Image в Footer RS2000
Люди поможите! Как вставить Image из базы данных(логотип компании) в Footer отчета Reporting Service? ... |
| 07.02.2007, 11:29:08 |
Создать dataset который возвращает единственную запись с картинкой Сделать внутренний параметр, значение которого берется из этого самого dataset'a Установить Image Value в =Parameters!LogoImageParam.Value --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 08.02.2007, 01:21:11 |
Упс, возможно придется делать Encode/Decode Create calculated field "MyEncodedImage" and set expression to =System.Convert.ToBase64String(Fields!MyImage.Value) Create report parameter "MyEncodedImageParam", set its type to String, erase Prompt, clear Allow Null and Allow Blank checkboxes, set default value "from query" and select MyDB as dataset and MyEncodedImage as value field. Set value for your image in the footer to =System.Convert.FromBase64String(Parameters!MyEncodedImageParam.value) --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 08.02.2007, 01:23:31 |
LevSУпс, возможно придется делать Encode/Decode Create calculated field "MyEncodedImage" and set expression to =System.Convert.ToBase64String(Fields!MyImage.Value) Create report parameter "MyEncodedImageParam", set its type to String, erase Prompt, clear Allow Null and Allow Blank checkboxes, set default value "from query" and select MyDB as dataset and MyEncodedImage as value field. Set value for your image in the footer to =System.Convert.FromBase64String(Parameters!MyEncodedImageParam.value) --- This posting is provided "AS IS" with no warranties, and confers no rights. А если не выходит? ... |
| 21.03.2007, 13:23:31 |
start [/forum/topic.php?fid=31&gotonew=1&tid=1538169]: |
29ms |
56ms |
73ms |
| others: | 338ms |
| total: | 568ms |
