ArgoUML и SQL
Здравствуйте. пробую поставить SQL plugin на ArgoUML Скачал и уставил ArgoUML Скачал dbuml-module закунул файлы в ext папку запустил ArgoUML и вижу в модулях SQL, но ничего в компонентах class diagram пробую запустить пример sample.zargo и получаю Error opening file : sample.zargo System Info: ArgoUML version : 0.32.2 Java Version : 1.6.0_21 Java Vendor : Sun Microsystems Inc. Java Vendor URL : http://java.sun.com/ Java Home Directory : D:\Program Files\Java\jre6 Java Classpath : D:\Program Files\ArgoUML\argouml.jar Operation System : Windows XP, Version 5.1 Architecture : x86 User Name : New User Home Directory : D:\Documents and Settings\New Current Directory : D:\Documents and Settings\New\My Documents\Downloads JVM Total Memory : 64946176 JVM Free Memory : 34536248 Error occurred at : Thu Nov 17 22:00:52 EET 2011 Cause : java.lang.ClassNotFoundException: org.dbuml.argo.uml.diagram.ui.DBDeploymentDiagram at org.tigris.gef.persistence.pgml.PGMLHandler.initDiagram(PGMLHandler.java:118) at org.tigris.gef.persistence.pgml.PGMLHandler. (PGMLHandler.java:76) at org.tigris.gef.persistence.pgml.InitialHandler.startElement(InitialHandler.java:65) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source) at javax.xml.parsers.SAXParser.parse(Unknown Source) at org.tigris.gef.persistence.pgml.PGMLStackParser.readDiagram(PGMLStackParser.java:166) at org.tigris.gef.persistence.pgml.PGMLStackParser.readDiagram(PGMLStackParser.java:128) at org.argouml.persistence.PGMLStackParser.readDiagram(PGMLStackParser.java:388) at org.argouml.persistence.PGMLStackParser.readArgoDiagram(PGMLStackParser.java:363) at org.argouml.persistence.DiagramMemberFilePersister.load(DiagramMemberFilePersister.java:116) at org.argouml.persistence.UmlFilePersister.doLoad(UmlFilePersister.java:378) at org.argouml.persistence.ZargoFilePersister.doLoad(ZargoFilePersister.java:260) at org.argouml.ui.ProjectBrowser.loadProject2(ProjectBrowser.java:1617) at org.argouml.application.Main.openProject(Main.java:504) at org.argouml.application.Main.main(Main.java:215) Caused by: java.lang.ClassNotFoundException: org.dbuml.argo.uml.diagram.ui.DBDeploymentDiagram at java.net.URLClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at org.tigris.gef.persistence.pgml.PGMLHandler.initDiagram(PGMLHandler.java:110) ... 26 more ------- Full exception : org.argouml.persistence.OpenException: java.lang.ClassNotFoundException: org.dbuml.argo.uml.diagram.ui.DBDeploymentDiagram at org.argouml.persistence.DiagramMemberFilePersister.load(DiagramMemberFilePersister.java:122) at org.argouml.persistence.UmlFilePersister.doLoad(UmlFilePersister.java:378) at org.argouml.persistence.ZargoFilePersister.doLoad(ZargoFilePersister.java:260) at org.argouml.ui.ProjectBrowser.loadProject2(ProjectBrowser.java:1617) at org.argouml.application.Main.openProject(Main.java:504) at org.argouml.application.Main.main(Main.java:215) Caused by: java.lang.ClassNotFoundException: org.dbuml.argo.uml.diagram.ui.DBDeploymentDiagram at org.tigris.gef.persistence.pgml.PGMLHandler.initDiagram(PGMLHandler.java:118) at org.tigris.gef.persistence.pgml.PGMLHandler. (PGMLHandler.java:76) at org.tigris.gef.persistence.pgml.InitialHandler.startElement(InitialHandler.java:65) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source) at javax.xml.parsers.SAXParser.parse(Unknown Source) at org.tigris.gef.persistence.pgml.PGMLStackParser.readDiagram(PGMLStackParser.java:166) at org.tigris.gef.persistence.pgml.PGMLStackParser.readDiagram(PGMLStackParser.java:128) at org.argouml.persistence.PGMLStackParser.readDiagram(PGMLStackParser.java:388) at org.argouml.persistence.PGMLStackParser.readArgoDiagram(PGMLStackParser.java:363) at org.argouml.persistence.DiagramMemberFilePersister.load(DiagramMemberFilePersister.java:116) ... 5 more Caused by: java.lang.ClassNotFoundException: org.dbuml.argo.uml.diagram.ui.DBDeploymentDiagram at java.net.URLClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at org.tigris.gef.persistence.pgml.PGMLHandler.initDiagram(PGMLHandler.java:110) ... 26 more java.lang.ClassNotFoundException: org.dbuml.argo.uml.diagram.ui.DBDeploymentDiagram at java.net.URLClassLoader$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source) at java.lang.ClassLoader.loadClass(Unknown Source) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Unknown Source) at org.tigris.gef.persistence.pgml.PGMLHandler.initDiagram(PGMLHandler.java:110) at org.tigris.gef.persistence.pgml.PGMLHandler. (PGMLHandler.java:76) at org.tigris.gef.persistence.pgml.InitialHandler.startElement(InitialHandler.java:65) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source) at javax.xml.parsers.SAXParser.parse(Unknown Source) at org.tigris.gef.persistence.pgml.PGMLStackParser.readDiagram(PGMLStackParser.java:166) at org.tigris.gef.persistence.pgml.PGMLStackParser.readDiagram(PGMLStackParser.java:128) at org.argouml.persistence.PGMLStackParser.readDiagram(PGMLStackParser.java:388) at org.argouml.persistence.PGMLStackParser.readArgoDiagram(PGMLStackParser.java:363) at org.argouml.persistence.DiagramMemberFilePersister.load(DiagramMemberFilePersister.java:116) at org.argouml.persistence.UmlFilePersister.doLoad(UmlFilePersister.java:378) at org.argouml.persistence.ZargoFilePersister.doLoad(ZargoFilePersister.java:260) at org.argouml.ui.ProjectBrowser.loadProject2(ProjectBrowser.java:1617) at org.argouml.application.Main.openProject(Main.java:504) at org.argouml.application.Main.main(Main.java:215) ну скорей всего изза того что он всётаки не установлен правильно. Информация об установке находиться тут http://argouml-db.tigris.org/documentation/DB_UML_Guide.htm Помогите пожалуйста запустить это дело... ... |
| 18.11.2011, 00:32 |
start [/forum/topic.php?fid=32&gotonew=1&tid=1541944]: |
154ms |
42ms |
| others: | 208ms |
| total: | 452ms |
