лажа в вопросе к экзамену 1z0-042?
готовлюсь тут к экзамену 1z0-042: Your boss wants you to clarify Oracle 10g. Which two steps are performed the first time any UPDATE statement is issued after the instance is started? ... A. Creating the parse tree of the statement B. Writing the modified data blocks to the data files C. Writing the modified data blocks to the archived redo log files D. Updating the control file to indicate the most recent checkpoint E. Updating the data file header to indicate the most recent checkpoint F. Reading the blocks to database buffer cache if they are not already there Правильные ответы стоят У НИХ В ПДФ-е: "C" and "D". ИМХО, очень странно что "С". Я бы сказал скорее F вместо С. (т.е. правильные ответы: D,F) я не прав? ... |
| 26.06.2007, 20:57:29 |
где я не правготовлюсь тут к экзамену 1z0-042: Your boss wants you to clarify Oracle 10g. Which two steps are performed the first time any UPDATE statement is issued after the instance is started? ... A. Creating the parse tree of the statement B. Writing the modified data blocks to the data files C. Writing the modified data blocks to the archived redo log files D. Updating the control file to indicate the most recent checkpoint E. Updating the data file header to indicate the most recent checkpoint F. Reading the blocks to database buffer cache if they are not already there Правильные ответы стоят У НИХ В ПДФ-е: "C" and "D". ИМХО, очень странно что "С". Я бы сказал скорее F вместо С. (т.е. правильные ответы: D,F) я не прав? Оба не правы. Особенно, D. ... |
| 26.06.2007, 21:02:59 |
AI где я не правготовлюсь тут к экзамену 1z0-042: Your boss wants you to clarify Oracle 10g. Which two steps are performed the first time any UPDATE statement is issued after the instance is started? ... A. Creating the parse tree of the statement B. Writing the modified data blocks to the data files C. Writing the modified data blocks to the archived redo log files D. Updating the control file to indicate the most recent checkpoint E. Updating the data file header to indicate the most recent checkpoint F. Reading the blocks to database buffer cache if they are not already there Правильные ответы стоят У НИХ В ПДФ-е: "C" and "D". ИМХО, очень странно что "С". Я бы сказал скорее F вместо С. (т.е. правильные ответы: D,F) я не прав? Оба не правы. Особенно, D. какие же два по вашему правильные? ... |
| 26.06.2007, 22:09:38 |
Я б ответил A и F ... |
| 26.06.2007, 23:59:06 |
В маске рабаЯ б ответил A и F Ссогласен. Сразу после рестарта экземпляра в буфере данных еще нет блоков таблиц, которые будут затронуты операторами update, и нет разобранных SQL запросов в shared-пуле. Соответственно варианты A и F: парсинг операторов и чтение блоков данных. Варианты D,E неподходят так как чекпоинт не зависит напрямую от выполнения update Варианты B,C необязательно должны приводить к записи в файлы данных и архивные журналы ... |
| 27.06.2007, 09:46:53 |
оффтопик А объясните зачем в этом вопросе вводное предложение "Your boss wants you to clarify Oracle 10g."? И зачем вообще это боссу? ... |
| 27.06.2007, 10:05:39 |
так, мимо проходил А объясните зачем в этом вопросе вводное предложение "Your boss wants you to clarify Oracle 10g."? И зачем вообще это боссу? Да, ему это нафиг не нужно. :-) Так просто, для красного словца, дабы создать гипотетическую ситуацию. Разумеется, A, F - какие сомнения могут быть вообще? ... |
| 27.06.2007, 10:57:57 |
start [/forum/topic.php?fid=34&gotonew=1&tid=1549893]: |
166ms |
51ms |
| others: | 202ms |
| total: | 467ms |
