Как сделать свой стереотип в Rational Rose
Господа! Если кто знает, то подскажите плс, как сделать свой стереотип в Rational... Если быть точным, то интересует конкретно следующее: хочется на основе стереотипа "use-case" сделать свой, например "вариант использования", чтобы он обладал всеми свойствами "use-case", но имел другую иконку.... или хотябы просто сменить иконки у стереотипов... Заранее санкс ... |
| 06.10.2004, 17:46 |
Stereotype Configuration File A stereotype configuration file defines a set of stereotypes, including the location of icon files as well as settings that affect the usage and display of the defined stereotypes. Typically, the extension of a stereotype configuration file is .ini, but any extension is allowed. Each stereotype configuration file needs to be located in the Rational Rose installation folder, defined by the InstallDir registry value, and listed in the StereotypeCfgFiles registry section. Note: It is recommended that you add any new stereotypes to the default stereotype configuration file, DefaultStereotypes.ini. Below is a sample configuration file. The sample displays all of the available settings, but the default settings are typically all you need. Select a setting for an explanation of its possible values. Stereotype configuration file contents: [General] ConfigurationName =Objectory Process IsLanguageConfiguration =No [Stereotyped Items] Class:Control Class:Entity etc. [Class:Control] Item =Class Stereotype =Control LocalizedStereotype = Metafile =&/process/color/control.wmf ExtentX =200 ExtentY TextXPos =100 TextYPos =320 ListImages = ListIndex = SmallPaletteImages = SmallPaletteIndex = MediumPaletteImages = StereotypeIconStyle = DisplayStereotype = Version = ShowAllAttributes = ShowAllOperations = ShowOperationSignature = SupressAttributes = SupressOperations = ShowCompartmentStereotypes = AutomaticResize = ShowVisibility = TextWidth =180 TextJust =Center NameLines =3 Proportional =Yes CenteredResize =Yes ToolTip=Creates a Boundry Class\nBoundry Class LocalizedToolTip=Crйez une Classe De Borne\nClasse De Borne Copyright © 2000 Rational Software Corporation. All rights reserved. ... |
| 06.10.2004, 18:09 |
В файле DefaultStereotypes.ini опиши свой стереотип. В разделе [Stereotyped Items] пишешь: Use Case:My Use Case, потом добавляешь раздел описания: [Use Case:My Use Case] Item=Use Case Stereotype=My Use Case Metafile=&\stereotypes\color\rube_usecase_c.wmf Proportional=Yes AutomaticResize=Yes SuppressMethods=Yes SuppressProperties=Yes StereotypeIconStyle=Icon SmallPaletteImages=&\stereotypes\small\rube_usecase_s.bmp SmallPaletteIndex=1 MediumPaletteImages=&\stereotypes\medium\rube_usecase_m.bmp MediumPaletteIndex=1 ListImages=&\stereotypes\list\rube_usecase_l.bmp ListIndex=1 ToolTip=Creates a my use case\nMy use case Перезапускаешь Rose, добавляешь в Toolbar свой стереотип ... |
| 06.10.2004, 18:15 |
start [/forum/topic.php?fid=32&gotonew=1&tid=1546262]: |
61ms |
61ms |
| others: | 233ms |
| total: | 407ms |
