HyperCube индексы
В мануале к одной из СУБД прочитал о возможности создавать HyperCube индексы. Что за зверь такой? В инете что-то не найду информации на эту тему. Примерно понимаю что такое B-tree индексы, FullText индексы, а вот что за HyperCube индексы? ... |
| 04.08.2008, 11:44 |
HyperCube индексы
Манул к какой БД ? В самом мануале что было написано-то ? Гуглили ? http://cat.inist.fr/?aModele=afficheN&cpsidt=14404659: Abstract Only few multidimensional access methods have made their way into commercial relational DBMS. Even if a RDBMS ships with a multidimensional index, the multi-dimensional index usually is an add-on like Oracle SDO, which is not integrated into the SQL interpreter, query processor and query optimizer of the DBMS kernel. Our demonstration shows TransBase HyperCube, a commercial RDBMS, whose kernel fully integrates the UB-Tree, a multidimensional extension of the B-Tree. This integration was performed in an ESPRIT project funded by the European Commission. We put the main emphasis of our demonstration on the application of UB-Tree indexes in real-world databases for OLAP. However, we also address general issues of UB-Trees like creation, space-requirements, or comparison to other indexing methods. ... |
| 04.08.2008, 14:02 |
HyperCube индексы
Программист-ЛюбительМанул к какой БД ? К той которая упоминается в вами приведеном тексте. Программист-Любитель В самом мануале что было написано-то ? Мануал With the HyperCubeKeySpec clause and the HCKEY specification, a HyperCube tree can be specified instead of a standard compound B-tree. A HyperCube tree should have no fields as part of key which typically are not searched for - therefore fields and keys can be specified separately in this case. The specified keys are UNIQUE by default unless the ”NOT UNIQUE” clause is specified. The ”CREATE UNIQUE ..” formulation is not permitted if a HyperCubeKeySpec is given. All fields used as HyperCube key fields must be NOT NULL and must have a range check constraint in the underlying base table. ну и это почти все, а для чего/зачем, в чем выгода по сравнению с standard compound B-tree не сказано. Программист-ЛюбительГуглили ? Гуглю. ... |
| 04.08.2008, 14:41 |
HyperCube индексы
alexmspНу что-то нашел Но не совсем то ... |
| 05.08.2008, 12:19 |
start [/forum/search_topic.php?author=Sufir&author_mode=last_topics&do_search=1]: |
175ms |
40ms |
| others: | 665ms |
| total: | 951ms |
