70-229: AFTER или INSTEAD OF ?
Кто как считает, А или D ? ========================================================= You are a database developer for an insurance company. Information about the company's insurance policies is stored in a SQL Server 2000 database. You create a table named policy for this database by using the script shown below: CREATE TABLE Policy ( PolicyNumber int NOT NULL DEFAULT (0), InsuredLastName char (30) NOT NULL, InsuredFirstName char (20) NOT NULL, InsuredBirthDate dattime NOT NULL, PolicyDate datetime NOT NULL, FaceAmount money NOT NULL, CONSTRAINT PK_Policy PRIMARY KEY (PolicyNumber) ) Each time the company sells a new policy, the policy must be assigned a unique policy number. The database must assign a new policy number when a new policy is entered. What should you do? A. Create an INSTEAD OF INSERT trigger to generate a new policy number, and include the policy number in the data instead into the table. B. Create an INSTEAD OF UPDATE trigger to generate a new policy number, and include the policy number in the data inserted into the table. C. Create an AFTER UPDATE trigger to generate a new policy number, and include the policy number in the data inserted into the table. D. Replace the DEFAULT constraint with a AFTER INSERT trigger that generates a new policy number and includes the policy number in the data inserted into the table. ========================================================= ... |
| 30.01.2003, 17:15:59 |
Думаю что A, потому как All referential cascade actions and constraint checks also must succeed before AFTER trigger executes ... |
| 30.01.2003, 17:28:55 |
start [/forum/topic.php?fid=34&gotonew=1&tid=1552117]: |
190ms |
59ms |
| others: | 220ms |
| total: | 530ms |
