, Does it work with Office ? I mean opening and saving a Word-file ... |
| 04.05.2015, 20:24:55 |
Kurt HofmanDAiMor, Does it work with Office ? I mean opening and saving a Word-fileyes, it is main for what we use it ... |
| 04.05.2015, 20:31:23 |
DAiMor, Is the code in some way available ? ... |
| 04.05.2015, 20:49:04 |
Kurt HofmanDAiMor, Is the code in some way available ?unfortunately not, it can't be open ... |
| 04.05.2015, 20:53:45 |
DAiMor, And not open ... |
| 04.05.2015, 20:56:51 |
But I can say how to do it. First, just create simple class with %CSP.Page as super. second, in cspgateway settings, create new application which should be different from main application, or subfolder. and then need to set that class as a webpath in field "Process with this class", for example if your class is CSP.WebDAV.cls and your main csp application is "/myapp/" you should set "/myapp/CSP.WebDAV.cls". So application for webdav request could be "/myapp/webdav/" and in Apache for this path you should point that every request have to be sent to Caché with "CSP on" directive in <Directory> block. So, class "CSP.WebDAV" should implement WebDAV functionality. You should use some identifiers, in URL, for indentify concrete files. ... |
| 04.05.2015, 21:41:56 |
start [/forum/topic.php?fid=39&gotonew=1&tid=1556674]: |
43ms |
68ms |
| others: | 328ms |
| total: | 495ms |
