Crystal Report
prochitala statiuy http://www.gotdotnet.ru/LearnDotNet/Misc/180671.aspx vse sdelala. est funkzii: private void btnParameterLoadReport_Click(object sender, System.EventArgs e) { ws1.Service1 ws1 = new WinClientCRSh.ws1.Service1(); DataSet myDataSet = new DataSet(); ReportDocument myReport = new ReportDocument(); string ShipCountry; ShipCountry = tbShipCountry.Text; myDataSet.Merge(ws1.LoadReport(ShipCountry)); dataGrid1.DataSource = myDataSet.DefaultViewManager ; myReport.Load("CrystalReport1.rpt"); myReport.SetDataSource(myDataSet); crystalReportViewer1.ReportSource = myReport; } public DataSet LoadReport(string ShipCountry) { DataSet ds; ds = new DataSet(); sqlDataAdapter1.SelectCommand.Parameters["@ShipCountry"].Value = ShipCountry; sqlDataAdapter1.Fill(ds); return ds; } posle zapuska proekta v dataGrid1 vivodyatsya nyshnie dannie (naprimer tolko te,y kotorix ShipCountry =USA). a vot v Report vivodyatsya vse, kotorie est v report1.rpt v chem moshet bit problema? ... |
| 26.01.2006, 12:19:12 |
start [/forum/topic.php?fid=31&gotonew=1&tid=1539265]: |
82ms |
68ms |
| others: | 337ms |
| total: | 563ms |
