Помогите найти ошибки в XML Correlate
XML code:<GetMOInfoResponse xmlns=" http://myserver.com/serv/myServices/myServices/v1" > <GetMOInfoResult xmlns:a=" http://schemas.datacontract.org/2004/07/MYS.Business.Data.EService" xmlns:i=" http://www.w3.org/2001/XMLSchema-instance" > <a:dataSource>0</a:dataSource> <a:fullName>name</a:fullName> <a:id>1234567890</a:id> <a:stList> <a:stList> <a:MOSRStavkaByType> <a:personalTypeID>1</a:personalTypeID> <a:personalType>my type1</a:personalType> <a:stPlan>25.25</a:stPlan> </a:MOSRStavkaByType> <a:MOSRStavkaByType> <a:personalTypeID>2</a:personalTypeID> <a:personalType>my type 2</a:personalType> <a:stPlan>29.75</a:stPlan> </a:MOSRStavkaByType> </a:stList> <a:totalPersonalLoading>374.37</a:totalPersonalLoading> </a:stList> <a:urAddress>my address</a:urAddress> </GetMOInfoResult> </GetMOInfoResponse>Classes:Class getInf.model.GetResult Extends (%RegisteredObject, %XML.Adaptor) { Parameter XMLNAME = "GetResult"; Property dataSource As %xsd.unsignedByte(XMLNAME = "dataSource"); Property fullName As %String(MAXLEN = "", XMLNAME = "fullName"); Property id As %Integer(XMLNAME = "id"); Property stList As list Of getInf.model.MOSRStList(XMLITEMNAME = "MOSRStList", XMLNAME = "stList", XMLPROJECTION = "COLLECTION"); Property urAddress As %String(XMLNAME = "urAddress"); } Class getInf.model.MOSRStList Extends (%RegisteredObject, %XML.Adaptor) { Parameter XMLNAME = "MOSRStList"; Property stList As list Of getInf.model.MOSRStByType(XMLITEMNAME = "MOSRStByType", XMLNAME = "stList", XMLPROJECTION = "COLLECTION"); Property totalPersonalLoading As %xsd.double(XMLNAME = "totalPersonalLoading"); } Class getInf.model.MOSRStByType Extends (%RegisteredObject, %XML.Adaptor) { Parameter XMLNAME = "MOSRStavkaByType"; Property personalTypeID As %Integer(XMLNAME = "personalTypeID"); Property personalType As %String(MAXLEN = "", XMLNAME = "personalType"); Property stPlan As %xsd.double(XMLNAME = "stPlan"); } Запрос и Ошибка: Код: plaintext 1. 2. ... |
| 08.12.2015, 06:55:23 |
чтобы убедиться что все настроено верно для импорта, нужно попробовать экспортировать и посмотреть что получится, результат должен быть таким как то что импортируемClass getInf.model.GetResult Extends (%RegisteredObject, %XML.Adaptor) { Parameter XMLNAME = "GetMOInfoResult"; Property dataSource As %xsd.unsignedByte(XMLNAME = "dataSource"); Property fullName As %String(MAXLEN = "", XMLNAME = "fullName"); Property id As %Integer(XMLNAME = "id"); Property stList As getInf.model.MOSRStList(XMLITEMNAME = "MOSRStList", XMLNAME = "stList"); Property urAddress As %String(XMLNAME = "urAddress"); } Class getInf.model.MOSRStList Extends (%RegisteredObject, %XML.Adaptor) { Parameter XMLNAME = "stList"; Property stList As list Of getInf.model.MOSRStByType(XMLITEMNAME = "MOSRStavkaByType", XMLNAME = "stList", XMLPROJECTION = "COLLECTION"); Property totalPersonalLoading As %xsd.double(XMLNAME = "totalPersonalLoading"); } Class getInf.model.MOSRStByType Extends (%RegisteredObject, %XML.Adaptor) { Parameter XMLNAME = "MOSRStavkaByType"; Property personalTypeID As %Integer(XMLNAME = "personalTypeID"); Property personalType As %String(MAXLEN = "", XMLNAME = "personalType"); Property stPlan As %xsd.double(XMLNAME = "stPlan"); } ... |
| 08.12.2015, 08:58:35 |
DAiMor, теперь возникает следующая ошибка: ОШИБКА #6237: Неожиданный тег при XML вводе: MOSRStavkaByType (заканчивается в строке 1 символ 783). ... |
| 08.12.2015, 10:04:26 |
start [/forum/topic.php?fid=39&gotonew=1&tid=1556556]: |
40ms |
54ms |
| others: | 328ms |
| total: | 486ms |
